Some more Maths + Matlab/Wolfram Alpha queries
Nick 50
PostPosted: 12:21 - 03 Feb 2013    Post subject: Some more Maths + Matlab/Wolfram Alpha queries Reply with quote
Firstly, could someone confirm I have got the correct answer please?
It's a 2nd Order Differential Equation with Resonance.
https://i300.photobucket.com/albums/nn6/ElScampio/BCFmaths1_zpsed1d87d0.png
https://i300.photobucket.com/albums/nn6/ElScampio/BCFmaths2_zps41b148e4.png
https://i300.photobucket.com/albums/nn6/ElScampio/BCFmaths3_zps86570270.png
I did try Wolfram Alpha which gave me an answer of:
https://i300.photobucket.com/albums/nn6/ElScampio/BCFWA_zpsf40ab561.png
Shocked ermmmmmm ok.
Secondly, can Matlab solve forced 2nd ODE's? If so, what do you input?
Most importantly I checked:
Is_the_answer_Potato.com And it said the answer is definitely NOT Potato.
el_oso
PostPosted: 16:59 - 03 Feb 2013    Post subject: Reply with quote
MATLAB will not be able to solve the equation exactly (as far as I'm aware)
you can however use ODE45, which is a fourth order Runge-Kutta method to solve it. Google the documentation on it. It's pretty well documented and easy to implement in MATLAB as long as you know how to reduce that equation into separate matrices. The 4th Order RK4 method is reasonably accurate.
How you would check if your solution is indeed the right solution is to plot a graph using ODE45 against your result
Duke 390
Car: Jeep Wrangler 4.0L
Nick 50
PostPosted: 18:15 - 03 Feb 2013    Post subject: Reply with quote
Thanks the_godfather. I've never really used Matlab to try and solve ODE's before. I will hunt around for info on ODE45 command. Thanks Thumbs Up
el_oso
PostPosted: 21:31 - 03 Feb 2013    Post subject: Reply with quote
It is pretty well documented. If you have done programming before and are comfortable/capable of reducing that equation into several linear equations then it is very straight forward.
for example:
https://cdn.bikechatforums.com/files/codecogseqn__2_.gif
and using the substitution for dy/dt
https://cdn.bikechatforums.com/files/codecogseqn__1_.gif
and then solve the 2 equations simultaneously
Duke 390
lihp
PostPosted: 21:19 - 04 Feb 2013    Post subject: Reply with quote
Sorry, but how do you get your formula like that?
What software generates those images?
Nick 50
PostPosted: 21:33 - 04 Feb 2013    Post subject: Reply with quote
Me or the_godfather? If you are referring to mine, I done it on MS Word 2010.
lihp
PostPosted: 21:36 - 04 Feb 2013    Post subject: Reply with quote
the_godfather, seen a couple of people do it recently in the same format.
I only use Word 2003, so I don't think I could do it your way, it seems it was only added in 2007?
The maths side of my course is handwritten, but annoyingly, assignments are submitted electronically, and all typed for the Mech Engineering side, and thought it would be a nice way of laying out the math.
el_oso
PostPosted: 22:44 - 04 Feb 2013    Post subject: Reply with quote
That is done using an online latex editor. google laTex editor and there will be a plethora or results.
you can use word 2003. it called equation editor. Again, there is loads of documentation on it.
clicky for instructions on how to open equation editor in word 2003.
in equation editor when you want to insert special characters such as Psi, you can put the / before it. i.e.
Code:
h^2 /2m \nabla^2 \Psi^2 (r) + V(r) \Psi(r) = E \Psi
gives the familiar time independent Schrodinger equation in 3D spherical coordinates with a position dependent electric field
https://cdn.bikechatforums.com/files/codecogseqn_559.gif
EDIT: missed an extra (r) off the last Psi, cbb to change it
Duke 390
The last post was made 12 years, 363 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> The Geek Zone All times are GMT
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.47 - MySQL Queries: 13 - Page Size: 57.55 Kb
