Project GOOF! - Honda CBR '91
StevenF
PostPosted: 12:29 - 16 Jan 2011    Post subject: Project GOOF! - Honda CBR '91 Reply with quote
It's not going to a full blown project, rebuild etc... Just doing a few bits and pieces that needs doing to the bike, and I thought I may as well share some of the pictures and what not with everyone else!
I should add that I am a complete novice when it comes to mechanics and the sort of thing. I have replace my down pipes (although I did snap a few bolts in there Shocked), I've replaced my spark plugs (which turned out to be a royal pain the arse on this bike), changed oil etc... But I'm all for learning! Smile
So back to last year - I decided to paint some bits on my CBR that were in need of attention - the engine cover and forks. I think it turned out pretty well!
https://i4.photobucket.com/albums/y118/Wonderboy_001/DSC_0401.jpg
https://i4.photobucket.com/albums/y118/Wonderboy_001/DSC_0402.jpg
https://i4.photobucket.com/albums/y118/Wonderboy_001/DSC_0403.jpg
https://i4.photobucket.com/albums/y118/Wonderboy_001/DSC_0404.jpg
https://i4.photobucket.com/albums/y118/Wonderboy_001/DSC_0408.jpg
https://i4.photobucket.com/albums/y118/Wonderboy_001/DSC_0409.jpg
https://i4.photobucket.com/albums/y118/Wonderboy_001/DSC_0406.jpg
https://i4.photobucket.com/albums/y118/Wonderboy_001/DSC_0405.jpg
And the whole bike:
https://i4.photobucket.com/albums/y118/Wonderboy_001/DSC_0407.jpg
https://i4.photobucket.com/albums/y118/Wonderboy_001/DSC_0410.jpg
Mr. Green
StevenF
PostPosted: 12:37 - 16 Jan 2011    Post subject: Reply with quote
Fast forward to now and it's winter! The bike has been in the garage for the last couple of months, but I'm going out for a wee ride today! Mr. Green Mr. Green
My radiator burst a few months ago and is currently sealed with RadWeld. Since I quite fancied doing some longer rides this year, I thought I better get it sorted! I didn't want to be out a 200 mile run and my radiator to start pishing out fluid again! So, I received this today:
https://i4.photobucket.com/albums/y118/Wonderboy_001/IMG_0006.jpg
https://i4.photobucket.com/albums/y118/Wonderboy_001/IMG_0007.jpg
Not bad considering the age of it, eh! Very Happy I was looking at a few others but they don't even come close to the condition of this one!
I was planning to fit it later today, but I've still got another 2 weeks off work, so plenty of time to get it done!
Maruchino
PostPosted: 13:00 - 16 Jan 2011    Post subject: Reply with quote
Good job on the paint!
StevenF
PostPosted: 20:35 - 25 Jan 2011    Post subject: Reply with quote
Ok so today I decided to tackle my radiator and get it changed over! I was excited at the thought of dismantling my bike! I started off by draining the current fluid:
https://i4.photobucket.com/albums/y118/Wonderboy_001/IMG_0064.jpg
Now, I'm pretty sure it's not supposed to be that colour Sick
I then for the first time, stripped down ALL of the fairings! Very Happy
https://i4.photobucket.com/albums/y118/Wonderboy_001/IMG_0065.jpg
https://i4.photobucket.com/albums/y118/Wonderboy_001/IMG_0066.jpg
https://i4.photobucket.com/albums/y118/Wonderboy_001/IMG_0068.jpg
I thought it looked quite mean! Twisted Evil
Then I removed the old radiator, which was looking a bit worse for wear
https://i4.photobucket.com/albums/y118/Wonderboy_001/IMG_0073.jpg
https://i4.photobucket.com/albums/y118/Wonderboy_001/IMG_0070.jpg
https://i4.photobucket.com/albums/y118/Wonderboy_001/IMG_0071.jpg
I then fitted the much better looking radiator
I didn't take any pictures of it fitted to the bike, but you get the idea!
I then set about putting everything back together, but I've left all the side and rear fairing off to make it easier to add my antifreeze later tonight.
PostPosted: 21:27 - 25 Jan 2011    Post subject: Reply with quote
StevenF wrote:
Your bike looks like a transformer. Laughing
Jamie S
PostPosted: 21:42 - 25 Jan 2011    Post subject: Reply with quote
Just a thought, might it be worth getting the bike up to working temp, and MAKE sure the new fan kicks in, it might appear in good condition, but may well not work/be faulty.
You don't want to find the fan to be nackerd on a hot day ! Shocked
Jamie
StevenF
PostPosted: 22:39 - 25 Jan 2011    Post subject: Reply with quote
@Chis - Aha, I see what you mean Cool
Jamie - Good idea. Just came in from the garage just now after putting the new fluid in, but it's a bit late to be running the bike. I'll get out tomorrow and just let it idle for about 10 minutes, hopefully that should be enough for the fan to kick in!
There is a gap of 1 year, 114 days between these two posts...
StevenF
PostPosted: 17:52 - 19 May 2012    Post subject: Cleaned and Stripped Callipers Reply with quote
So I thought I would update this with some more progress on the bike! It's currently off the road with no tax, MOT or insurance. Although, that's going to change soon!
When the bike was last on the road, I was having problems with the back brake; it was almost non existent and I had no feel through the pedal. So I decided to strip and clean the brakes.
First challenge was to get the pistons out. I had a dry system so couldn't use fluid to push then out. I resorted to using a car/tyre pump, was a pain in the arse and it took forever. Trying to get a good sealed air connection was a nightmare. Anyway eventually took the first piston out and gave it a little clean:
https://i4.photobucket.com/albums/y118/Wonderboy_001/7d891cf2.jpg
https://i4.photobucket.com/albums/y118/Wonderboy_001/d4b9a557.jpg
Taada!
Took the slider pin out of the rear calliper, needed a bit of a clean!
https://i4.photobucket.com/albums/y118/Wonderboy_001/3ea53996.jpg
https://i4.photobucket.com/albums/y118/Wonderboy_001/504aaeff.jpg
Took all the seals off and cleaned behind them
https://i4.photobucket.com/albums/y118/Wonderboy_001/19e03712.jpg
This was was a bit of a mess!
https://i4.photobucket.com/albums/y118/Wonderboy_001/c219fe49.jpg
After a clean
https://i4.photobucket.com/albums/y118/Wonderboy_001/aa8fba1f.jpg
There was also a chip out of this one, but it didn't seem to be leaking before so should be ok.
Also cleaned the sliders
https://i4.photobucket.com/albums/y118/Wonderboy_001/cf82aa9a.jpg
https://i4.photobucket.com/albums/y118/Wonderboy_001/e572ab06.jpg
Everything went well for a change! Nothing broken (unheard of) Smile I need to get done red rubber grease before re-assembling everything.
I'm collecting my calliper bolt (snapped it a few months ago) from Honda tomorrow and I'll try pick up a new pad pin as one of them has started to round which makes it a pain in the arse to get out!
StevenF
PostPosted: 17:55 - 19 May 2012    Post subject: Reply with quote
And an updated picture:
https://i4.photobucket.com/albums/y118/Wonderboy_001/1ec12aab.jpg
I really enjoy tinkering about with the bike and learning new things (mechanically) as I've never done anything like this before.
Any ideas to what else I could do on the bike to keep me busy?
Oh lastly, what's everyone's opinions on the stickers? (more visible on the top pictures) Not sure whether to remove them or not.
Nick 50
PostPosted: 18:04 - 19 May 2012    Post subject: Reply with quote
The stickers don't look that bad to be honest.
As for tinkering..........
How about the back end?? Swing arm off, check rear suspension. Give it all a good detailing especially round the front sprocket, my CBR was horrendous round the front sprocket.
Quick question, how did you clean the brake pistons? Reason I ask, is they look "gold'ish" coloured, is that a protective coating?
I get a bit obsessive when cleaning and on the GZ took the coatings of lots of stuff which started rusting. Had to get them recoated Embarassed
StevenF
PostPosted: 18:15 - 19 May 2012    Post subject: Reply with quote
That sounds like a big job taking the swing arm off etc! Don't really know what condition the rear suspension is in so it could be worth while. Just don't want to bite off more than I can chew and end up having to take it to a garage!
I cleaned them using a green scourer pad and some very fine sand paper. Is that ok? Embarassed
https://i4.photobucket.com/albums/y118/Wonderboy_001/c51e8716.jpg
You can see the bit I've cleaned as I have taken off some of the gold, which I now know (from you) is a protective coating Embarassed
Harley
PostPosted: 12:23 - 20 May 2012    Post subject: Reply with quote
What type of paint did you use on the forks? mine have the same kinda corrosion and I was wandering what you used to get such a nice finish?
StevenF
PostPosted: 12:48 - 20 May 2012    Post subject: Reply with quote
Just some Hammerite Black metal paint and a pain brush!
Drove to my local (15miles) Honda dealer today to pick up my brake capplier bolt and a pad pin, only to find it's closed on Sundays! Doh.
TUG
PostPosted: 15:11 - 20 May 2012    Post subject: Reply with quote
Steven, Dont go too mad with the green pube pads Laughing make sure you clean out the grooves where the seals fit too. Thumbs Up
Haz ER-5, innit!
StevenF
PostPosted: 18:38 - 20 May 2012    Post subject: Reply with quote
Haha - I suppose that's another name for them! I gave all the groves a good clean, they were full of crystallised material which was like salt. Coated the seals in fluid and popped them back in! I ordered some red rubber grease today, so once that comes I'll re-fit everything.
Thinking of replacing my fork seals as one of my stanchions has a slight oil haze around it. Hopefully should be able to tackle that without getting into too much bother!
There is a gap of 251 days between these two posts...
StevenF
PostPosted: 19:21 - 26 Jan 2013    Post subject: Update Reply with quote
So rather sadly the bike hasn't left the garage since the last update! I've decided there's no point in the old girl sitting in the garage all year, so I've decided to start prepping it for spring.
I left the Calipers sitting out with the bleed nipples off and this caused the brake fluid around the caliper to crystallise
https://i4.photobucket.com/albums/y118/Wonderboy_001/05925C38-B7BA-48AA-8262-76DC4DA968A8-1410-000001A48D5109ED.jpg
Fearing that the seals would be covered in the same gunk, I've have decided to strip the calipers again to give them a good and proper clean. I have orders a set of piston pliers (hopefully they will do the trick) and a 100mm syringe to reverse bleed the brakes. Updates to come shortly!
StevenF
PostPosted: 19:26 - 26 Jan 2013    Post subject: Valve Clearances Reply with quote
The bike has done just over 30k miles and I'm not sure if the valve clearances have ever been checked! I decided to tackle this milestone today!
I removed the side and rear fairings, fuel tank, air box and housing and the HT leads and control box (not sure what its called).
Air filter looks brand new even though i've owned the bike for 2 years and never changed it.
https://i4.photobucket.com/albums/y118/Wonderboy_001/83A264DC-FD42-4018-B5B5-BCB0A2DF4823-343-00000043883752BA.jpg
https://i4.photobucket.com/albums/y118/Wonderboy_001/070F7D02-D5F6-42FE-94E4-E6A43BFD0954-343-000000438FFDF3C3.jpg
And how it stands
https://i4.photobucket.com/albums/y118/Wonderboy_001/A514B238-9E20-4090-B388-EC37C95FBB06-343-00000043A0E652BD.jpg
I'm a little unsure of what to so next, so hopefully with a little help from forum members ill get there!
StevenF
PostPosted: 23:54 - 26 Jan 2013    Post subject: To Do List... Reply with quote
What's still to be done and buy
Check valves and adjust as necessary
Flush + change coolant
Oil + filter change
New cam chain tensioner
Double bubble screen
Strip and re-build calipers
Change bulb dials
Charge Battery
Inspect chain + sprockets
Not much then Rolling Eyes
StevenF
PostPosted: 21:37 - 27 Jan 2013    Post subject: Reply with quote
Set about stripping the bike further today:
https://i4.photobucket.com/albums/y118/Wonderboy_001/5AF6973C-0748-4893-B9A1-9943A23702D0-343-000000D12541C457.jpg
https://i4.photobucket.com/albums/y118/Wonderboy_001/6DD6E827-FCC5-4263-89E9-6095C5A918FA-343-000000D11DBEE94A.jpg
and eventually got the cam cover off:
https://i4.photobucket.com/albums/y118/Wonderboy_001/765BCD11-B5F9-45D7-90B1-6E96401F243A-343-000000D13608C648.jpg
Measured all my valve clearances
https://i4.photobucket.com/albums/y118/Wonderboy_001/DB2ACAEE-02BB-441F-8FD0-4ADD657EAE27-343-000000CE85E3A6F0.jpg
As you can see surprisingly most of them are on the limit and only two are out by 0.01mm bellow the tolerance. I'm not sure whether I should go ahead and change the shims or leave it another 8k miles.
Kind of left it like that for tonight. Purchased some Anti-Freeze today so that's maybe the next job.
PostPosted: 11:14 - 28 Jan 2013    Post subject: Reply with quote
Why wouldn't you sort them? Do the lot IMO. You have it apart and know the sizes you need. Once done you won't need to touch it again for several thousand miles. Is it shims out lock nuts?
stonesie
PostPosted: 11:18 - 28 Jan 2013    Post subject: Reply with quote
They look like Shim-under-bucket, get them all to the slack end of the tolerance and they should be fine for a good while.
Edit
It's a job I keep putting off on mine but it needs doing, one handy tool I need to go and buy is a magnet on a stick (pick up tool) it will keep the shim stuck in the bucket.. Dropping the shim into the engine could be bad depending where it settled.
PostPosted: 11:21 - 28 Jan 2013    Post subject: Reply with quote
+1 it'd be silly to put it all back together, as if you left it for a while you'd need to re open it up measure again then order the right shims.
StevenF
PostPosted: 12:26 - 28 Jan 2013    Post subject: Reply with quote
Because they are the lowest tolerance I thought they would be ok. Someone suggested they should be fine for another 8k miles.
Stonesie- they are shim under bucket style, I got one of those tools from Halfords yesterday for £3.50 and it has a little torch at the end.
So you both think it would be better to do now? In that case ALL of them would probably need done, any idea what sort of price I'd be looking at for a full set of shims?
What effect do the valve clearances actual have on the ride if they're out?
PostPosted: 13:28 - 28 Jan 2013    Post subject: Reply with quote
Low tolerance is bad, they usually tighten up not loosen, AFAIK.
It probably would be 'fine' for another 8k but you would have to do it then anyway. Like I said you would only have to take it apart and re measure everything then order the shims and wait etc. just do it now while it is apart. Set all of them toward the looser end of the tolerance IMO.
Edit: affect on the ride,
Loose - lower performance
Tight - over heating and damge to the valve train.
Jefr0
PostPosted: 16:12 - 28 Jan 2013    Post subject: Reply with quote
Interesting little project you got going on.
Nice colour scheme Razz
I'd be interested to know if you went by a guide or Haynes for the valve clearences? Also, what do you need to take to get off to get to them? I've got new spark plugs to go in mine also.
Where would you get new shims from, shops wise so you don't have to wait days for delivery on net?
I'll be keeping an eye on when you do the cam chain tensioner too, I'll be needing to do mine.
I suffered the same with the brakes, rebuilt them and they're fine now Thumbs Up
What's your battery like? I think I need to invest in a motobatt, but going to do the valve clearances/spark plugs first (not touched in at least 6 years!)
Rides: Honda XR 125 ('03) Honda CBR 600F ('91), Ducati 916 Biposto ('95)
The last post was made 13 years, 293 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 1.06 - MySQL Queries: 13 - Page Size: 143.71 Kb
