No Drive
R1stu
Shrek!
PostPosted: 22:01 - 11 Nov 2004    Post subject: No Drive Reply with quote
I was out and about monday when I ran into a problem!
I went to pull away after completing a job!
Starts bike, puts into gear lets clutch out, speedos going up but yet im at a stand still! :thumbdown :bugeyes
The chain is rotating when i roll the bike, so im not too sure if its jumped of the front sprocket or not?
Does it sound like final drive gears gone? It all clicks into gear and clutch works etc. just no drive to rear wheel?
HELP!
Carbon closet tart! https://www.bikepics.com/members/r6stuk/02r6/
Stolen bike. 2000 R1: https://www.bikepics.com/members/r6stuk/00r1/
Current bike 1991 Honda ST1100 Pan European, 1986 Honda cb350sg (Finished)
Guest
PostPosted: 22:53 - 11 Nov 2004    Post subject: Reply with quote
Is the chain spinning in relation to the engine revs when you've put it in gear, or just turning when you push the bike?
I assume you can see whether it's on the back sprocket correctly or not, so it sounds like .....
a: the chain has jumped off the front sprocket
b: the front sprocket has come off it's splines
c: (very expensive) the output shaft has sheared/lost it's splines.
If the speedo's driven off the front sprocket then it's obviously turning so it sounds like 'a'.
R1stu
Shrek!
PostPosted: 23:55 - 11 Nov 2004    Post subject: Reply with quote
Driven from the font sporcket! and dosent turn when engine moving! but rotates when move bike!
am going to take off the cover soon!
PostPosted: 00:10 - 12 Nov 2004    Post subject: Reply with quote
As the speedo is moving I would say that the most likely thing is that you have copied a certain NSRs chain:-
https://www.alfa-pages.co.uk/TempPicture/cols_sprocket.jpg
sickpup
Old Timer
PostPosted: 01:23 - 12 Nov 2004    Post subject: Reply with quote
As the man above say's, that or you've stripped the splines off of the output shaft.
R1stu
Shrek!
PostPosted: 10:46 - 12 Nov 2004    Post subject: Reply with quote
my chain does look a bit that! Shocked it has not been used for 2-3 months and left outside! and now is 2-3 incs of slack! I have a spare sprocket so I can put them on there!
Let you know the weekend!
Guest
PostPosted: 13:35 - 12 Nov 2004    Post subject: Reply with quote
There's another 1000 miles in that if you turn it round Wink
PostPosted: 14:37 - 12 Nov 2004    Post subject: Reply with quote
Laughing . Think it might need more than that. Could use it as a blank for machining up a new smaller sprocket.
kasandrich
PostPosted: 16:26 - 12 Nov 2004    Post subject: Reply with quote
I think you could say the owner of that sprocket has had his monies worth Razz
But look how dry & rusty the chain looks! who would ride a bike like that?
Richard
CBR1000FM
mr jamez
PostPosted: 16:54 - 12 Nov 2004    Post subject: Reply with quote
He is on these forums I believe Laughing
R1stu
Shrek!
PostPosted: 22:52 - 12 Nov 2004    Post subject: Reply with quote
Looks like the sprockets come off the splines!
dose any1 know what the size the bolt is that holds the sprocket on as i seemed to have lost mine! :bugeyes
And where I can get one from before monday?
Mr Tickle
PostPosted: 23:13 - 12 Nov 2004    Post subject: Reply with quote
Silly question... How can the speedo move when the bike is at a standstill? The cable goes to the front wheel doesn't it? Question
Forgive my ignorance if I'm wrong Rolling Eyes
Mr Tickle
R1stu
Shrek!
PostPosted: 23:15 - 12 Nov 2004    Post subject: Reply with quote
The R6 is driven from the front shaft!
Guest
PostPosted: 23:19 - 12 Nov 2004    Post subject: Reply with quote
Any Yam dealer should stock 'em, try Fowlers in Bristol if you can't get one locally. Part number 90179-18020-00 according to YAM's USA site. I'd get a new tab washer too - 90215-21022-00
PostPosted: 00:48 - 13 Nov 2004    Post subject: Reply with quote
Is it a bolt or a large nut? Watch out as it is quite easy to wreck the thread on the output shaft from the gearbox so that the nut will not go on again.
The last post was made 21 years, 349 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.99 - MySQL Queries: 13 - Page Size: 88.29 Kb
