possible electrical issue?
GREENI3
PostPosted: 17:23 - 30 Jan 2013    Post subject: possible electrical issue? Reply with quote
On the way home today I noticed the rev counter was moving up and down even though the engines rpm wasn't (ie. riding at a constant 5k, but needle suddenly drops to 4k and moves back again).
Engine noise didn't change at all.
It did this pretty much the whole journey.
And the indicators decided to flash really fast once or twice before reverting back to normal.
Am really confused as to what might be causing this. Confused
Any ideas?
dolly3900
PostPosted: 10:27 - 31 Jan 2013    Post subject: Reply with quote
Possible one of seveal issues.
1) Rectifier on the way out (feeding AC into the DC circuit)
2) Battery on way out (Helps with the smoothing of the output from alternator)
3) Earth issue
Hope that helps a bit
Mike
PostPosted: 11:22 - 31 Jan 2013    Post subject: Reply with quote
Agreed, the speedo on my VFR used to randomly dip when the reg/rec was on its way out. Time to get a voltmeter on the battery and check it's charging properly.
Islander
PostPosted: 11:25 - 31 Jan 2013    Post subject: Reply with quote
Sounds like it might be a dodgy earth connection as it's affecting more than one system.
It wouldn't hurt to meter the battery and check charging conditions as well.
GREENI3
PostPosted: 19:06 - 31 Jan 2013    Post subject: Re: possible electrical issue? Reply with quote
Well I checked the battery last night and was at 12.3v. Started and ran it for a while; voltages were all over the place, mostly going down!
Wouldn't go over 13v at 5k.
Swapped the reg/rec for the original that I had replaced as a preventative measure and it was sort of doing the same thing.
Had it switched off for a while then went to start again and a load of sparks came off the starter motor. It would then only click.
Checked fuses, all ok.
Then thought the earth on the starter motor might be the culprit due to looking quite dirty and the recent rain we've had.
Cleaned it up with a wire brush to get it nice and shiny and put a bit of lithium grease on it. Started first time.
The battery was then reading just under 12.5v, so stuck it on charge overnight.
Put a multi-meter across the battery at work today and was reading 12.9v, so it appears the reg/rec was at fault and possibly the earth was a contributing factor as you guys thought.
The reg/rec I bought was only £25 off ebay, so probably made in china. Not surprising it failed.
BLUEX5 wrote:
Dunno. Hope it catches fire though, preferably on the motorway so it makes jumping off potentially lethal.
Sleeping Sleeping Sleeping Sleeping Sleeping
Wow, your scrap heap must be really stressing you out big time to carry on with your pathetic post stalking.
The last post was made 13 years, 288 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.27 - MySQL Queries: 13 - Page Size: 49.83 Kb
