Brake Cable Nut
neilzomg
PostPosted: 15:27 - 30 Jan 2013    Post subject: Brake Cable Nut Reply with quote
I need a nut for my brake cable. The nut supplied with the brake cable (chinese cable) this is the exact one - https://www.ebay.co.uk/itm/190785122588?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
Seems to slip inside the drum brake holder.
the nut is 14mm..
Does anyone know if I can buy a nut to fix this?
Neil.
PostPosted: 15:40 - 30 Jan 2013    Post subject: Reply with quote
It's called a brake rod adjuster nut and it's only used for that application but it'll be a standard metric thread.
You'll be able to use a standard M6 or M8 nut. A proper one has a curved cutaway that butts against the brake trunnion (the cylindircal bit with a hole through the middle) which stops it undoing itself.
As such, I usually use two nuts to act as a locknut or a nylok nut
neilzomg
PostPosted: 00:38 - 02 Feb 2013    Post subject: Reply with quote
I ordered a nut which was way too big, fortunately the other one fitted inside the thread of the big nut solving the problem!
I guess sometimes things work out.
The last post was made 13 years, 257 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.72 - MySQL Queries: 13 - Page Size: 35.61 Kb
