Ignition lock trouble
Doovy
PostPosted: 19:02 - 25 Jan 2013    Post subject: Ignition lock trouble Reply with quote
Hello guys and girls.
I'm having a little trouble with my ignition lock (2002 Honda Hornet CB600).
The problem is thus: if I put the key in and turn ignition on thats fine.. but if I then turn it off and try and put it into steering lock, it won't budge to the left, and then I can't even turn the ignition back on.
I have to wiggle the key about a lot, pulling it upwards and trying to turn. It just won't go left or right. Eventually after playing for a few goes it then turns ignition back on, but *same problem*, it won't go to steering lock and I'm back to square 1.
I've tried spraying some 3 in 1 lube in there, no joy..
It seems the problem is when I push 'down' to get to steering lock.. that's when it refuses to turn either way. Is it a case of a 10 year old lock having it's final moments before dying? Quite expensive for a new set (£200ish)...
Anyone have any ideas? This has only been happening for a few days now!
Hetzer
PostPosted: 19:09 - 25 Jan 2013    Post subject: Reply with quote
I had the same problem with my Kwak. I rammed loads of lithium grease into the slot which fixed it.
Doovy
PostPosted: 19:16 - 25 Jan 2013    Post subject: Reply with quote
Lithium grease you say? Will purchase and try some of that tomorrow, thanks Hetzer.
Hetzer
PostPosted: 19:18 - 25 Jan 2013    Post subject: Reply with quote
I suspect any other grease would do just as well. I used lithium because it was the pot I found first.
Nick_Giles
PostPosted: 19:29 - 25 Jan 2013    Post subject: Re: Ignition lock trouble Reply with quote
Ditto recently on mine.
Cured it with aerosol grease with a tube on.
Put the key in a little bit so it makes a gap in the lock gate. Spray and repeat, spray and repeat. Do the same over a couple of days.
If you can twist the flexible tube and try to get some into the actual locking bar at the bottom of the lock. The moving bit that goes into the 'keep' on the frame headstock and stops the yokes being moved when locked.
Nick
Doovy
PostPosted: 19:33 - 25 Jan 2013    Post subject: Reply with quote
Ok cool - so grease may be the answer then.
I've never actually seen where the locking bar is for the steering lock, will have a looksie tomorrow. Cheers!
Nick_Giles
PostPosted: 19:42 - 25 Jan 2013    Post subject: Reply with quote
It's not overly obvious. But it exists I can assure you. Smile
They are deliberately out of the way and not easily accessible to make it more difficult for 'poor-sweet-innocent-neglected-by-society-Duane-chav.' to get at. Evil or Very Mad
Nick
Doovy
PostPosted: 10:56 - 26 Jan 2013    Post subject: Reply with quote
Ha, this is awkward.
After all the lube I sprayed in there last night (behave, you lot), it has loosened it all up and working fine now!
Cheers for all the help, usually the simplest of solutions we try - but didn't want to chance a more serious problem!!
Hetzer
PostPosted: 11:04 - 26 Jan 2013    Post subject: Reply with quote
I'd still pack lots of grease in there, otherwise it'll all dry out and start acting up again.
Doovy
PostPosted: 11:13 - 26 Jan 2013    Post subject: Reply with quote
Mmm grease-packing.
Will do Thumbs Up
MattEMulsion
PostPosted: 20:14 - 27 Jan 2013    Post subject: Reply with quote
Try some Ambersil Graphite Lock Lube, it works wonders and is designed for the job. It was about £3 from Maplins last time I had some.
Yamaha YZF-R6
Doovy
PostPosted: 20:43 - 27 Jan 2013    Post subject: Reply with quote
Sorted now, cheers Smile Thumbs Up
Will keep a look out for that stuff though!
The last post was made 13 years, 291 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.31 - MySQL Queries: 13 - Page Size: 78.89 Kb
