Dim headlight
andym
PostPosted: 16:56 - 20 Feb 2013    Post subject: Dim headlight Reply with quote
Not really a workshop issue, so figured this would be the best place for it.
Last night I went out about 10pm and still noticed my headlight was a bit dim on dipped, it was fine on streets etc, but part of the motorway was unlit and I couldn't see very far ahead of me unless I used full beam.
At the moment there is an H4 60/55w fitted (allegedly), but to give you an idea of how crap light is, when I turn on the sidelight and then the dipped light they are throwing out about the same amount (just that dipped is a bit more wide spread).
Now I'm considering just buying a brighter bulb to see if that helps any.
Anyone used these bulbs? or is there any that could be recommended?
cimbian
PostPosted: 16:58 - 20 Feb 2013    Post subject: Reply with quote
If battery is okay and charging is okay then look at excessive series resistance somewhere... switch, fuse, relay, wiring or grounding.
22PlusY
Current: Moto Guzzi 1100 Breva. Previous: Honda XL650V TransAlp
Bearded, Balding, Born again Buddhist Biker
PostPosted: 17:29 - 20 Feb 2013    Post subject: Reply with quote
A 60/65 H4 is illegally bright to start with.
Increasding the wattage of the bulb is not going to address this problem, it should be brighter than any standard car headlight.
Your problem is that the current required to light up a 60W bulb is not being supplied for some reason.
What bike is it in?
c-m
PostPosted: 17:42 - 20 Feb 2013    Post subject: Reply with quote
It sounds like your bulb is on the way out. All filament bulbs degrade over time as the tungsten evaporates/burns away. Eventually the filament fails.
Stick in a spare bulb and test with that.
Motorcycle headlight bulbs and HIDs
Blogging about my bike and trips
https://ridershandbook.com/
andym
PostPosted: 18:59 - 20 Feb 2013    Post subject: Reply with quote
cimbian, I tried wiring it direct to a battery and it done the same thing, battery is about 12.5 (ish) v before starting and about 14.5 when revving
Vincent, slightly brighter, but still crap on dark roads
stinkwheel, 60/55 (that's what it says on the bulb anyway), the full beam works as it should, just that the dipped beam is about the same as the side light... also it's the GPz
c-m, the light has been that way since it was put in there, I have a spare bulb which I can try, but I'd have thought bulbs lasted longer than about 3 hours as that's all it's been on for... I'll try the spare bulb though
angryjonny
PostPosted: 19:19 - 20 Feb 2013    Post subject: Reply with quote
Then you either have a duff bulb or a duff battery.
Or cataracts.
reed
PostPosted: 19:22 - 20 Feb 2013    Post subject: Reply with quote
HID kit Smile I fitted one a couple months ago and it is so much brighter. The beam pattern is fine also, fitted in a honda hornet circular headlight
Generic XOR 50, Gilera SMT 50, GSXR 400 GK73A, Ducati Monster 600, Honda Hornet 600.
Sold. Stolen. Written off. Sold. Current.
andym
PostPosted: 19:33 - 20 Feb 2013    Post subject: Reply with quote
angryjonny, I think it must be cataracts then.... I just took the headlight off, used the zxr battery and connected up the spare bulb, spare bulb in the headlight, spare bulb in a different headlight, and they are all the same brightness.
Reed, if the bike was actually worth caring about I might have looked into something like that
The last post was made 13 years, 39 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 61.43 Kb
