helicoil a brake caliper
daffy
PostPosted: 21:53 - 27 Jan 2013    Post subject: helicoil a brake caliper Reply with quote
need some help here. thread is fucked in the caliper, the bolt winds in hand tight, keeps spinning and doesn't bite. do i helicoil it or tap n get a bigger bolt? thanks.
Matt578
PostPosted: 22:27 - 27 Jan 2013    Post subject: Reply with quote
Do you have a picture?
Your Daddy, Everyone's Friend.
EazyDuz
PostPosted: 22:52 - 27 Jan 2013    Post subject: Reply with quote
Isnt helicoiling tapping anyway? You tap so the helicoil threads in place.
Nick_Giles
PostPosted: 23:07 - 27 Jan 2013    Post subject: Reply with quote
Yes it is. Thumbs Up
But with a helicoil you then screw in an insert and then use the original size bolt.
I think the OP is considering drilling and tapping a larger thread and then using a larger bolt that will then fit the new larger thread.
Nick
EazyDuz
PostPosted: 23:11 - 27 Jan 2013    Post subject: Reply with quote
Thought so, in which case theres no point. Helicoils are supposedly stronger than the original thread
daffy
PostPosted: 23:19 - 27 Jan 2013    Post subject: Reply with quote
a pic of what? its a front caliper of an fzr 600r
nick, spot on. never had the need to do either before so not sure which is better
Matt578
PostPosted: 23:40 - 27 Jan 2013    Post subject: Reply with quote
Just wanted to see Exactly what you was talking about so i could give you some reasonable and accurate advise. If you can tap it one size up and get away with using a larger bolt then go for it, Just check the larger bolt will go through the hole in the fork too, If it won't helicoil might be the way forward.
Walloper
PostPosted: 03:12 - 28 Jan 2013    Post subject: Reply with quote
The fcuk they're not.
Helicoils would only be 'stronger' when inserted into a soft/er alloy. In steel they are a bit weaker than tapped parent metal due to stack up of tollerance. i.e. The small gaps introduced between the treads (which enable a fastener to be turned in/out).
The last post was made 13 years, 291 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.77 - MySQL Queries: 13 - Page Size: 55.44 Kb
