| direct2000 |
 direct2000 L Plate Warrior
| lihp |
 lihp World Chat Champion
| direct2000 |
| direct2000 |
| P.addy |
 P.addy Red Rocket
| direct2000 |
| bikenut |
 bikenut World Chat Champion
| Walloper |
 Walloper Super Spammer
| direct2000 |
| Walloper |
 Posted: 04:22 - 02 Feb 2013 Post subject: |
| direct2000 wrote: | | Walloper wrote: | Don't call it a thermostat. It is easier to think of it as a temperature regulator.
It is closed when the engine is cold so coolant is kept in the block and circulated via a by-pass circuit to help the engine warm up to 'running temperature' Engines work better at this temp (82C) as all the bits have expanded to fit properly. And fuel mixing works better.
The regulator then gradualy opens as the heated water warms the wax in the regulator bulb. It pushes a piston out of the wax and opens the valve.
Coolant is then directed to the top of the radiator.
It should be hot at the top and cooler at the bottom.
There shold be a drop of about 10% between top and bottom over the complete surface (when the fan is blowing air through it). Less than this means the system has a fault. Not enough flow.
Pumps are robust but regulators feel heat all their life and can fail.
If only one side of the radiator is hot it means something may be blocking it. Before ripping it all apart drain and fill with fresh water and a radiator cleaner.
Do NOT leave the bike in the cold with this shit in it as it can freeze and fuck the engine.
There are some cleaners that can be added to a frost protected system and run for a few days to act on the system.
Buy good quality Antifreeze. It will come premixed 50:50 with de-ionised water and have 2% inhibitor from the factory It will (should) state this on the bottle/can. |
Do you mean Thermo Switch for Radiator Fan, £ 48.76 (Part # 37760-MT2-003) or Thermo Switch for Temperature Gauge, £ 20.38 (Part # 37750-PC1-0041) faulty?
If the first one, that fixed on the bottom - exit - left side of the radiator which is cold in my case due the lack of coolant circulation that everything is correct. The switch is cold and the fan must not start. My radiator does not have rust (CBF500, 2004) at least outside, therefore, I am sure the thermostat is always closed.
The second one, I think also, is working becauce I can see coolant/engine temperature on the display.
PS: A thermo switch [1] sometimes called a fan switch is a temperature sensor.
Usually close to the radiator in your vehicle engine this device is the one that switches on the fan as soon as the engine/ radiator reaches a set temperature. Symptoms of a faulty thermo switch usually relate in some way to the engine... overheating,
https://www.autosensors.co.uk/en/49-thermo-switch |
No. I mean a water temperature regulator. Which controls the flow of coolant around the engine.
A 'an switch only controls the temperature at which the fan comes on.
They can be electrical, hydraulic or even a bi-metalic strip which closes a valve and forces a viscous fluid through an impeller/turbine affair to drive the fan. ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
| direct2000 |
 Posted: 14:43 - 02 Feb 2013 Post subject: |
[quote=No. I mean a water temperature regulator. Which controls the flow of coolant around the engine.
They can be electrical, hydraulic or even a bi-metalic strip which closes a valve and forces a viscous fluid through an impeller/turbine affair to drive the fan.[/quote]
Are you sure that I have this water temperature regulator on my bike Honda CBF500, 0.5 Litre? This is not a turbo-disel engine. I suppose the thermostat (with a pump) is for this purpose.
Have you got a bike or a car?
PS: This this temp (82C) typed on the thermostat which I ordered which fits to
Honda CBF500, CB600, CBR600, VFR750, CBR900, RVF750, VF750, XR650 &
Kawasaki GPZ400S, KLE400, EX-4, KLE500, ZX600, ER500, GPZ500S, ZX500. |
| Walloper |
The last post was made 13 years, 263 days ago. Instead of replying here, would creating a new thread be more useful? |
