Removing Brake Piston Inner?
johnsmith222
PostPosted: 18:26 - 02 Feb 2013    Post subject: Removing Brake Piston Inner? Reply with quote
Hi guys.
I was wondering if anyone on here has any tips for removing the inner part of my brake pistons. They are from a tokico 4 pot calipers and the material seems to almost be attached to the pistons probably just through wear.
I'm having to replace my pistons so would like to get them out.
Thanks for any help Thumbs Up
StevenF
PostPosted: 18:48 - 02 Feb 2013    Post subject: Reply with quote
Are you meaning the piston seals? Use something sharp or thin that one damage the rubber too much, push it into the corner or lip of the seal and push it out.
johnsmith222
PostPosted: 18:59 - 02 Feb 2013    Post subject: Reply with quote
Thanks. Unfortunately I wasn't meaning the seals. It's the part of the piston that touches the back of the pads. I think it's actually attached to the piston itself.
StevenF
PostPosted: 19:44 - 02 Feb 2013    Post subject: Reply with quote
I would need to see a picture, they sound different from the style I've seen. All the calipers I've seen are just the piston directly onto the pad of pad shims.
0ddball
PostPosted: 20:26 - 02 Feb 2013    Post subject: Reply with quote
Is it the rubber/plastic inserts or the cork type material ones.If it's the cork, I don't think you'll get them out intact.They seem to be bonded in.
ZXR750L
PostPosted: 21:52 - 02 Feb 2013    Post subject: Reply with quote
Another vote for the brown ones (look like they are made out of fine chipboard material) not being removable. They do seem to degrade over time though.
Presume they are there to insulate the caliper from the heat of the pads.
Stonefly
PostPosted: 10:47 - 03 Feb 2013    Post subject: Reply with quote
I went through this when i rebuilt my ZZR calipers last year. To remove them, you need to drill a teeny hole in the centre of the insert, then screw in a long self tapper, grab it with pliers, and give it a yank. They may come out in one piece, or they may break up. Either way, dont worry about it. You dont need to have them in, but remember to use plenty copperslip on the back of the pads.
Kawasaki do not sell them on their own - they are sold as part of the piston, so you would need to buy a full set of pistons to replace all the inserts, which would cost a 'kin fortune. Hope that helps
Current......Kawasaki ZZR1200 C2H and Kawasaki ZZR600 E7
Previous....Yamaha FS1E, Honda SS50, Suzuki AP50, BSA Bantam D14, Honda CD175, Honda CB250N, Kawasaki Z250A3, Yamaha RD250E, Kawasaki Z400, Kawasaki Z500, Kawasaki GPz550, Honda NTV600, Kawasaki GT750, Kawasaki Z1000R, Kawasaki GPX250
The last post was made 13 years, 270 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.21 Sec - Server Load: 1.04 - MySQL Queries: 16 - Page Size: 55.18 Kb
