Problem with NSR 125R 2001
Bitter
PostPosted: 09:59 - 16 Nov 2004    Post subject: Problem with NSR 125R 2001 Reply with quote
Hi from spain.
I read all the topics about this bike, but I can solve the problem with my nsr with 6000 Km.
The problem is that the bike don't get enough speed. At 120-125 Km/h (about 75 mph) is top speed.
I tried to remove the restriction, but it seems that no restrictor are in the bike. I changed the sparkplug and the air filter. Also changed the transmission kit and put a 13/36 system.
The bike push up of revolutions without problem arriving to the 11K rev or more, in all gear, but it arrives al 75 mph in 5 gear, but when I put 6 gear, the speed is the same.
After all this changes, I think that the CDI is OK, and no restrictions are in the bike, but it remains without top speed.
Any idea?. Is possible that the discharge valve don't opens at all?
Thanks for any suggestion, and sorry for my poor english.
Bye
tatters
Exxon Valdez
PostPosted: 10:08 - 16 Nov 2004    Post subject: Reply with quote
europearn bikes (non-UK) like yours have CDI restrictions that limit the bikes revs in higher gears, have a search around the forum l think allians had a power valve mod that bypassed the restrictions.
Bitter
PostPosted: 10:14 - 16 Nov 2004    Post subject: Reply with quote
Thanks, but the bike arrives at 11-11,5K in all gears, except in 6.
If I push the 5 gear, the tachometer goes into red zone.
Do you still thinks that is a problem with CDI?
alains
PostPosted: 12:32 - 16 Nov 2004    Post subject: Reply with quote
the restriction is in the RC valves control box , the exhaust valves do not open as they should do after 7800 rpm . try this : on the right side of the tank , you can see the servo pulley and a piece of stuff where the cables are stopped . the tractor cable is the most right . undo the screw in the pulley center an take off the pulley . take the right cable out of its stop . insert a thickness 1/10 of inch at the end of the sheath (the best way is to do it with aluminium foil) . then re-fit the cable and you must see the sheath a bit out of its stop . re-fit the pulley . this will force the valves to open fully . also fit a 402 CARB jollymoto exhaust line (+2.5 hp) , upjet 145-45-70 (https://www.dellorto.co.uk) with a 10% air box entry openning
the rc valves control can be improve electronicaly , if you want to know send me a direct email at [email protected] , i will give you the docs
Bitter
PostPosted: 16:13 - 16 Nov 2004    Post subject: Reply with quote
Ok-
thanks. I'll try your idea this weekend.
I'll tell you something after make the change.
Thanks
alains
PostPosted: 16:32 - 16 Nov 2004    Post subject: Reply with quote
you must reach & overtake easily the red zone (12500 rpm) , but the shape of the exhaust will limit you at 11000 , but you will feel the improvment .
wantser
PostPosted: 16:36 - 16 Nov 2004    Post subject: Reply with quote
hey alains.
after your advise with the CDI for my bike I have got hold of a second hand unit from a NS125R. Later model than my NSR125RR, I beleive?!
Will it work on my bike? I bought it anyway as I cant seem to find the damn things anywhere! Thumbs Up
An expert is a person who has made all the mistakes that can be made in a very narrow field
Bitter
PostPosted: 16:42 - 16 Nov 2004    Post subject: Reply with quote
Alains,
The problem with the exhaust valve is because the valve is broken or is because the CDI don't open at all the valve??
Thx.
alains
PostPosted: 18:06 - 16 Nov 2004    Post subject: Reply with quote
if your cdi was restricted you need to change the coil . the better (i do not know which specifications you have on your bike) is to call TIM https://www.davidsilverspares.co.uk (phone is on the site) with your bike's serial number and your color code (under the saddle) , he will help you to determine your specs , but i remember thar the RR's are restricted on the CDI .
for bitter , the problem is not from the CDI , it's from the RC valves control box which not provide enough voltage to fully open the valves (4.4 V instead of 5.25 V) . in france we built a electronic complement to correct this , and i've written several posts about that and i am ready to send docs to everyone who wants it . pass me direct email [email protected]
The last post was made 21 years, 302 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.77 - MySQL Queries: 13 - Page Size: 59.56 Kb
