| Vase |
 Vase Two Stroke Sniffer
 Posted: 16:54 - 20 Jan 2013 Post subject: zx6r f3 not getting any fuel |
hi, my zx6r f3 97 aint getting any fuel!
Iv replaced the fuel pump relay with a 2nd hand on that came off a running bike,
the fuel filter aint blocked,
checked with cap open,
any ideas what else i can check before replacing the pump as that is the dearest part.
the fuel pump i have had off and checked with a direct feed, now it seems to do something but not much but i dont realy know what to expect from it so i dont know if it is right or not.
basically il try to explain what it does, if you can imagine something going up and down inside it (in like a pumping action) when connected to the live feed it will go up (inside) and then nothing until to disconnect it then it will go back down.
should i expect more from it than that?
any ideas will be greatly appreciated as its sat outside under cover in this weather with out being turned over which cant be good for it  ____________________ Current : zx6r f3
Previous : gsf400 |
| Fizzer Thou |
| ZaphodBeeble |
 ZaphodBeeble World Chat Champion
 Posted: 15:57 - 21 Jan 2013 Post subject: |
When you drain the fuel from the pump and then reconnect it you should hear it clicking while it fills up with fuel. This will only happen when you turn the ignition on. It should start clicking about 4 times a second and then gradually slow down until the fuel is fully primed into the pipes and carbs. Actually, I think you might have to crank the engine to start the pump clicking. Try with just the ignition on first and then crank it if the pump doesn't click.
Also, as Fizzer says above, try cleaning those points if it doesn't click at all. ____________________ Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders. |
| Vase |
| Stonefly |
 Stonefly Scooby Slapper
 Posted: 17:24 - 21 Jan 2013 Post subject: |
Sounds like you need one of these,.
https://www.wemoto.com/bikes/kawasaki/zx-6r_zx_600_f2-f3/96-97/picture/fuel_pump_repair_kit_-_point_switch/
Its a common problem on Kawas.
Take out the existing one and have a look. It will probably be pitted to buggery and generally worn. ____________________ Current......Kawasaki ZZR1200 C2H and Kawasaki ZZR600 E7
Previous....Yamaha FS1E, Honda SS50, Suzuki AP50, BSA Bantam D14, Honda CD175, Honda CB250N, Kawasaki Z250A3, Yamaha RD250E, Kawasaki Z400, Kawasaki Z500, Kawasaki GPz550, Honda NTV600, Kawasaki GT750, Kawasaki Z1000R, Kawasaki GPX250 |
| Vase |
| ZaphodBeeble |
 Posted: 22:53 - 21 Jan 2013 Post subject: |
I fitted a used pump to a G model not so long ago. That one cost around £30 off ebay. You can get what appear to be pattern pumps for about £75 too. ____________________ Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders. |
| Vase |
The last post was made 13 years, 18 days ago. Instead of replying here, would creating a new thread be more useful? |
