Working out CC of your bike
Bike Bunker
PostPosted: 19:59 - 05 Feb 2013    Post subject: Working out CC of your bike Reply with quote
Just going to post a few Formulae that people may find interesting or even useful Idea
Hope a few people maybe find this helpful or even interesting please pm if ive made any mistakes or feel free to post your own formulae
Thanks!
Arrow Working out the volume of a cylinder
Arrow Formula - H(height) x R(radius) x R(radius) x Pi(3.14)
Height is simply the height of the cylinder from BDC to TDC (Top Dead Centre and Bottom Dead Centre
Radius is found by measuring the diameter of the cylinder and simply halving it
Arrow Example:
ZXR400- Diameter or Bore =57mm Height or Stroke =39mm
PLEASE NOTE Exclamation Engines are measured in CC3 (centimetres cubed) not MMC (millimetres cubed) so always convert to CM before starting any formula's
So take the formula input our measurements and get -
3.9 x 2.85 x 2.85 x 3.14 = 99.46135
The 2.85 comes from the diameter or bore which is 57mm converted to 5.7cm then divided by two as we need radius not diameter
Arrow Working out the CC of a engine
Arrow Formula - B x B x 0.7845 x S x N
B is Bore or Diameter of the cylinder
0.7845 is a constant and is not change regardless of bike or size.
S is stroke or height of cylinder
N is Number of cylinders
Arrow Example:
ZXR400
input the measurements into the formula;
5.7 x 5.7 x 0.7845 x 3.9 x 4
=398.0752776 cc simplified to 398cc or 400cc
Please note! an R1 is not 1000cc a zx6r is not 600cc and a aprilia rs 125 is not 125cc but it will be very close.
There are ways to work out your compression ratio but you need to find the clearance volume which is not as readily available for some bikes but for those who are lucky enough to be able to work it out or find it Idea
Arrow Working out the compression ratio
Arrow Forumla - Pi x R x R x H=A then... A/CV
the ration is always too 1 so 6:1 or 7:1 it should never be 3:2 or 6:5
pi=3.14
R=Radius
H= Height
CV= clearance volume
Arrow Example
Please note in this case we convert everything to Cm and not MM
a bike with a 60mm bore 70mm cylinder height and clearance volume of 18 cc goes like;
3.12 x 3 3 x 7 =197.82/18=10.99 ration 10.99:1
(these figures was just pulled out of the sky and do not represent an actual bike)
P.s If you read all that bloody well done Mr. Green
Ariel Badger
PostPosted: 20:07 - 05 Feb 2013    Post subject: Reply with quote
So how do you calculate CV?
Slacker24seve...
PostPosted: 20:13 - 05 Feb 2013    Post subject: Reply with quote
As if you know what any of those big words mean.
Banger rallies are ace
Timmeh
PostPosted: 20:20 - 05 Feb 2013    Post subject: Reply with quote
To be honest, to work out CC, bore, stroke or compression ratios I just tend to read the manual.
Karma
keggyhander
PostPosted: 20:26 - 05 Feb 2013    Post subject: Reply with quote
The CC is printed plain as day on the V5.
JiveBunny This post is not being displayed because the poster is banned. Unhide this post / all posts.
Nick_Giles
PostPosted: 20:42 - 05 Feb 2013    Post subject: Reply with quote
JiveBunny wrote:
"Arrow Or simply look at the V5 document. "
But he 'suspects' it has had a 'big-bore' kit fitted and the CC stamp ground off so as not to visually offend his local 'Rozzers' Wink Wink Wink
Nick Twisted Evil
Bike Bunker
PostPosted: 20:55 - 05 Feb 2013    Post subject: Reply with quote
.wrthsth
Bike Bunker
PostPosted: 20:56 - 05 Feb 2013    Post subject: Reply with quote
too be honest i dont know other than measuring it because its obviously a very unusual shape. do you know would be great if you did ?
Bike Bunker
PostPosted: 20:58 - 05 Feb 2013    Post subject: Reply with quote
Study bikes at college Thumbs Up
Slacker24seve...
PostPosted: 21:06 - 05 Feb 2013    Post subject: Reply with quote
This thread:
https://www.bikechatforums.com/viewtopic.php?p=3408993&highlight=#3408993
...and many others would suggest you need to study harder.
Bike Bunker
PostPosted: 21:09 - 05 Feb 2013    Post subject: Reply with quote
lmfao ive done alot to the bike since then and havnt updated , also the bike got so bad due to doing around 1+k miles everymonth no fail with no limits due to weather
Ariel Badger
PostPosted: 21:22 - 05 Feb 2013    Post subject: Reply with quote
I do know and have done it many times. You remove the sparking plug and take the engine to TDC on the comp stroke and use a Burrette to fill the combustion chamber with oil and take a reading.
johnsmith222
PostPosted: 21:30 - 05 Feb 2013    Post subject: Reply with quote
Out of interest, how do you figure it out from filling it at TDC?
wilz1234
PostPosted: 21:32 - 05 Feb 2013    Post subject: Reply with quote
If you know the swept volume (SV) and the compression ratio (CR), then it's simples:
CR=V1/V2
Where
V1=total volume (SV+CV)
V2=chamber volume (CV)
CR = (CV+SV)/CV
CV*CR=CV+SV
CV(CR-1)=SV
CV=SV/(CR-1)
Chamber volume= Swept volume / compression ratio minus 1
RS50 - ZXR400 - ZXR 400 - ZX7R - Bandit 600 - NTV 650
Bike Bunker
PostPosted: 21:34 - 05 Feb 2013    Post subject: Reply with quote
ahh makes perfect sense cheers
Ariel Badger
PostPosted: 21:35 - 05 Feb 2013    Post subject: Reply with quote
In his calculation he was trying to calculate CR so it is not known.
Bike Bunker
because its all the space upwards of TDC?
PostPosted: 21:38 - 05 Feb 2013    Post subject: Reply with quote
Bike Bunker wrote:
its actually for older bikes which wont always have the numbers stamped on, also its just work i done at college today Smile plus a v5 doesn't give you the cc to a decimal Smile
Anyone who actually needed to know this to a level more accurate than that stamped on the cylinder or on the v5 would probably be capable of working out the volume of a cylinder anyway, so who really is your target audience?
johnsmith222
PostPosted: 21:39 - 05 Feb 2013    Post subject: Reply with quote
Thanks Ariel, I got you now Thumbs Up
Bike Bunker
The Shaggy D.A. wrote:
Anyone who actually needed to know this to a level more accurate that that stamped on the cylinder or on the v5 would probably be capable of working out the volume of a cylinder anyway, so who really is your target audience?
Very true! well i was just revising over everything to work out engine size's knock on effects different things will have and was jotting it down on the mac decided to post some bits.
PostPosted: 21:41 - 05 Feb 2013    Post subject: Reply with quote
Ah, a Mac user. 'Nuff said Smile
Bike Bunker
PostPosted: 21:42 - 05 Feb 2013    Post subject: Reply with quote
aha when you can claim tax back get business discounts and a shit load of free software a mac for pennies becomes reasonable
Bike Bunker
PostPosted: 21:44 - 05 Feb 2013    Post subject: Reply with quote
CR=V1/V2
Where
CR = (CV+SV)/CV
CV*CR=CV+SV
CV(CR-1)=SV
CV=SV/(CR-1)
i was trying to show how to work out the Comp Ratio but yeah you right aha. i cant post without bad karma anymore it seems though.
The last post was made 13 years, 268 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.17 Sec - Server Load: 0.85 - MySQL Queries: 13 - Page Size: 136.81 Kb
