| StormCrow |
 StormCrow Scooby Slapper
 Posted: 22:31 - 19 Feb 2013 Post subject: Triumph Trident oil pressure... |
1995 Triumph Trident 900... 14600 miles, oil changed recently for 10w40 semi synthetic.
Been having intermittent issues with the oil pressure light.
First time it came on when starting outside work - dimly lit but increasing with revs. Took bike to local mechanic (by trailer) who put a new crimp on the end of the wire and declared it fine.
About two weeks later, same problem. I replaced the oil pressure switch with a genuine new part.
Fast forward a month, and the light comes on AGAIN. Now it's on 'strong'...
Had a good poke around tonight. When the wire is disconnected, the light goes out, which I think proves that there is no short circuit in the wiring.
Running the bike at cold idle, the switch is outputting about 750ohms at ~2000rpm (obviously not going to rev higher!). Obviously this is enough to turn on the light - I'm not sure if the switch should 'snap' open and closed - anyone know?
This sounds like it's going to be expensive...
Anyone got any suggestions? |
| Robby |
 Robby Dirty Old Man
| StormCrow |
| uberkron |
 uberkron Crazy Courier
| StormCrow |
| uberkron |
| StormCrow |
 Posted: 13:31 - 20 Feb 2013 Post subject: |
Knowing my luck... probably!
Booked in for collection next Tuesday - got the sinking feeling it won't be good either way... the crank cases need splitting to get at the oil pump, so if pressure IS down, then it'll need stripping and rebuilding just to look at the problem...  |
| StormCrow |
| StormCrow |
| lukamon |
 lukamon World Chat Champion
 Posted: 01:57 - 23 Mar 2013 Post subject: |
if it is at 70psi then yes, the valve will be open.
think about it. the oil pump has to work at anywhere between 1000 and 15000 rpm on some machines. that's a ridiculously wide margin of operation. think of the pump, pumping oil into a pipe with a hole on one side. there is a flap of metal pressing down over the hole, the pressure inside bends the bit of metal a little bit , releasing oil, which falls into the sump. is there pressure in the pipe? of course, otherwise how could it push open the spring to get out?
tl;dr: the relief valve is open, yes. but that's normal. my money would be on an almost - blocked pickup strainer that maybe pick up and extra bit of crap that nearly seals it, then drops it again. drop the sump  ____________________ killa wrote: Im an ass man myself |
| Robby |
 Robby Dirty Old Man
The last post was made 13 years, 223 days ago. Instead of replying here, would creating a new thread be more useful? |
