water pump and ballence gears
chappy
PostPosted: 15:44 - 27 Jan 2013    Post subject: water pump and ballence gears Reply with quote
hi there just opened up my clutch case on my rs 125 because of a Grey oil leak.
found a damaged cog. got replacements on hand with a new gasket and water pump seals and rings for water pump .
is there a certain way the seals face going in the pump as they both faced spring outwards when removed not sure if they was right way round. . also when i do the balance gears i know about the markings but is there a easy way to find the TDC some one said on the net that you can put a screwdriver in plug hole and twist to highest point to find the tdc is this right and is it as easy as that thanks iv attached pics included
thomp1983
PostPosted: 18:28 - 27 Jan 2013    Post subject: Reply with quote
Download the rs125 workshop manual both are well covered in there
Chris
thomp1983
PostPosted: 18:30 - 27 Jan 2013    Post subject: Reply with quote
Chris
The last post was made 13 years, 291 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 34.92 Kb
