DVI connectors... completely confused
Jayy
Mr. Ponzi
PostPosted: 19:31 - 22 Jan 2013    Post subject: DVI connectors... completely confused Reply with quote
Having trouble finding the right adapters.
Setup:-
Card: DVI-D Dual | DVI-I Dual | HDMI | Display Port
Samsung Monitor: DVI-D Single | HDMI
Acer Monitor: DVI-D Dual | HDMI
Projector: HDMI | HDMI
The Acer needs to be DVI-D Dual connected, as it's 144hz. ( or HDMI if it supports it? )
The Samsung is only 60hz but has DVI-D Single and my card will only have the DVI-I Dual input as the Acer is in the other.
Projector has to be HDMI as there's no others for it to go in.
Can I use the diplay port to HDMI for the projector and use HDMI to HDMI for the monitor? As the only other way of doing it would be for some kind of DVI-D single to DVI-I Dual adapter, as they're completely different connections?
https://i.imgur.com/TFSoTTN.gif
Mind fuck.
Jayy
Mr. Ponzi
PostPosted: 19:39 - 22 Jan 2013    Post subject: Reply with quote
I could do it like this:-
Acer HDMI to HDMI ( Will it be 144hz? I think they are but not sure )
Projector HDMI to Display port (adapter)
Samsung DVI-D single to DVI-D dual ( will the connector even work? )
oldpink
PostPosted: 19:42 - 22 Jan 2013    Post subject: Reply with quote
had similar issues, ended up using DVI -> HDMI adapters to resolve it
Alpha-9
PostPosted: 19:43 - 22 Jan 2013    Post subject: Reply with quote
I agreed with the mind fuck statement and can unfortunately add little else to this thread.
Fzr-600 1999
AlanC
PostPosted: 19:49 - 22 Jan 2013    Post subject: Reply with quote
Acer: DVI-D dual to DVI-D dual so you get the full resolution.
Samsung: DVI-D single to DVI-I dual with a DVI-D single cable (DVI-I carries analogue as well as digital; you just need the digital bit).
Projector: HDMI to HDMI.
DVI cables are so wonderful. Laughing
DVI single cables have got a resolution maximum limit of 1920x1200 so they they are not the 100% best.
Display port is good, I believe for that you could use an adapter to take it to fit a dvi dual cable.
Jayy
Mr. Ponzi
PostPosted: 20:05 - 22 Jan 2013    Post subject: Reply with quote
The 6990 had 1 DVI-D and 5 mini HDMI... was so much easier connecting displays.
Jayy
Mr. Ponzi
PostPosted: 20:09 - 22 Jan 2013    Post subject: Reply with quote
The Samsung won't go DVI-D single to DVI-I dual... look at the difference in connectors. THe DVI-I dual has 4 extra pins, which would need some kind of adapter to fit.
However it will fit in the DVI-D Dual and recognises it. But I need the Acer in there.
AlanC
PostPosted: 20:17 - 22 Jan 2013    Post subject: Reply with quote
Display Port isn't compatible with DVI without using adapters.
DVI-I carries analogue and digital signals
DVI-D is digital only
DVI-A is analog only
Single link has a max resolution of 1920x1080 or 1600x1200
Dual link goes up to about 2560x1600
A dual link port will support single link monitors.
HDMI is, basically, DVI-D Single.
So all you need to do is plug your monitors into the either of the DVI ports using suitable cables, and go HDMI to HDMI for your projector.
Edit: Was typing that as you posted. The extra pins on the DVI-I are for analogue monitors; you don't need to worry about them, and a DVI-D plug should go in a DVI-I socket without problems.
Jayy
Mr. Ponzi
PostPosted: 20:20 - 22 Jan 2013    Post subject: Reply with quote
My great illustration of the situation...
https://i.imgur.com/dlDihrg.jpg
J.M.
PostPosted: 20:21 - 22 Jan 2013    Post subject: Reply with quote
My PS3 setup used to be:
HDMI -> DVI-D (single) -> HDFury (DVI-D double) -> VGA
Worked a treat despite plugging a single in to a double socket. The HDFury was simply there to strip the HDCP from the HDMI.
Anyway, it seems to be from an initial point of view that you could simply use DVI -> HDMI for all of your devices?
Edit... looked at the picture above... now confused.
2004 R1 & 2018 XSR900
bEN_
PostPosted: 20:22 - 22 Jan 2013    Post subject: Reply with quote
Are there any DVI connections that carry audio aswell?
curious because my surround sound is connected up in a gay way with the ps3 because apparently DVI doesn't do the audio.
my ps3 is hooked up to my hitatchi monitor and is HDMI in the ps3 and DVI to the monitor, which has no HDMI slot Confused
2010 Ducati 848 Dark
Lamp Post Enthusiast
AlanC
PostPosted: 20:31 - 22 Jan 2013    Post subject: Reply with quote
Nope, DVI is video only.
HDMI can carry a bunch of other stuff like audio, remote control and Ethernet, plus the latest versions can do 3D and 4K resolution.
el_oso
PostPosted: 20:37 - 22 Jan 2013    Post subject: Reply with quote
If it's the monitor that has DVI as an input then no.
Best solution would be use optical out of the ps3 into the surround sound (i think)
Duke 390
Car: Jeep Wrangler 4.0L
Jayy
Mr. Ponzi
PostPosted: 21:00 - 22 Jan 2013    Post subject: Reply with quote
Tried to plug the Samsung into the DVI-I Dual on the left of the card but it doesn't fit, only the right (DVI-D) and the Acer lead won't fit in the DVI-I... they have solid plastic around them so the 4 pins on the DVI-I block it from going in.
I will sort it, the Acer arrives on Thursday, so I will see what's what then.
AlanC
PostPosted: 21:47 - 22 Jan 2013    Post subject: Reply with quote
Eh? The DVI-I socket on the card should have holes for the four analogue pins above and below the large flat pin. You're saying the Samsung plug won't go in the socket because its got some plastic bits in there to block it? Confused
If the cable goes to a socket on the Samsung you could replace it with a standard DVI-D to DVI-D that would go in the DVI-I on the card.
Wikipedia has a pretty good section on all the permutations.
The last post was made 13 years, 249 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 87.66 Kb
