Cyclone V2 - possible to adjust sensitivity?
goto10
PostPosted: 17:13 - 14 Feb 2013    Post subject: Cyclone V2 - possible to adjust sensitivity? Reply with quote
Unfortunately I no longer have the manual, I managed to ride 20 miles with the alarm armed [unknowingly] - it was at 80mph I received the alarm chirps and indicators flashing (!) -
(I only have the indicators wired in because my bike already has a factory immobiliser)
I've since tried getting the alarm to chirp or give some indication that it's armed, but it won't respond unless it hits a pot hole. Is there a way to adjust sensitivity or is just faulty..?
Andyk
PostPosted: 17:17 - 14 Feb 2013    Post subject: Reply with quote
there is a way to adjust it it was something like hold the lock button for 8 seconds the lights will stay lit and then press the lightening bolt..... to adjust levels..... cannot remember fully will dig my instructions out later if nobody else knows for sure
LordShaftesbu...
PostPosted: 18:42 - 14 Feb 2013    Post subject: Reply with quote
https://cdn.bikechatforums.com/files/lastscan_194.jpg
Derivative
PostPosted: 20:53 - 14 Feb 2013    Post subject: Reply with quote
Are you sure you didn't arm it by mistake?
I've had that happen once. The key fob touched another key in my pocket and so the alarm started blazing away.
I just put the fob in its' own pocket now.
goto10
PostPosted: 11:58 - 16 Feb 2013    Post subject: Reply with quote
Perfect, thank-you!
It has, however, confirmed that my alarm is shagged after only a few months :/ (set to maximum sensitivity it still refuses to acknowledge being shaken/knocked/ridden down the road 20 miles) - everything appears to function normally aside from the shock sensor.
I'll drop N Cooke security an Email, but IIRC he only gives a warranty if you had it professionally installed. I'm not sure why connecting 4 wires requires professional installation, but there you go.
Ja7
PostPosted: 12:14 - 16 Feb 2013    Post subject: Reply with quote
Shame it's broke in that short amount of time, apart from that was it any good.
I'm stuck between a hawk x40, or a cyclone v2, I had a hawk on a bike I owned a few years ago, and it never failed, bit annoying sometimes when you fill up with petrol and wash the bike as it self arms and kept going off.
The cyclone doesn't self arm does it ?
bridgedino
PostPosted: 12:30 - 16 Feb 2013    Post subject: Reply with quote
Mine certainly doesn't self arm.
I had to adjust the sensitivity on mine. Trouble was I hadn't even bothered wiring up the indicators. It works just fine as a stand alone motion sensing alarm.
Anyway try holding the 'arm' button for 2 seconds then hold the lightening bolt button for 20 seconds. After that use the lightening bolt button to try setting it. Level 1 suits me perfectly
There's a factory re set option which is on my instructions...out in the shed. Let me know if you want to try that option
The last post was made 13 years, 143 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 2.43 - MySQL Queries: 13 - Page Size: 51.38 Kb
