Best drill bits to get?
Nick 50
PostPosted: 17:11 - 16 Feb 2013    Post subject: Best drill bits to get? Reply with quote
I have a snapped bolt on the VFR which holds on earths. So I need to get it out and replaced.
What are the best type of metal drill bits to get?
I've seen Cobalt, Titanium, DeWalt Extreme ones etc etc, but not sure which are best for the job?
The Artist
PostPosted: 17:26 - 16 Feb 2013    Post subject: Reply with quote
Cobalt I like. Cut through mild steel like cheese but are expensive. Also brittle, I snapped a 13mm cobalt bit the other day just by catching a burr wrong.
PostPosted: 17:45 - 16 Feb 2013    Post subject: Reply with quote
If the earth strap bolt as sheared, why not simply put the earth on a different bolt?
And why the hell post this in Dear Auntie?
c_dug
PostPosted: 17:58 - 16 Feb 2013    Post subject: Reply with quote
Standard drill bits will do the job fine, I use a few types at work but only really notice the difference when drilling through hardened steel.
I'm not sure drilling out should be the first port of call though and I'm talking from experience here. If you don't know what you're doing it is very easy to make matters worse.
As mentioned maybe look at relocating the earth for the time being and looking at other ways of removing the stud.
PostPosted: 21:31 - 16 Feb 2013    Post subject: Reply with quote
I like my cobalt bits. I haven't snapped one yet, and they demolish mild steel. Cost is fine if you factor in your time.
PostPosted: 22:26 - 16 Feb 2013    Post subject: Reply with quote
Absolutely, cobalt drills are the mutts testicles Thumbs Up
Triumph Trophy Launch Edition
BTTD
PostPosted: 23:42 - 16 Feb 2013    Post subject: Reply with quote
HSS for mild steel and soft metals, and cobalt for stainless.
h00dwink
PostPosted: 02:32 - 17 Feb 2013    Post subject: Reply with quote
this- hss bits are also super cheap by comparison to cobalt and other higher quality. which is a lot better when you're snapping shit loads of them drilling metal.
Sahf East Winnah 4LYF
https://bikepics.com/members/h00dwink/00sv650s/
www.youtube.com/h00dwink updated regularly
PostPosted: 08:07 - 17 Feb 2013    Post subject: Reply with quote
Then you are doing something wrong! Laughing
Raffles
PostPosted: 11:55 - 17 Feb 2013    Post subject: Reply with quote
He's using super cheap bits.
woll
PostPosted: 21:23 - 17 Feb 2013    Post subject: Reply with quote
Personally I'd use cobalt for drilling any metal. I always find HSS even expensive ones snap too easy and go blunt as soon as they look at something hard.
kramdra
PostPosted: 22:13 - 17 Feb 2013    Post subject: Reply with quote
Solid carbide for win. They are significantly more brittle compared to HSS/HSS-Co, but they are good Very Happy
For low accuracy, you may be able to cheat with a masonary drill Laughing
Dont waste money buying drills with surface coatings like titanium.
Azonicben
PostPosted: 22:25 - 17 Feb 2013    Post subject: Reply with quote
I'd be trying an "E-z out" first if its a snapped bolt.
https://www.toolstation.com/shop/Power+Tool+Accessories/Speciality+Drills+Chucks/Screw+and+Bolt+Extractor+Set+5+Piece/d80/sd1400/p51010
Raffles
PostPosted: 11:06 - 18 Feb 2013    Post subject: Reply with quote
https://i.telegraph.co.uk/multimedia/archive/02147/carson2_2147546c.jpg
MarkJ
PostPosted: 11:08 - 18 Feb 2013    Post subject: Reply with quote
Cobalt bits are awesome Thumbs Up
Nick 50
PostPosted: 21:43 - 18 Feb 2013    Post subject: Reply with quote
Cheers for the replies.
I trundled off to machine mart yesterday in the hope of getting some Cobalt ones they have advertised online. Got to the place and quickly realised the staff are extremely well trained at being the most miserable unhelpful *beeps* i've experienced in a while.
I've ended up with some Titanium coated ones (then came back and read kramdra's reply) Embarassed oh well
spikenipple
PostPosted: 22:34 - 18 Feb 2013    Post subject: Reply with quote
There's nothing wrong with that, the TiN coating helps reduce friction and consequent heat build up, which will blunt the drill quickly if not controlled.
C50 > GN250 > XJ600 > SV650S K7 > 2001 RSV Mille R > MT-09, XR400R > 2005 Fireblade (trackbike) + 2022 MT-09 + ZXR400 race bike
The last post was made 12 years, 363 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 94.33 Kb
