Zen cart & ssl
Marmalade
PostPosted: 12:06 - 09 Feb 2013    Post subject: Zen cart & ssl Reply with quote
Does anyone have any history of using zen cart?
I've installed the cart onto a site and the store front is showing but the admin login page doesn't show. I think it might be something to do with the ssl certs which I do have installed but not sure about changes in the config php files.
Anyone know what they are doing with this?
hellkat
PostPosted: 14:29 - 09 Feb 2013    Post subject: Reply with quote
Nooooooooo idea whatsoever.
I am a total noob.
Yesterday I got something that looked like
https://www.bikechatforums.com/download.php?id=87773
... and I still have NO idea what it means/what to do.
But in the meantime the girl whose website it was gave me some other instructions which meant I got into the back end without all that kerfuffle, I'm worrying that I will come across this again and still have no idea what to do about it.
(at which point I shall prolly pester you guys again... Laughing )
Dalemac
PostPosted: 16:56 - 09 Feb 2013    Post subject: Reply with quote
If it was an invalid SSL certificate it would just throw an SSL error and then load the page using the normal http protocol.
Without getting into the server it would be almost impossible to debug.
Dale
YBR125 -> GPZ500S -> SL1000
Jayy
Mr. Ponzi
PostPosted: 17:35 - 09 Feb 2013    Post subject: Reply with quote
You need to edit your admin url in the config to reflect the SSL address.
i.e. https://www.yoursite.co.uk/admin
Also, did you set forced SSL in the admin area before you installed the certificates?
oldpink
PostPosted: 22:23 - 09 Feb 2013    Post subject: Reply with quote
not used zen
but normally you can log in using FTP and edit the config.ini file(s) to set up your SSL
it will look something like this
define('ENABLE_SSL_CATALOG', 'false');
define('HTTPS_CATALOG_SERVER', 'https://www.yoursite.com');
you may need to define your path to Admin as well in the Config
define('DIR_FS_ADMIN', '/data/web/yoursite.com/www/catalog/admin/');
define('DIR_WS_ADMIN', '/catalog/admin/');
HK you say you got into the back end so it must be installed
its saying you have some issues with paths to info it needs
same as above you may need to edit some config files via FTP to get it to work correctly
and give it the info it needs
Dalemac
PostPosted: 23:45 - 09 Feb 2013    Post subject: Reply with quote
The problem turned out to be file permissions. Marmalade's web host does not allow group write/edit permissions, to which they throw a 500 error!
oldpink
PostPosted: 00:10 - 10 Feb 2013    Post subject: Reply with quote
confused !!
how do you know this info ??
Dalemac
PostPosted: 00:22 - 10 Feb 2013    Post subject: Reply with quote
oldpink wrote:
confused !!
Because i fixed it for him Wink
Dale
oldpink
PostPosted: 00:47 - 10 Feb 2013    Post subject: Reply with quote
oldpink wrote:
confused !!
Dale
so its your site or you have Admin access to the FTP as thats the only way you can change folder permissions Wink
Dalemac
PostPosted: 01:05 - 10 Feb 2013    Post subject: Reply with quote
Yeah, he sent me over hosting details. Its a good job I am trustworthy!
Dale
oldpink
PostPosted: 01:11 - 10 Feb 2013    Post subject: Reply with quote
thats cool then
just one of the advantages of being a BCF member
like on the road bikers look out for each other, the way it should be Thumbs Up
Jayy
Mr. Ponzi
PostPosted: 16:36 - 10 Feb 2013    Post subject: Reply with quote
I've only just seen his PM asking me to take a look, sorry about that but you've had it fixed anyway Thumbs Up
Marmalade
PostPosted: 23:24 - 11 Feb 2013    Post subject: Reply with quote
I did ask a couple of members that had replied, seemed like they knew what they were on about and had a good history.
The site was terrible so there would have been no tears if it had all gone tits.
Turns out Dale did know his way around and sorted it swiftly and didn't demand money with menaces although i did donate a few beer tokens for relieving me of getting thoroughly confused by it all.
Thank you all that offered advice Thumbs Up
The last post was made 13 years, 53 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 78.94 Kb
