intake manifolds xjr1300
johnxjr
PostPosted: 10:41 - 28 Jan 2013    Post subject: intake manifolds xjr1300 Reply with quote
i have fitted 36y intake manifolds to 2005 xjr1300 i need some advice on jet sizes and where they can be sourced any advice will be welcome.
cheers
john
Fizzer Thou
PostPosted: 16:22 - 28 Jan 2013    Post subject: Reply with quote
G'day mate.
Nice way to introduce yourself.
Do you mean the rubber inlet manifold/adapter between the carbs/injectors and the engine or the rubbers/bellmouths between the carbs/injectors and the airbox?
Always have a 'Plan B'
johnxjr
PostPosted: 19:05 - 28 Jan 2013    Post subject: inlet manifolds Reply with quote
the inlet manifolds from carbs to head.
john
temeluchus
PostPosted: 20:24 - 28 Jan 2013    Post subject: Reply with quote
Those are FJ1200 manifolds presumably.
The FJ1200 uses the similar Mikuni BS36 carburettors. Stock jetting for the FJ1200 in the UK is 112.5 mains and 40 pilots. US jetting is 110 mains and 42.5 pilots. XJR1300 apparently runs 107.5 mains.
See how it runs on stock jetting, if it isn't happy I would suggest getting a set of 110s and 112.5s and seeing if it is happier.
temeluchus
PostPosted: 20:28 - 28 Jan 2013    Post subject: Reply with quote
Any decent parts supplier should sell Mikuni main jets.
Wemoto sells them, among others. They should be around £3 quid each.
johnxjr
PostPosted: 03:11 - 30 Jan 2013    Post subject: xjr manifolds Reply with quote
Thanks for that ill ,give them a try .
Good on ya
john
The last post was made 13 years, 14 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.95 - MySQL Queries: 13 - Page Size: 46.71 Kb
