honda cg 1987
ts50x0
PostPosted: 14:12 - 12 Nov 2004    Post subject: honda cg 1987 Reply with quote
what is this bike like ive just bought one to get to work and back on. i need something really reliable with a little bit of poke when riding in towns. ive heard the 1987 is the fastest model and also still very reliable. it has cost me 500 with 12800 miles on it and in near perfect condition. and it was owned by and old man and then the present owner a lady.
what do you recon i should expect from this bike and did i get a good deal? well you cant go too far wrong for 500 nicker!!!
cheers
guys.
p.s. oh and if your wondering why i backed out from the brand new cg in the end insureance was way too high so.....
8316
PostPosted: 14:16 - 12 Nov 2004    Post subject: Reply with quote
have you actually seen the state of the bike? might help a little bit. and hearing how it runs as well can help. Laughing
Now own a Fireblade!! Speed Limits? Bah!
ts50x0
PostPosted: 20:03 - 12 Nov 2004    Post subject: Reply with quote
it runs nicley but im no mechanic. not much to go wrong with these although i know sometimes it can. it revs right through fine and the engine sounds sweet,
and as i said its in near perfect condition!
Nath
PostPosted: 20:51 - 12 Nov 2004    Post subject: Reply with quote
£500 is not *cheap* for a bike 17 years old, but if it's in good condition and the engine's fine then that sounds fair enough. They are solid, but make sure you take care of it - Keep up to date with oil changes, take it easy for the first mile or two in order to let the engine warm up, and don't run it for any length of time with the throttle fully open.
Since they only take a few quids worth of oil, you should probably change the oil now, regardless of when the previous owner said they last did it.
To get any kind of performance out of it, you'll need to thrash it, but this is okay since the engine is so hardy. Just not when it's still cold. It will beat practically all non-sports cars around town, but for higher speeds it just doesn't have the grunt Sad
Hard livin', hard luck.
mchaggis
PostPosted: 22:36 - 12 Nov 2004    Post subject: Reply with quote
About 1.5 litres max if I remember correctly. 90-100 mpg, you could get about 200 miles out of the tank. Ah, and certainly don't run it at full throttle for extended periods, the CG languishing in my Mum's garage was held at full throttle for 10 minutes, we think the main bearings are boogered.
I imagine 60 will be about full whack for it if you have any mechanical sympathy though. The redline will be at about 10,000rpm, which is quite high enough if you think what the rockers are doing in there. Shocked
I must not be a troll...
Mmmm, Guinness
pipnet11
PostPosted: 23:52 - 12 Nov 2004    Post subject: Reply with quote
errrr, does this apply to old GS125s aswell?? If so why? mine did 20 miles each way to work, 5 days a week, for about 4 month and at least 12 miles each way was at full throttle. Hasnt done it any harm. Infact when I checked the compression with my dads little pressure meter thing, it was better than my mates GS. His is only 4 years old and has done 25,000 miles less. A tad worrying for him I think.
I love the girls that do, I hate the girls that dont, I hate the girls who say they will and then they say they wont, but the girl I like most of all and I think youll say Im right, is the girl who says she never has but looks as though she might. - Max Bygraves
mchaggis
PostPosted: 23:59 - 12 Nov 2004    Post subject: Reply with quote
Well, I (semi-) regularly run mine (CG125 engine) at around 8000 rpm for an hour or so doing about 45-50 mph going home on the A roads past Nottingham... No problems with it yet, though I
I agreed with the not fully open throttle thing as I have seen the results. It's not neccesarily going to always be the case though, we could have just got a bad 'un.
Mmmm, Guinness
RS1Banger
PostPosted: 09:01 - 13 Nov 2004    Post subject: Reply with quote
I rode a Honda C70 130 miles to Newcastle, flat out all the way, I only throttled off when forced to. The valves were bouncing in top gear for at least an hour solid up the A19. I rode this journey 5 times there and back, no damage occured.
The last post was made 21 years, 225 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 3.59 - MySQL Queries: 13 - Page Size: 58.02 Kb
