Tachometer (i think)
jamie192
PostPosted: 19:28 - 12 Nov 2004    Post subject: Tachometer (i think) Reply with quote
hi,
The tachometer (rev counter) does not work on my bike, i know the problem its the cable coming from then engine has broken from inside. Is it worth getting a new one does the rev counter help much. I know its not legally required though.
Ride Fast, Brake hard, don't fall off!
Marc_Buck
PostPosted: 19:43 - 12 Nov 2004    Post subject: Reply with quote
An experienced rider will never ever need one, certain bikes do not even have one. (rev counter, that is.)
94 fzr600r
8316
PostPosted: 19:55 - 12 Nov 2004    Post subject: Reply with quote
if you pull wheelies, it might help to have one that works, but otherwise you should be fine without one.
Now own a Fireblade!! Speed Limits? Bah!
mchaggis
PostPosted: 20:34 - 12 Nov 2004    Post subject: Reply with quote
My rev counter went round the clock, getting stuck pointing at six oclock, so I unpinched the metal collar holding it together, put it right, then did it up. I forgot of course that moving the needle on the spindle would loosen it, so after about 3 miles it just fell off. Then of course, the metal collar is work hardened and now is hugely tough and brittle. Rolling Eyes I really never need it though, about the only time it would be useful would be when I'm sat at around 45 or so for an hour or so, as I can't tell if the engine's at 8000 rpm, or maybe more... Thinking
I must not be a troll...
Mmmm, Guinness
Rollins
PostPosted: 22:47 - 12 Nov 2004    Post subject: Reply with quote
You should know whereabouts the redline is by the pitch (note) of the engine. If you know that, then you don't really need the tacho.
"... I wouldn't mind doing 130 up to a T junction, but unfortunately my bike tops out at 120 which is gay..."
2005 CBR600RR
Guest
PostPosted: 08:42 - 13 Nov 2004    Post subject: Reply with quote
I'm going to take mine out and fit a clock in it's place - much more useful Thumbs Up
nick.h
PostPosted: 16:12 - 13 Nov 2004    Post subject: Reply with quote
thats just started happening on my bike. once i go into neutral it goes back down to 2, but when i put it onto 1st and rev it up, it goes straight to 6 and comes down very slowly as i ease off the throttle...
[Italjet MM5A] ll [Rieju RS1 Evolution] ll [Suzuki GS500e] ll [Suzuki GSX600F] ll [Honda CG125] ll [Pug Elyseo 125] ll [Yamaha YZF750R] ll [Yamaha Thunderace] ll [Yamaha R6] ll [Triumph 955i] ll [Hayabusa RZK3] ll [Suzuki RGV250] ll
The last post was made 21 years, 189 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.72 - MySQL Queries: 13 - Page Size: 51.47 Kb
