xj900 diversion - any straight swap for the brakes?
c_dug
PostPosted: 17:05 - 31 Jan 2013    Post subject: xj900 diversion - any straight swap for the brakes? Reply with quote
I knackered my reservoir at the beginning of January, and today being pay day I would like to get it sorted.
The original reservoirs seem to be a bit like hens teeth so I'm wondering if there is an easy swap?
jjdugen
PostPosted: 19:54 - 31 Jan 2013    Post subject: Reply with quote
I put EXUP 1000 calipers and master cyl on mine. You could (almost) bend the forks with those suckers! Calipers bolt straight on, dual piston instead of sliding pin type.
PostPosted: 20:13 - 31 Jan 2013    Post subject: Reply with quote
If EXUP1000 callipers fit then so should R1 blue spots. Now they will bend the forks!
c_dug
PostPosted: 20:50 - 31 Jan 2013    Post subject: Reply with quote
Found out through the divvy forum that bluespots do fit, not compatible with the divvy master though so need to find an easy swap for that.
temeluchus
PostPosted: 21:01 - 31 Jan 2013    Post subject: Reply with quote
I suspect your OE master will work with blue spots. Worked fine on a fj1200 with its original master.
MandP sell pattern master cylinders that will work fine.
The last post was made 13 years, 288 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 43.75 Kb
