Honda hornet 600 HT Lead order??
Lynchasaurus
PostPosted: 16:27 - 14 Feb 2013    Post subject: Honda hornet 600 HT Lead order?? Reply with quote
Just got a hornet 600 and it came in bits and was wondering if anyone had a picture of what order the ht leads go in since everything's hanging out and nothing's numbered?
The ignition coils are still mounted to the frame so that's my only reference point unless there's a better way to figure this out?
Grateful for any positive advice, thanks
P.
PostPosted: 16:42 - 14 Feb 2013    Post subject: Reply with quote
Left ignition coil (closest to left footpeg) does 1 and 4, right hand does 2 and 3.
Just switch them round till it runs sweet.
Lynchasaurus
PostPosted: 16:53 - 14 Feb 2013    Post subject: Reply with quote
Thanks mate, ill give it a go.
It won't even start atm lol
Lynchasaurus
PostPosted: 17:18 - 14 Feb 2013    Post subject: Reply with quote
Where does this go? lol
Nick_Giles
PostPosted: 17:39 - 14 Feb 2013    Post subject: Reply with quote
Its possibly the vacuum pipe. If it is it goes between the carb and the fuel tap on the tank.
Nick.
Casper
PostPosted: 17:41 - 14 Feb 2013    Post subject: Reply with quote
Nick.
Failing that it could just be a breather pipe.
Nick_Giles
PostPosted: 17:45 - 14 Feb 2013    Post subject: Reply with quote
What year Hornet is it.?
I 'think' I have a workshop manual in .pdf format on my PC at work. - Would a copy be of use to you.?
Nick
Lynchasaurus
PostPosted: 17:47 - 14 Feb 2013    Post subject: Reply with quote
Well the vacuum pipe and fuel line are attached to the tank so don't think it's either of them lol Yea it could come in handy mate, thanks
Lynchasaurus
*2001 Hornet
Nick_Giles
PostPosted: 17:53 - 14 Feb 2013    Post subject: Reply with quote
Lynchasaurus wrote:
*2001 Hornet
OK. I will load it onto my 'Dropbox' and send you a link to it. - It will be tomorrow now though.
Nick
Lynchasaurus
PostPosted: 18:31 - 14 Feb 2013    Post subject: Reply with quote
Yea that's no problem, thanks alot
GrumpyGuts
PostPosted: 23:18 - 14 Feb 2013    Post subject: Reply with quote
That looks like the crankcase breather tube. It goes on the top left hand side of the air box.
If not, could it be the fuel tank breather tube? Where does the other end go? If it is not attached to anything but runs down towards the ground, it must be the fuel tank breather hose. (<<< This is my betting...seems the correct size to be this. Breather port is on the right hand side)
If not, it could also be the sub air cleaner tube. That end should connect to the sub air cleaner:
https://i48.tinypic.com/nyvaq9.jpg
My Bikes: Lifan Beat 125cc '11 -> Suzuki B120P '76 -> Suzuki EN 125-2A '08 -> Honda CG 125 '04 -> Honda CB600F Hornet '98 -> Kawasaki ZZR 600 '99 -> Kawasaki GPZ 500S '95 (Current)
Theory test passed - 09/02/2012 >>>> Module 1 passed 24/07/2012 >>>> Module 2 passed 24/10/2012
Casper
PostPosted: 00:57 - 15 Feb 2013    Post subject: Reply with quote
Think you might be wright. It looks like a breather is missing when you look back at the top of the carbs.
MarkJ
PostPosted: 10:07 - 15 Feb 2013    Post subject: Reply with quote
Looks too small for the crankcase breater to me, looks more like the fuel tank breather/overflow to me, or possibly the tube that links the radiator to the coolant tank.
If you follow the tube, where does it lead to? If it is the fuel tank breather it should route down the RHS unto the round 'hook' on the RHS bracket that holds the swingarm on the frame.
Nick_Giles
PostPosted: 18:14 - 15 Feb 2013    Post subject: Reply with quote
Nick_Giles wrote:
Lynchasaurus wrote:
*2001 Hornet
Nick
Here you go. Smile
https://dl.dropbox.com/u/50093335/HondaHornetcb600f-W-Servicemanual.zip
Save the download somewhere on your PC then 'un-zip' it.
Nick
The last post was made 12 years, 355 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.84 - MySQL Queries: 13 - Page Size: 85.47 Kb
