Oil filter cover bolt thread knackered, what are my options?
EazyDuz
PostPosted: 14:43 - 27 Jan 2013    Post subject: Oil filter cover bolt thread knackered, what are my options? Reply with quote
Just did an oil and filter change on the Virago.
Upon re tightening the 3 bolts which secure the cover over the oil filter, one of them (the longest one) wouldnt tighten. Im confident i didnt overtighten the thread, the 2 other bolts were slightly tighter with the threads intact.
So i removed the bolt and on the thread itself there is a metal coil type peice about 5mm long on the tip of the thread, i dont know if it was thread from the casing itself or if its the remains of a previous repair to the thread in the engine.
So now something needs to be done otherwise im fairly sure its going to leak oil. What are my options?
Fisty
PostPosted: 14:48 - 27 Jan 2013    Post subject: Reply with quote
You have stripped the thread, needs a helicoil.
Fatter and faster than Fret
CaNsA
PostPosted: 14:56 - 27 Jan 2013    Post subject: Reply with quote
Fisty you are way off the mark.
Needs more tassels.
EazyDuz
PostPosted: 14:58 - 27 Jan 2013    Post subject: Reply with quote
Just been reading the bolt in question is a common one to mess up. Is a helicoil an easy procedure? Might take to a garage for it. Im assuming the filter cover will have to come off, which also means all that new oil drained and replaced as well?
Fisty
PostPosted: 15:12 - 27 Jan 2013    Post subject: Reply with quote
They are a piece of piss to do, just drain the oil into a container and put it back in the bike when you are done.
https://www.youtube.com/watch?v=RFYa6sjhh_E
EazyDuz
PostPosted: 15:22 - 27 Jan 2013    Post subject: Reply with quote
Ok thanks is there a particular retailer best to buy the kit from?
The bolt in question is here:
https://www.cmsnl.com/yamaha-xv535a-virago-1990_model9652/partslist/B-01.html#results
Part number 5, but it doesnt say what size the thread is so i need to find that out before ordering the kit.
EazyDuz
PostPosted: 16:48 - 27 Jan 2013    Post subject: Reply with quote
Just seen Machinemart sell them, but then there are some on Amazon and loads on ebay too, which kits are the best?
EazyDuz
PostPosted: 19:42 - 27 Jan 2013    Post subject: Reply with quote
bump
hmmmnz
PostPosted: 14:04 - 28 Jan 2013    Post subject: Reply with quote
the best are time-sert or keensert type inserts, rather than the coil type, re-coil, heli-coil etc
the humans are dead
I kick arse for the lord
EazyDuz
PostPosted: 14:46 - 28 Jan 2013    Post subject: Reply with quote
What makes them better
EazyDuz
PostPosted: 17:08 - 28 Jan 2013    Post subject: Reply with quote
True but imo not worth the £100+ price tag, helicoils are supposedly easy
The last post was made 13 years, 143 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.25 Sec - Server Load: 2.21 - MySQL Queries: 13 - Page Size: 78.79 Kb
