Resistors and load ratings
StormCrow
PostPosted: 01:13 - 05 Feb 2013    Post subject: Resistors and load ratings Reply with quote
Hi guys
Bit of a basic question for anyone in the know, but I'm not, so here goes.
I'm replacing four 5w 501 bulbs in one of the cars with 1w LEDs.
Unfortunately, I need to wire a resistor in to the circuit to stop the bulb warning lamp being illuminated.
Bear with me - correct me if I'm wrong:
4*5w = 20w 'normal' draw
4*1w = 4w draw with new bulbs
Need to simulate 16w of draw.
Now here is where my knowledge of electronics gets a bit hazy - can I just fit a 16w resistor (which presumably would be fucking massive?) or am I looking at a 10ohm resistor?
oldpink
PostPosted: 01:54 - 05 Feb 2013    Post subject: Reply with quote
V= I x R or any variation of the formula
https://people.usd.edu/~schieber/psyc770/resistors/ohms4beginner.html
look at the 3rd example "Let's say a friend asks you to fit a red warning light into the dashboard of his/her car"
same maths
cimbian
PostPosted: 09:02 - 05 Feb 2013    Post subject: Reply with quote
You will need to know the current drawn by your LEDs and the voltage dropped across them (probably have built-in current limiting resistors so will likely be battery voltage)
Deduct the current drawn from the overall current in your 16W circuit and it is that current you need to shunt through your parallel load resistor.
Use the info on the page OldPink posted and you will find the answer.
Post what you calculate on here if you want someone to check your workings before spend dosh. Smile
22PlusY
Current: Moto Guzzi 1100 Breva. Previous: Honda XL650V TransAlp
Bearded, Balding, Born again Buddhist Biker
PostPosted: 09:54 - 05 Feb 2013    Post subject: Reply with quote
This is what electrical tape was invented for: covering unwanted warning lamp bulbs.
Islander
PostPosted: 11:51 - 05 Feb 2013    Post subject: Reply with quote
A 10 ohm resistor will draw 1.2A giving you a tad over 14W which should be sufficient to do the job. It'll need to go in parallel with the existing loads. I'd use a 20W type to give you some headroom and remember it'll get hot so you'll need to be careful where you physically place it.
ETA
It might be easier to fit four resistors, one in parallel with each of the LEDs. In which case you'd need 4 x 33 ohm resistors or you could use 39 ohm resistors. Either would need to be rated at 5W minimum and again would need careful placement as they'll get hot. Thumbs Up
oldpink
PostPosted: 13:14 - 05 Feb 2013    Post subject: Reply with quote
this type is good for heat dissipation
https://meniscusaudio.com/images/10R1.jpg
Islander
PostPosted: 13:39 - 05 Feb 2013    Post subject: Reply with quote
Yep wirewound ceramics are good, easy to find and also nice and cheap. Thumbs Up
This type is more expensive but can be fixed to a bulkhead easily - you can even use a smear of heatsink compound under it to help with dissipation.
https://i01.i.aliimg.com/wsphoto/v0/674625655/10pcs-6-Ohm-6R-50W-Watt-Power-Metal-Shell-Case-font-b-Wirewound-b-font-font.jpg
cimbian
PostPosted: 14:32 - 05 Feb 2013    Post subject: Reply with quote
Given away the answers.. life it just too easy. Wink
22PlusY
PostPosted: 14:41 - 05 Feb 2013    Post subject: Reply with quote
Why not just get a flasher unit to suit? Might be more expensive but Will be much neater.
Islander
PostPosted: 15:42 - 05 Feb 2013    Post subject: Reply with quote
I don't think it's for indicators. They use 21W bulbs not 5W. Wink
PostPosted: 15:56 - 05 Feb 2013    Post subject: Reply with quote
Sorry I read indicators at some point Thumbs Up
smegballs
PostPosted: 17:30 - 05 Feb 2013    Post subject: Reply with quote
Lets say you get two of these in parallel: https://spiratronics.com/10w-alum-clad-wirewound-resistor-22r.html
That will give you a resistance of 11 Ohms.
Assuming a voltage of 12V
I = V/R = 12/11 = 1.09 A
P = V x I = 12 x 1.09 = 13W
Assuming a Voltage of 13.5V
I = V/R = 13.5/11 = 1.22 A
P = V x I = 13.5 x 1.22 = 16.5W
So you should be looking at the right kind of ballpark figure. The problem with a resistive load, as shown is that the actual power drawn varies with the voltage.
In any case, the power rating is being shared by two equal value 10W resistors in parallel. This means they both share the current which means the total allowable power is 20W. So with normal battery voltages you should be well within safe limits.
The last post was made 12 years, 359 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> The Geek Zone All times are GMT
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.99 - MySQL Queries: 13 - Page Size: 74.99 Kb
