| UsernameTaken |
 UsernameTaken Borekit Bruiser
| Fizzer Thou |
 Posted: 16:11 - 11 Feb 2013 Post subject: |
Not silly questions at all.To check to see if the inlet valves are bent,pour something like white spirit or parrafin into the combustion chamber and see if it flows away through leaking valve seats
https://i666.photobucket.com/albums/vv23/WiNot_Rhencullen/Workshop/CIMG2951.jpg
If the bike had been over-revved,it is quite likely that the valves are bent.
As the inlet valves are black,this could be oil or a rich mixture.Check the end gap of the piston rings within the bore and if the valve guide seals have perished. ____________________ Just talk bikes.What else is there?
Always have a 'Plan B' |
| base |
 base Trackday Trickster
| UsernameTaken |
| Fizzer Thou |
 Posted: 16:58 - 11 Feb 2013 Post subject: |
Take the piston rings off the piston,place them within the bore,square them within the bore using the loose piston and measure the gap between the ends of the rings.If they are over a specified limit,or even close to,then hone the bore and install new rings.
If the inlet valves are damaged,they are normally cheaper than the exhaust items.You might get away with just lapping in the new valves and check for leaks again.But if the valve seats are pock-marked,then you might have to have the seats recut if grinding them in does not work.
The Clymer manual https://www.amazon.co.uk/Suzuki-Dr-Z400e-2000-2009-M477-3-Diagrams/dp/1599693631/ref=sr_1_1?s=books&ie=UTF8&qid=1360601829&sr=1-1 is a known good product if you do not already have one. ____________________ Just talk bikes.What else is there?
| UsernameTaken |
| Dr. Quack |
 Dr. Quack Could Be A Chat Bot
 Posted: 20:58 - 12 Feb 2013 Post subject: |
Might be a silly thing to say, but the Mikuni carbs on the SK's are problematic in regards to the needle valve.
Also the seals can be an issue with the keihin carb.
For winter they both need adjusting, especially with older DRZ's.
Mixture screw turned out 1/2 a turn, or a tad more normally helps in winter.
https://www.drz400uk.org/viewtopic.php?f=21&t=4015
https://www.drz400uk.org/viewtopic.php?f=21&t=5210
(Just with you saying it stopped working, and looking at the dirt it looks like and SK or even an E)
Also all models need the manual cam chain tensioner after so long, so just wondering if the cam chain slipped. |
| unitynotsocri... |
 unitynotsocri... Banned
 Posted: 00:17 - 13 Feb 2013 Post subject: |
check the valve guides and valve seals as well,looks mostly healthy although it looks like its been running rich or stuck choke for a while. ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| UsernameTaken |
| UsernameTaken |
 Posted: 18:22 - 14 Feb 2013 Post subject: |
| Nexus Icon |
| woll |
 woll World Chat Champion
 Posted: 21:30 - 14 Feb 2013 Post subject: |
I'm with nexus. They don't look bad at all. Seen hell of a lot worse come out of running tractors. Personally I'd wap new piston and rings in. Change valve stem seals, lap valves in. Check for leakage. If they dont leak jobs a good un. Put back together and hope for teh best ____________________ Current Bike- Suzuki DRZ400 SM K6
Damaged spleen, damaged kindey, 2 popped lungs, 2 broken ribs, broken face, broken wrist and 5 back fractures... remember kids walls hurt |
| UsernameTaken |
| UsernameTaken |
 Posted: 09:37 - 15 Feb 2013 Post subject: |
Just checked the piston rings end gap in the cylinder head and they are both at 0.2mm. Manual says that 0.5mm is the service limit.
So surprise surprise no issues there either
Unless the gap is too small? ____________________ CBT => Passed 23/09/07 Theory => Passed 18/07/08 A2 Test => Passed 30/07/08 |
| P.addy |
 P.addy Formerly known as P.
| UsernameTaken |
| bikenut |
 bikenut World Chat Champion
| P.addy |
| bikenut |
| UsernameTaken |
| UsernameTaken |
| UsernameTaken |
| bladerunner |
| UsernameTaken |
 Posted: 20:33 - 16 Feb 2013 Post subject: |
Thanks for the reply, and explaining the different colours of the valves.
Am replacing as much as possible whilst I have the engine in pieces...
A parcel arrived today with my top end gasket kit.
Could identify all the bits that came apart from these...
https://i460.photobucket.com/albums/qq322/UsernameTaken_01/Newbits_zpsa3e5dfa2.jpg
Are these valve stem seals? ____________________ CBT => Passed 23/09/07 Theory => Passed 18/07/08 A2 Test => Passed 30/07/08 |
| Fizzer Thou |
The last post was made 13 years, 25 days ago. Instead of replying here, would creating a new thread be more useful? |
