| cfh85 |
 cfh85 Two Stroke Sniffer
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 22:44 - 30 Jan 2013 Post subject: |
What colour smoke?
Blue? If so it's burning oil, suspect knackered rings. ____________________ My Flickr |
| cfh85 |
| TomGT |
 TomGT Spanner Monkey
 Posted: 22:58 - 30 Jan 2013 Post subject: |
| Wafer_Thin_Ham |
 Posted: 23:12 - 30 Jan 2013 Post subject: |
Basically you'll want to inspect the whole way down the to crank I would suspect. Check those bearings for damage, and work back up from there. ____________________ My Flickr |
| cfh85 |
 Posted: 23:29 - 30 Jan 2013 Post subject: |
Are you trying to imply that my experience with larger, more complicated car engines isn't going to be of any use?
Just because the bike is burning oil, it doesn't mean that I'm causing further damage by driving it. As long as the oil level is maintained there is a good chance that nothing new will be broken. ____________________ Current bike - Honda CBF 125
CBT - 13/01/13 |
| Shaft |
 Shaft World Chat Champion
 Posted: 01:06 - 31 Jan 2013 Post subject: |
| cfh85 wrote: |
Just because the bike is burning oil, it doesn't mean that I'm causing further damage by driving it. As long as the oil level is maintained there is a good chance that nothing new will be broken. |
I think the implication was more about it being a rather odd question to ask.
Doesn't matter if it's fitted to a car, a bike or a wacker plate, an engine is an engine; if you know what the consequences are of starving a car engine of oil, to the point where it seizes, then smokes and knocks as a result, then why would a bike engine be any different? ____________________ Things get better with age; I'm close to being magnificent........
WooHoo, I'm a Man Point Millionaire! https://www.bikechatforums.com/viewtopic.php?t=234035 |
| cfh85 |
| TomGT |
 Posted: 01:30 - 31 Jan 2013 Post subject: |
If you're splitting the cases get a haynes manual  |
| Kickstart |
 Kickstart The Oracle
 Posted: 01:36 - 31 Jan 2013 Post subject: |
Most bikes use a large number of plain bearings which need good oil pressure to work. Not enough oil pressure and the bearings are dead. If you have run it out of oil then almost certainly the engine will need a complete strip to replace all these bearings.
Add to that probably a load of excessive heat wrecking other engine components.
Roller bearings are more resistant to damage from low oil pressure, but that won't help from over heating caused by a lack of oil.
Most of the time it will be a lot cheaper to just buy a 2nd hand replacement engine.
| _Iain_ |
 _Iain_ Banned
 Posted: 01:37 - 31 Jan 2013 Post subject: |
Given the cost & associated ballache with rebuilding it, I'd be inclined to get a breakers engine & run that one till it actually went & kersploded. ____________________ Please be aware that the above post may be full of complete nonsense.
| Shaft |
 Posted: 01:54 - 31 Jan 2013 Post subject: |
| cfh85 wrote: | Not all car engines are the same...
An example of which would be the wankel engines. Not adding oil would cause damage quite quickly, but once the inside of the cylinder has worn down enough it won't get further damage. The design makes the engine more resistant to catastrophic failure.
I have an understanding of how the engines work (obviously not like wenkels) but no clue as how they're put together. |
You've obviously never seen a Wankel suffer a catastrophic failure!
Your engine is put together the same way as pretty much every other OHC 4T; cam and valve train at the top, piston in the middle and crank at the bottom.
You've got a cylinder head, a cylinder block (usually known as a barrel on bikes) and crankcases; they usually have gaskets between them all.
The big differences between a bike engine and a car, are the scale and performance; everything in a bike engine is tiny, including the tolerances and contact areas, plus your bike is revving much harder than the majority of car engines, so lubrication is critical.
In addition, your oil (just over a litre capacity) also has to lubricate the clutch and gearbox, unlike most cars, so it's spread pretty thin and has a hard life, hence much shorter service intervals and probably much more damage, when you let it run out.
You also don't seem to be taking into account the damage caused by oil starvation; you can keep topping it up, but where has all the swarf gone from the scored bores/bearing journals/valve train?
If you don't get rid of that, all topping the oil up does, is swill it around the engine a bit more, causing even more damage.
Car engines can sometimes tolerate that for a while, bike engines most often won't. ____________________ Things get better with age; I'm close to being magnificent........
| smegballs |
 smegballs World Chat Champion
| spaz |
 spaz Nova Slayer
| cfh85 |
| stevo as b4 |
| smegballs |
 Posted: 20:40 - 31 Jan 2013 Post subject: |
If I was you, I'd give myself a slap for making such a noob mistake, chalk this one up to experience and start looking for an 2nd hand engine to flop in your bike.
By all means strip down the fucked one, to have a look, but I wouldn't entertain the idea of building it back to a useable standard - especially if you need a reliable bike for work commuting etc.
I'd find it very difficult to trust an engine that had been run dry, even if the subsequent damage had been supposedly repaired. There can be still be fucked components, or damage that might not be apparent until several thousand miles later.
Think of it from the perspective of going to buy a bike. The guy says, "well it was run without oil to the point of engine failure in the past, but don't worry it's been repaired....". Chances are that you'd walk away and find another bike....
It may be good to go for several thousand miles or it may fuck up a few miles down the road after you've spent hundreds on rebuilding it. A friend of mines dad had the big ends go on his Evo, on its maiden trip out after spending months in his garage with a total top-end rebuild. He reckons there must have been a speck of shit in the oil pump - a few miles down the road and the knocking started. Apparently tears were shed.
| mr jamez |
 mr jamez World Chat Champion
| delsol |
 delsol World Chat Champion
 Posted: 21:56 - 31 Jan 2013 Post subject: |
Just seen this, absolutely ace, rofl  |
| smegballs |
| Walloper |
 Walloper Super Spammer
The last post was made 13 years, 230 days ago. Instead of replying here, would creating a new thread be more useful? |
