help with running of honda cg 125
jimbob005
PostPosted: 17:03 - 29 Jan 2013    Post subject: help with running of honda cg 125 Reply with quote
hi all,
I hope some one can help me ... I have a honda cg 125 kb 1981 6 volt system , now iv changed the spark plug and cap the tank and carb have been off and cleaned replaced the heat gard for the carb all paper gaskets replaced .
This is what iv done now its being an ass to start ( think this is down to the card setup )
When running it will run for around 2 mins and cut out iv uploaded a video to youtube
https://www.youtube.com/watch?v=HbXLBpY-lU8&feature=youtu.be
any help thanks james
jimbob005
PostPosted: 17:09 - 29 Jan 2013    Post subject: Reply with quote
one more thing the bike has not been on the road for 3 months if this helps
Cyclingbiker
PostPosted: 18:04 - 29 Jan 2013    Post subject: Reply with quote
If it helps my Haynes manual for the CG says that the possible causes for the engine dying after running for a short while is:
#1 - Blocked air hole in the fuel filler cap. If it is blocked it could possibly cause a vacuum effect in the tank that prevents any more fuel from flowing to the carb. Probably a good way to see if this is the issue just run the bike for a while with the fuel cap removed to see if the same problem occurs. If it is that I'd just blow some air through the hole to make sure it is unblocked.
or
#2 - Dirt or water in the carb. There could be some crap in the float bowl or even in the tank itself that is getting dragged through and killing the engine. It wouldn't surprise me if like you said the bike had been stood for a few months. Clean the carb out, clear the jets and maybe consider getting some fresh fuel in there. Also check the tank for rust and other crap floating around as that will not help things if they get pulled through the system. Maybe the fuel filter in the petrol tap is getting blocked so give that a clean just to be sure.
Also one more thing, check the air filter and the idle settings as that could play a part.
I did have this problem on my BR-J a couple of months back, it would die after a few minutes idling, which was pain if I was sat waiting in traffic and I'd have to kickstart the bugger ASAP to get going again. I just twiddled with the idle settings until I was happy and chucked some Redex in the tank to see if that would help and so far I have been fine.
HTH Thumbs Up
Honda CB500s (1999) - Honda CG 125 BR-J (1991)
Mod 1 - Passed - 12/11/12 --- Mod 2 - Passed - 26/11/12
jimbob005
PostPosted: 18:52 - 29 Jan 2013    Post subject: Reply with quote
thanks for that
forgot to say its has fresh fuel and iv put an inline fuel filter and this is all ways full when it cuts out .
im trying to test the valve gaps but having a bit of truble getting the side off i will do this tomorrow
TheSmiler
PostPosted: 19:14 - 29 Jan 2013    Post subject: Reply with quote
jimbob005 wrote:
thanks for that
Have you tried running it without the inline fuel filter to see if it behaves any better Question
jimbob005
PostPosted: 19:18 - 29 Jan 2013    Post subject: Reply with quote
TheSmiler wrote:
jimbob005 wrote:
thanks for that
No i will try this i will have to go and get some more fuel line
TheSmiler
PostPosted: 19:33 - 29 Jan 2013    Post subject: Reply with quote
Would be worth checking out and always handy to have some fuel line encase yours splits, have you also checked the valve clearances Question
jimbob005
PostPosted: 15:12 - 03 Feb 2013    Post subject: Reply with quote
Hi all ,
thanks for the reply's.. its still playing up .. today i done an oil change
https://i154.photobucket.com/albums/s267/jimbob005/Photo0025_zps5803d740.jpg
found some shiny bits in the oil
how bad is this?
thanks james
jimbob005
PostPosted: 16:24 - 15 Feb 2013    Post subject: Reply with quote
Hi all
First off thanks for the replys . Second iv sorted it , I started looking at the bike the other day after trying the things that have been added to this topic none of it work then i tested the spark and it become week.
So i was taking off the side to test the points and when the side was off it had a lot of fur on the eletrics so iv cleaned it all off and now every thing is work as it should
well thanks for all your help
The last post was made 12 years, 356 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 67.13 Kb
