| MAR5H7 |
 MAR5H7 Nitrous Nuisance
 Posted: 16:50 - 15 Feb 2013 Post subject: Thundercat Idling/Sparking Issue |
Hello there
Iv recently replaced my plugs as due on milage and at first they were a quick and responsive
I have now done about 700 miles on them, and now the bike refuses to idle for more than 10 seconds, sometimes it will just die
I am well aware the carbs are desperate need of balancing but thats not the main issue with it
The problem is during warm up stage (choke) and low running speeds, you can hear the bike not sparking, sometimes until 30 mph!!!
my mate heard it when I pulled away and you can also see QUITE A BIT of petrol coming out of the exhaust pipe D: which leads me to believe its only running on 3 cylinders??
NGK spark plugs in, now I will add a note, when I took the 3rd spark out (one of the middle bitches to get) It was EXTREMELY difficult, and when I finally got it out after hours of labouring, I found out why, the spark plug thread had a lovely little like a few notches down making it a sod to get out
Not sure if that helps??
Cheers guys!! ____________________ Ex: CBR 125 R 06', ZXR 400 96' (RIP), Bandit 650 06'
Owned: SRAD 600 97'
Current: YZF Thundercat 600 96' |
| weasley |
 weasley World Chat Champion
| MAR5H7 |
| steady eddie |
 steady eddie Nova Slayer
 Posted: 23:46 - 15 Feb 2013 Post subject: |
Has the bike been laid up for a while? If so, could be blocked pilot jets. Or throttle position sensor... Or even a problem with no 3 pot
Google "Bikers oracle", there's a good Thundercat forum on there  ____________________ Fz50>Ts185>Rd125Lc>Cb250n Superdream "Deluxe" (!)>Kmx200>Tdr250>Yzf600 Thundercat>
Current bikes: 1997 Fireblade RRV & 1989 KMX200 |
| weasley |
 Posted: 09:17 - 16 Feb 2013 Post subject: |
And a better (more active) one at www.yamaha-thundercats.org
Declaration of interest: I am an administrator of this one. ____________________
Yamaha XJ600 | Yamaha YZF600R Thundercat | KTM 990 SMT | BMW F900XR TE |
| Walloper |
 Walloper Super Spammer
 Posted: 09:33 - 16 Feb 2013 Post subject: |
The thing you were phannie-ing about with is the most prbably cause of your symptoms.
Ensure you have the caps on properly.
Also may be worth fitting a set of HT leads.
They are only made with a carbon filament so any rough handling can damage the lead. If they are still soft/felxible then that may not be an issue.
If you can run it with the tank off you can disconnect each plug one by one to find if there is a 'dead one' (bad connection).
Also let it idle and rock the bike that may show a broken connection. (but I doubt it).
You could also have a dodgy plug . Pulling the caps off with show this though and if it shows a dead plug at No. 3 as you say then swap the plug at No. 3 with the plug at No. 2, 4 or 1. If the fault stays with the plug then the plug is bad.
I never balanced the carbs on my T'cat and ran it for three years form new. ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
| weasley |
The last post was made 12 years, 347 days ago. Instead of replying here, would creating a new thread be more useful? |
