Honda CBF 125 smoking.
moley101
PostPosted: 22:28 - 05 Feb 2013    Post subject: Honda CBF 125 smoking. Reply with quote
Hi Im new to this forum, after being away from bikes for the last 15 years and being my last bike was a Suzuki GP125 I have recently brought and 2009 honda cbf 125 privately.
Just wondering if anyone has any ideas, the bike runs really well no idling issues and will do 65 mph ok, but at low rpm while riding (normally pulling away) the bike smokes and burns a little oil.
now I was used to an old 2 stroke needing and burning oil but did not expect this to be the case with a 4 stroke.
The bike itself like i say runs well no rattle type noises and pulls as i would expect a 125 to do.
Any help or ideas would grateful.
Thanks Again All.
lukamon
PostPosted: 23:12 - 05 Feb 2013    Post subject: Reply with quote
whats the milage?
killa wrote: Im an ass man myself
moley101
PostPosted: 23:27 - 05 Feb 2013    Post subject: Reply with quote
13000 miles mot done in november no issue on that and serviced by a local motorcycle shop 300 miles ago with a report on smoking but recommendation adjusting valves, done this but with no improvement.
lukamon
PostPosted: 23:31 - 05 Feb 2013    Post subject: Reply with quote
reeks of being thrashed / siezed. i'd take the head off and put some new rings on the piston Thumbs Up
edit: out of interest, what condition? how much?
toshpot
PostPosted: 23:42 - 05 Feb 2013    Post subject: Reply with quote
I'm no pro, by any stretch of the imagination, but have you checked your oil? has it been overfilled at all?
I've come across oil in the airbox before, due to overfilling.
Sometimes, I touch myself and smell my fingers.
evoboy
PostPosted: 23:52 - 05 Feb 2013    Post subject: Reply with quote
Scored barrel.
Been ran low on oil.
Would'nt be the first one.
APT Motorcycles
uberkron
PostPosted: 02:28 - 06 Feb 2013    Post subject: Reply with quote
gp125, awesome introduction to bikes. I had one, the fun ended when I had to hold it in fifth gear.
As for your four smoker, normally the head holds oil longer than the bore so take out the plug and shine a torch in there.
i ride a zip 50 2smoke. It overtakes a hundred times a day.
PostPosted: 11:18 - 06 Feb 2013    Post subject: Reply with quote
evoboy wrote:
Scored barrel.
Works at a Honda dealership, so can truthfully say "They all do that, mister. Then they seize."
stevo as b4
PostPosted: 12:25 - 06 Feb 2013    Post subject: Reply with quote
if it sounds ok, and is doing 65mph, then i'd be checking the oil every other day, and topping up as required. If it's not using too much oil i'd say 0.5l per 500-600miles, then id just leave it well alone and top it up.
you'll be changing the oil anyway every 1000miles, and cleaning the strainer gauze out if you've got sense and mechanical sympathy that is.
Other than that just ride it and ride it hard, you should get 30'000+ miles out of a Honda 125 before needing to do any engine work, and some have done alot more, it's down to maintainence and frequent oil changes.
PostPosted: 13:16 - 06 Feb 2013    Post subject: Reply with quote
The recommended oil change interval on the CBF is 2,500 miles. Which is demonstrably too much, admittedly.
Honda's marketing department thanks you for your faith.
It's an "HMSI Stunner" made for the Indian domestic market, and they clearly have some quality control issues with it.
stevo as b4
PostPosted: 13:40 - 06 Feb 2013    Post subject: Reply with quote
I take it that it's about 1/10th as robust as a Brazilian CG125 then?
The CG and XLR125's are where most of my 4stroke 125 experiences come from. My mate's 91J CG was up to 38'000 when it finally chewed up a LHS main bearing. It still ran though, and i think he forgot the 1000mile oil change rule about 3-4times in a row, so it was a sturdy enough motor in my mind.
neil.
PostPosted: 20:10 - 06 Feb 2013    Post subject: Reply with quote
You really must check the oil strainer behind the clutch cover as these love to clog up with clutch friction material fluff amongst all else, starving the top end of oil. I'd say I top up around 50ml every 600-ish miles, been that way since very early on in the bike's life. Just ticked over 21'500 miles. These CBFs are a really poor successor to the CG. You can't run the engine on sludge, in fact you need to service it to the letter and the rust issues some people have had are terrible. Then there's the fuel pump kangaroo issue. You can tell they're built to a price. I still like mine though, it's cheap and easy to work on and fantastic on fuel at 130mpg.
lukamon
PostPosted: 23:59 - 06 Feb 2013    Post subject: Reply with quote
how often do you guys clean the centri oil filter? mine is just under a year old and about to roll over 5k. changed the oil every 1k from the start Smile
neil.
PostPosted: 06:50 - 07 Feb 2013    Post subject: Reply with quote
Never, judging by reports it doesn't get significantly dirty (a bit of sludge that will fit on the end of your thumb) and the screws on mine are bastard tight so I gave up trying. The strainer is the one to watch - first time I did mine at 7.5k it was filthy. No harm in checking it earlier and if you're lucky with the screws, no harm in checking the centrifugal filter but I don't think it's worth it unless you're rebuilding a shagged engine where swarf etc will have been circulating around it.
mudcow007
PostPosted: 09:29 - 07 Feb 2013    Post subject: Reply with quote
the centrifugal on my CG was covered in sludge when i got it - an the screws looked brand new so it doesn't look like its ever been touched...in nearly 30 years?!
lukamon
PostPosted: 17:57 - 07 Feb 2013    Post subject: Reply with quote
cool. might do the screen on mine at the weekend, i'm going to have to order a RHS crankcase gasket right?
neil.
PostPosted: 18:25 - 07 Feb 2013    Post subject: Reply with quote
Yes and a gasket for the centrifugal filter if you decide to do it too.
moley101
PostPosted: 22:36 - 06 Mar 2013    Post subject: Reply with quote
Hi all thanks for all the responces.
A local bike shop has had the bike apart and an oil seal at the bottom of the piston was twisted, rings and bore marked due low compression as a result.
They will be putting back together tomorrow so hope to be back on the road by the weekend.
Thanks to the guys at SAS Custom Bikes.
lukamon
PostPosted: 23:00 - 06 Mar 2013    Post subject: Reply with quote
sounds good Smile how much are they charging you?
i cleaned the strainer on mine. it was fair covered in crap at 5k. couldnt get the spinner cover off though.
The last post was made 12 years, 362 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 110.36 Kb
