Aprilia rs 125 starter motor
rob_rob999
PostPosted: 23:02 - 01 Feb 2013    Post subject: Aprilia rs 125 starter motor Reply with quote
I have tried to remove my starter motor todat undone the 2 bolts holding it on and it still wont come out have i missed anything cant see anymore bolts
HELP PLEASE
Rob
andy_uk
PostPosted: 00:09 - 02 Feb 2013    Post subject: Reply with quote
Have you removed the cover from the opposite side to see if the gear is stuck on the shaft?
Also... without checking mine (same engine) are you sure there are only 2 bolts?
If you don't have any luck I'll have a look at mine tomorrow when I'm working on it.
G19RKE
PostPosted: 01:12 - 02 Feb 2013    Post subject: Reply with quote
yes there are only 2 bolts holding it in. the allen key bolts.. the 3 phillips screws are to remove the cover from the unit.
it will come off but if it was engaged properly will need a wiggle side to side and a light pull.. it will come off but dont force anything just wiggle it around untill it frees up.
i had mine off 2 days ago and stripped it down a cleaned everything up nicely..
The last post was made 13 years, 258 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.06 - MySQL Queries: 13 - Page Size: 35.31 Kb
