another one with bleeding problems.
BravoCharlie
PostPosted: 15:13 - 17 Feb 2013    Post subject: another one with bleeding problems. Reply with quote
im having an issue in bleeding the brakes.
the weathers gorgeous and im pretty desperate to get out.
i've opened the MC, cleared it of its existing fluid, poured in dot4, and started to pump. been doing so for about 35 minutes now. each time i try and open the bleed nipple, nothing comes out. i was worried fluid wasnt reaching the calipers, so i opened the banjo bolt and fluid is definitely there.
any ideas? or anyone in the glasgow area willing to help? will pay if necessary!
Current: Kawasaki ZL600 Eliminator
Past: Suzuki GZ125, Kawasaki GT550, Kawasaki GPX600R, Honda vrx400,Kawasaki Zephyr 750, Suzuki SV650 K5
Dream as if you'll live forever, live as if you'll die today.
anthony_r6
PostPosted: 15:38 - 17 Feb 2013    Post subject: Reply with quote
I didn't think you were supposed to clear the MC ? I thought you just topped it up and filtered the old stuff through with the new until it was clear. Possibly the problem is that air got into the lines via MC?
BravoCharlie
PostPosted: 15:44 - 17 Feb 2013    Post subject: Reply with quote
it had to be a dry bleed regardless, i'd just had the calipers taken in for a refurb, so whilst they were off the fluid had been pissing into a bucket anyway, but when i opened the reservoir there was some grime, so saw it best just to take it all out and start again.
its getting to me big time as the weathers almost gone now and its back to work tomorrow!
Copycat73
PostPosted: 16:07 - 17 Feb 2013    Post subject: Reply with quote
its air locked ... put a clear plastic pipe on the open bleed nipple, top up the master cylinder to the brim.. pump the lever and suck on the pipe at the same time...
PS. brake fluid tastes horrible.. you will get some in your mouth.
caveat emptor
Charlie
Isn't there a method of filling them from the calliper instead? Think you need one of those bleeding kit hand pump things though
keggyhander
I always start from an empty m/c and back fill from the calipers using a large plastic syringe.
It's really a two man job. One person mans the syringe and the bleed nipples, the other keeps the m/c level down using another syringe.
Once done, bleed the banjos, and bleed the nipples again.
Time required: Half an hour.
keggyhander
PostPosted: 16:08 - 17 Feb 2013    Post subject: Reply with quote
Just a large syringe from Ebay and the correct diameter tubing.
Charlie
PostPosted: 16:12 - 17 Feb 2013    Post subject: Reply with quote
Good to know thanks Thumbs Up
How do you bleed the banjo bolts? Same as normal bleeding?
BravoCharlie
PostPosted: 16:14 - 17 Feb 2013    Post subject: Reply with quote
Thanks chaps, ill get on to the bay. Looks like I can't go play motorbikes today Sad
keggyhander
PostPosted: 16:18 - 17 Feb 2013    Post subject: Reply with quote
Fasten everything up, wrap rags around the banjos, then crack them open slightly while applying lever pressure. Do them individually. Throw the rags away.
Copycat73
PostPosted: 16:27 - 17 Feb 2013    Post subject: Reply with quote
12212012 wrote:
Copycat73 wrote:
its air locked ... put a clear plastic pipe on the open bleed nipple, top up the master cylinder to the brim.. pump the lever and suck on the pipe at the same time... PS. brake fluid tastes horrible.. you will get some in your mouth.
to point absurdities about the way we live our lives in a non-threatening way.
ok.. but do you know how he can fix his brakes..
pointing out relevance non-threatening way.
caveat emptor
BravoCharlie
PostPosted: 16:41 - 17 Feb 2013    Post subject: Reply with quote
new guy, just joined, name full of numbers...
i'll admit copycat your way does sound lethal. but if you reckon it'd work without taking the urine outta me...i'll do anything at this point!
Copycat73
PostPosted: 16:46 - 17 Feb 2013    Post subject: Reply with quote
look its not my prefered option, its some thing i would do at the side of the road.. but it sounded to me like your back is against the wall with time running out and limited options & tools.
it will work ... but brake fluid is horrible-horrible stuff... good luck !!!
caveat emptor
BravoCharlie
PostPosted: 16:51 - 17 Feb 2013    Post subject: Reply with quote
mouthwash at the ready! cheers mate!
Copycat73
PostPosted: 16:55 - 17 Feb 2013    Post subject: Reply with quote
i had to make do with tooth paste ... always was interesting with that DR600
caveat emptor
Noxious89123
PostPosted: 16:56 - 17 Feb 2013    Post subject: Reply with quote
First time bleeding brakes? Are you holding the lever back to the bar at the same time you undo the bleed nipple? You might not get any fluid initially, probably just air, but if you keep going you should eventually get fluid through.
Apologies if you're already doing it this way! Over the internet it's a case of "Not sure if full potato". Thumbs Up Laughing
kingsknight
PostPosted: 17:00 - 17 Feb 2013    Post subject: Reply with quote
That will work, I had to do it on my XR. Be warned, there is no warning what so ever you will just have a load of brake fluid in your mouth and it is one of the worst tastes I have ever tasted. But you will have working brakes. Mine was fine from that day on! Let us know how it went!
TS50 (sold) NS125F (sold) NSR125R-K (write off after 2 crashes) CG125 (nicked) XR125L-3 (Sold )-: ) DR125SM '11 (sold yay) XL125V '12 (In love with this bike) XT600E '04 (fun on the dirt)
P.
PostPosted: 17:03 - 17 Feb 2013    Post subject: Reply with quote
Brake fluid is corrosive. Ignore copycat. Laughing
Keep bleeding it normally.. but yeah, grab a syringe Thumbs Up
Copycat73
PostPosted: 17:16 - 17 Feb 2013    Post subject: Reply with quote
given the time where do you suppose he will get one of those?
Also given he needs the bike fit for monday ?
caveat emptor
P.
PostPosted: 17:17 - 17 Feb 2013    Post subject: Reply with quote
Copycat73 wrote:
given the time where do you suppose he will get one of those? ,
Should have learnt not to mess with the most fundamental part of the bike unless he knew what he was doing Thumbs Up
Copycat73
PostPosted: 17:21 - 17 Feb 2013    Post subject: Reply with quote
what and you have never got in over your head with a mechanical problem & made it worse by tryin to fix it .. endin up needin help or guidance from outside ?
caveat emptor
P.
PostPosted: 17:23 - 17 Feb 2013    Post subject: Reply with quote
Copycat73 wrote:
what and you have never got in over you head with a mechanical problem & made it worse by tryin to fix it .. endin up needin help or guidance from outside ?
Not without having a backup plan.
I tackle what I can with mechanics. What I can't do, I enlist someone that can help, but I'm never without my bike/car as I've fiddled too far beyond my own skill Thumbs Up
Copycat73
PostPosted: 17:26 - 17 Feb 2013    Post subject: Reply with quote
don`t think he has the luxury of a second vehicle as a back-up plan.
caveat emptor
piazza
PostPosted: 17:35 - 17 Feb 2013    Post subject: Reply with quote
If you're still stuck PM me. I'm in the southside Thumbs Up
GrumpyGuts
PostPosted: 18:28 - 17 Feb 2013    Post subject: Reply with quote
This is my bleeding thread . Lots of suggestions and turns out my problem was with the lever. It was still pushing the MC piston even when released. You could try that Thumbs Up
My Bikes: Lifan Beat 125cc '11 -> Suzuki B120P '76 -> Suzuki EN 125-2A '08 -> Honda CG 125 '04 -> Honda CB600F Hornet '98 -> Kawasaki ZZR 600 '99 -> Kawasaki GPZ 500S '95 (Current)
Theory test passed - 09/02/2012 >>>> Module 1 passed 24/07/2012 >>>> Module 2 passed 24/10/2012
The last post was made 12 years, 352 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.23 - MySQL Queries: 13 - Page Size: 131.35 Kb
