Strange Headlight Problem
Ollie1995 This post is not being displayed because the poster is banned. Unhide this post / all posts.
gfrancisdev
PostPosted: 23:05 - 28 Jan 2013    Post subject: Reply with quote
https://www.maplin.co.uk/domestic-multimeter-37279
just get a meter, they're horribly useful for the price Razz
Islander
Sounds like a loose/broken connection. Buy a multimeter - they aren't expensive.
Islander
PostPosted: 23:56 - 28 Jan 2013    Post subject: Reply with quote
It could indeed be a faulty earth but how can you check unless you can measure voltage both across the headlight bulb connector and then across a known good earth and the bulb connector?
Seriously, a meter is an essential part of your toolkit. Thumbs Up
Islander
PostPosted: 00:23 - 29 Jan 2013    Post subject: Reply with quote
unitynotsocrippledatmo wrote:
maybe a knacked lighting coil or a disconnected wire from the genny.failing that check out the connectors in the headlamp and loom,sometimes knacked switchgear can cause similar problems through corrosion.
The other lights are working. It's only the headlight itself.
andym
PostPosted: 01:16 - 29 Jan 2013    Post subject: Reply with quote
Before I had a multi-meter I just connected a couple of wires to the battery for testing purposes.
Islander
PostPosted: 01:32 - 29 Jan 2013    Post subject: Reply with quote
I've improvised with a bulb and a couple of lengths of wire when I've been stuck without my meter. Thumbs Up
The last post was made 13 years, 140 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.76 - MySQL Queries: 13 - Page Size: 65.44 Kb
