What do I chain it up to?
Srengam
PostPosted: 13:39 - 20 Feb 2013    Post subject: What do I chain it up to? Reply with quote
Might be moving house to somewhere with no garage, so I'll be looking to chain my bike up with a big fat chain.
So what do I chain it up to?
Are there "suggested" steel hoop brackets or something?
Suzuki GSX600F Katana (1997)
Casper
PostPosted: 13:43 - 20 Feb 2013    Post subject: Reply with quote
Your car tow eye if you have one. Drain in the gutter. Lampost. Rent a lockup or find local biker and chain bikes togeather.
Slacker24seve...
PostPosted: 13:44 - 20 Feb 2013    Post subject: Reply with quote
If permission allows (or you're the owner) then bolting or concreting in a ground anchor is preferable.
If that isn't possible (I rebar-ed and concreted a massive D-shackle that had been welded shut into my drive) one of the things that comes up on here is to make a big lump of concrete which is heavy and not very portable with an anchor point to chain you bike too.
Banger rallies are ace
Steven8294
PostPosted: 13:54 - 20 Feb 2013    Post subject: Reply with quote
I have seen a bike parked infront of a car (presumably their own) and it being chained to the car, couldn't see what it was chained to however the chain went underneath the car.
| Passed; 14th November 2012 | 1st Bike: Yamaha YBR125 2009 Model |
| 2nd Bike: 09 Kawasaki ER-6F (Stolen) | Current Bike: 08 Kawasaki ER-6N
goto10
PostPosted: 14:18 - 20 Feb 2013    Post subject: Reply with quote
*Later that evening*
"Honey, I needed to use the car to pop to Tesco earlier on, but it's making an awful racket - I think the car needs a service or something"
Joncrete Cungle
PostPosted: 14:34 - 20 Feb 2013    Post subject: Reply with quote
Ground anchor / wall anchor set in floor or wall. BIG plant pot filled with bricks, concrete, reinforcement and with a ground anchor set in the concrete and reinforcement. Chain to a lamp post or any hefty railings / benches near by? Can you rent a private garage or council / housing association garage nearby?
Alpha-9
PostPosted: 14:35 - 20 Feb 2013    Post subject: Reply with quote
Tie it to a really long piece of rope and tie the rope to your leg, so if it get's pulled you'll know someone is robbing your bike from the comfort of your own home.
No thanks necessary Thumbs Up
Fzr-600 1999
j.silvs
PostPosted: 14:38 - 20 Feb 2013    Post subject: Reply with quote
I have chemically bonded an anchor to my house.
Before this I chained the bike to the alloy on my car - driver side just so my mrs or I don't forget lol
Kol
PostPosted: 14:40 - 20 Feb 2013    Post subject: Reply with quote
I screwed an Oxford Brute Force ground anchor to the wall, about 8" from the floor and it works a treat. Costs about £20 with fixings, but I picked it up on eBay for £12 new. You want to think about where you'll be putting the chain on the bike when deciding where to fit a wall/ground anchor. The best place is through the swing arm. For me due to the tight space outside I have to put it through the rear wheel, which isn't ideal as it can obv be removed easily. Having said that though, any thief worth his salt is more likely to just cut the chain. When I'm away for any extended length of time I also use a motion sensitive alarmed disc lock on the front wheel. Along with the bikes motion sensitive alarm and a decent outdoor cover over the bike, there's not a whole lot else that can be done security wise.
PostPosted: 15:03 - 20 Feb 2013    Post subject: Reply with quote
Find someone who's just paid £4400 for a new YZF-R125 and chain it to them. You won't find anything denser. Thumbs Up
-LG-
PostPosted: 15:06 - 20 Feb 2013    Post subject: Reply with quote
At the moment mine isn't locked to anything, disc lock and another lock though the rear wheel. I will be getting a ground anchor soon though.
Snow rider wrote: I'm far to annoying to be near for long periods of time
Casper
PostPosted: 15:14 - 20 Feb 2013    Post subject: Reply with quote
I cant see you having bother owning a gold teapot. My bike is worth less than yours, all i use is an shitty Oxford chain through the rear wheel. As long as its good enough to keep the kids from joyriding it. If your bike has no great value you are not going to get two guys chucking it into the back of a van.
The problem with leaving it chained to a lampost you need to make sure that space will still be there when you get home.
LordShaftesbu...
PostPosted: 15:34 - 20 Feb 2013    Post subject: Reply with quote
Chain it to a second bike.
thx1138
PostPosted: 15:44 - 20 Feb 2013    Post subject: Reply with quote
chain my main bike to a tree, other bikes chained to main bike and to the chain around the tree
Casper
PostPosted: 16:49 - 20 Feb 2013    Post subject: Reply with quote
But the OP may not have a tree at his new gaff.
PostPosted: 16:57 - 20 Feb 2013    Post subject: Reply with quote
Get down to B&Q and buy a gorilla bucket, 3 bags of ballast and 1 cement. and get yourself a stout chain or a large loop of heavy steel like a mooring ring or heavy shackle. I would use 40-50mm rebar but I can get that easily.
Dig a hole and drop in a gorilla bucket, fill in around hole so the sides press in a bit then throw in a loop of the chain from the middle, mix up your ballast & cement with water and fill the bucket with it. You'll now have a 100kg anchor with chain/fixing point attached that won't pull out of the ground easily but can be dug out and removed if you have to put the garden right.
thx1138
PostPosted: 17:12 - 20 Feb 2013    Post subject: Reply with quote
how very urban Shocked
andym
PostPosted: 17:14 - 20 Feb 2013    Post subject: Reply with quote
I've found having such a hideous bike that kids run past the drive screaming if they see it is helpful... I don't even need to bother chaining it up (or removing the keys from the ignition for that matter).
If you can't dig anything up or find anything solid enough, get an old dustbin (or an old oil drum would be better) and fill it with concrete, put the metal loop in that... it will be enough of a deterrent for most thiefs
LordShaftesbu...
PostPosted: 18:31 - 20 Feb 2013    Post subject: Reply with quote
Seriously, chain it to a second bike, it's what I do. Your own movable ground anchor.
Timmeh
PostPosted: 18:54 - 20 Feb 2013    Post subject: Reply with quote
Just buy some surplus russian landmines from ebayski and attach them to your seat.
no one will dare even fart next to it.
i.p.phrealy
PostPosted: 00:30 - 21 Feb 2013    Post subject: Reply with quote
or buy a push bike D lock and a couple of bags of postcrete, shove the D lock into the wet postcrete until only a few inches of the curved bit stick out, wait until the postcrete sets and Bob's your Mother's Brother!
D locks are a fiver in Tesco, no horse jokes though. Laughing
Walloper
PostPosted: 01:09 - 21 Feb 2013    Post subject: Reply with quote
Pray tell.... Why could Bob only be his mum's Bro?? Confused
Srengam
PostPosted: 08:39 - 21 Feb 2013    Post subject: Reply with quote
Thanks all,
I'm gonna go with the Oxford Brute Force Ground Anchor.
Cheers again.
The last post was made 13 years, 48 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.85 - MySQL Queries: 15 - Page Size: 116.32 Kb
