cb400 superdream
hondakawasaki
PostPosted: 04:28 - 18 Feb 2013    Post subject: cb400 superdream Reply with quote
hi all Smile
the base gasket needs replacing on my superdream 400 as its leaking oil
i need to take off the whole head and replace all the gaskets
can any one tell me if i need to take the engine out of the frame to remove the head
thanks Very Happy
bikenut
PostPosted: 13:30 - 18 Feb 2013    Post subject: Reply with quote
wet dream, can be done with eng in frame but be carefull with head bolts etc etc etc.
if leaking tween cyl at the front bottom be carefull of centre bolt problems......see cmsnl for the exploded views etc etc etc.
study the eng exploded views, do you need more info??
hondakawasaki
PostPosted: 14:40 - 18 Feb 2013    Post subject: Reply with quote
Thanks, its leaking at the base of the head were it connects to the bottom end
It seems to be leaking from the back and somwhere on the front of the engine because there is oil around there
smegballs
PostPosted: 15:30 - 18 Feb 2013    Post subject: Reply with quote
Is it easy to get the engine out of the frame?
I'd be tempted to do so to avoid the possibility of accidentally dropping rust or paint flakes from the frame into the open guts of the engine.
Casper
PostPosted: 15:40 - 18 Feb 2013    Post subject: Reply with quote
I had a slight weep from mine. A quick 1/4 turn of the head bolts sorted the problem.
moonzoomer
PostPosted: 16:25 - 18 Feb 2013    Post subject: Reply with quote
the main frame spine under the tank has got 4 holes drilled already to allow the removal/tightening of engine studs, it is an easy job to do though I would be inclined to try tightening the studs before replacing The gasket or removing the head and barrel.
hondakawasaki
PostPosted: 21:20 - 18 Feb 2013    Post subject: Reply with quote
so i went and took off the head and barrels the first thing i noticed was the 4 cylinder bolts in the middle
here, they are missing some sort of rubber seal only 2 of the bolts had the rubber seals on should all 4 bolts have the rubber seals on? or should all the cylinder bolts have them on
i also noticed the 2 bolts with out the seals where they screw in was full of oil
could this be the reason it was leaking?
https://i438.photobucket.com/albums/qq101/daz7189/IMAG1480-1.jpghttps://i438.photobucket.com/albums/qq101/daz7189/vlcsnap-2013-02-18-20h28m43s91.png
also the valves looked a bit crispy should i clean them up? if so how should i do it, it also looks like 1 of the valves has been replaced at some point
https://i438.photobucket.com/albums/qq101/daz7189/IMG_0427.jpg
also the pistons looking rather clean
https://i438.photobucket.com/albums/qq101/daz7189/IMG_0428.jpghttps://i438.photobucket.com/albums/qq101/daz7189/IMG_0429.jpg
bikenut
PostPosted: 14:45 - 19 Feb 2013    Post subject: Reply with quote
wet dream cause of oil, see cylinder base and show pics, see cmsnl for exploded views which will answer some of your questions.
bikenut
PostPosted: 14:48 - 19 Feb 2013    Post subject: Reply with quote
dont use the blue sealer, or anyother colour.
examine your parts and figure ouit how oil gets to cam, and how its stopped from leaking, see cmsnl !!!!!!!!!!!!!!
some more pics and is oil control ring top and bottom rail "gaps" in line??
hondakawasaki
PostPosted: 16:09 - 19 Feb 2013    Post subject: Reply with quote
Hi cmsnl does not show the bolts with the rubber seals
Im not sure if all the bolts should have it also the holes the 4 center bolts go down have gaps that go straight through to the outside of the engine i will take a pic later to show you what i mean
Also what do u mean are the oil controll ring rail gaps in line i did spin the rings to see if they was stuck
Thanks inwill post pics later
bikenut
PostPosted: 20:14 - 20 Feb 2013    Post subject: Reply with quote
:D hi dude
so you have found the reason for the on bolt seals then!!
how is balance chain for slack, you will be able to see it thru cyl holes, its adjustable, see cmnsl.......
ring gaps paced so no gaplines up, also check oil ring wavvy bit for proper fit............
make sure all head bolt holes are clean, 10 x 1.25 from memory.....
how you getting on??
hondakawasaki
PostPosted: 05:36 - 21 Feb 2013    Post subject: Reply with quote
hi Smile yes the bolts with the seals should be placed in the correct place i dont think they was in my bike
i am still waiting for the new gasket set Confused
i will check balance chain tomorrow its dark now
if it needs adjusting how do i do it?
my manual says its spring loaded so i just unscrew the bolt and re tighten it? is this correct theres no pictures it pretty vague
heres a pic witch bolt do i loosen ?
https://i438.photobucket.com/albums/qq101/daz7189/5-1.jpgthanks i will let you know how i get on Smile
hondakawasaki
PostPosted: 06:33 - 21 Feb 2013    Post subject: Reply with quote
Also when i put the barrels back on do the piston rings have to go on in a certain way? Do they have to line up in any way or does it not matter
Thanks for the help?
grahamd1
PostPosted: 14:48 - 21 Feb 2013    Post subject: Reply with quote
bbbbbNot all of the head bolts have seals or even washers
https://i314.photobucket.com/albums/ll431/grahamdrry/head1_zpsf2a0965a.jpg
Also the order in which the head bolts are undone and tightend on the SDs is critical
https://i314.photobucket.com/albums/ll431/grahamdrry/head2_zps218fdc6f.jpg
Heres an exploded view that acutally shows the seals
https://i314.photobucket.com/albums/ll431/grahamdrry/head3_zps9909c8bb.jpg
And the correct tightening sequence
https://i314.photobucket.com/albums/ll431/grahamdrry/head4_zpse4503d5b.jpg
Hope it helps, I'm on my second rebuilt SD (first was a messy 250, second is 400NB). Some of the later 400s had an additional oil pipe on the top of the head, if you have that one let me know and I will share those pics as well.
XV1100, XV750
CD175 (Rebuild)
CF70 (Chaly - Rebuild),
hondakawasaki
PostPosted: 05:12 - 22 Feb 2013    Post subject: Reply with quote
hi, i have now rebuilt the top end took me all day Surprised
i now have another problem the bike took about 10 mins to start and when i did get it started there was a horrendous whirry rattly sound coming from under the rocker cover
i did adjust the valve clearances i had to unscrew them for ages to get the feeler gauge under it says 0.10mm for inlet 0.14mm for exhaust
i think i have set them way to big should the valve springs be compressed by the tappets i set them so they have a little play in them a sliding fit with the feeler gauge
please help!!!
hondakawasaki
PostPosted: 06:09 - 22 Feb 2013    Post subject: Reply with quote
also does the engine have to be on the right stroke to set the valve clearances
i remember my cg 125 had to be on the right engine stroke to set the valve clearances
i think i set them wrong now they have a huge gap? Shocked
hondakawasaki
PostPosted: 16:01 - 22 Feb 2013    Post subject: Reply with quote
Hi, ok so it turns out i set the valve clearances WAY to big i was on the wrong engine stroke
So i re set the valves and it took 2 kicks its very smokey now and i seen no oil leaks
Thanks
paddlesat16
PostPosted: 15:50 - 23 Feb 2013    Post subject: Reply with quote
If you own a superdream you need here Very Happy
https://honda-superdream.proboards.com/index.cgi
lots of like minded people owning superdreams Wink
The piston ring gaps should have been equally spaced at about 120 degrees.
With the head off I would have re-lapped the valves, changed the stem seals and then bolted it back up.
You need to buy a Haynes manual at the very least for this bike especially when your dismantling and rebuilding the engine as you could have bent all the valves by mis-timing the engine. Sad
I once saw a bloke shagging a donkey.... in Saudi arabia. Theory Test Passed 26/10/09 Mod 1 Passed 26/4/10, Mod 2 Passed 7/6/10 Current Bikes Suzuki GSX1400 K5, Aprillia Pegaso 650, Suzuki DR350T.
hondakawasaki
PostPosted: 17:35 - 23 Feb 2013    Post subject: Reply with quote
Hi, i have a haynes manual we timed it properly it starts ok it just real smokey for 5 mins and has a slight oil leak on the front of the engine
Could oil be leaking into the piston from the same place its leaking out the front of the engine i think theres a dodgy seal also som of the cylinder bolts are the wrong size so i couldent torque them up properly
paddlesat16
PostPosted: 17:57 - 23 Feb 2013    Post subject: Reply with quote
Hi hondakawasaki
Pop onto the superdream site and say hello, they are a friendly bunch and will help out, you may find the bolts on there.
Your smoky engine could be that leak?? difficult to say.
Regards
bikenut
PostPosted: 13:08 - 25 Feb 2013    Post subject: wet dream Reply with quote
the head bolts wi5th the onbuilt seals go into the holes in the cyl which have the daft cut out designed in oil leak holes..........you have seen them??????
the balance shaft has an adjustable adjusting slotted quadrant bit.......the shafy also has a "dot" on the end.
bikenut
PostPosted: 13:18 - 25 Feb 2013    Post subject: Reply with quote
you sure you fitted the correct bolt in the correct hole?????where the haed bolt holes cleaned out, ie crap in the bottom of the holes??????
10mm x 1.25
you have a haynes manual so better than nothing........
the "dot" looks to be at 1 o clock position so plenty of adjustment left.
dot at 3 o clock max OFF position
rotating anticlockwise to 9 o clock position MAX ADJUSTMENT.
if dot below 3 amd 9 o clock its worn out ( eng strip ).
the quadrant is splined to the balance shaft and is adjustable relative to the balance shaft.
you can see the balance chain through the gaps, when adjusted, any slack??
adjust on stationery eng at "T".
also when at "t" are cam sprocket marks parrallel to head or sloping backwards??
oil leak at front would be from favorite place, those daft channels in cyl base and poor seal tween cyl and built on seal head bolts
oil can leak down the 4 inner headbolts and make it appear at bottom, favorite place..............so take care of that. 8o) 8o)
400's are very desirable so dont get it nicked!!!!!!!!!!!!!
The last post was made 13 years, 7 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.77 - MySQL Queries: 13 - Page Size: 115.95 Kb
