Zero release police bike range
Bike Chat Forums Index -> Biking News & Rumours
Sable
PostPosted: 21:06 - 20 Feb 2013    Post subject: Zero release police bike range Reply with quote
https://www.gizmag.com/zero-2013-police-security-electric-motorcycles/26280/
According to Zero, the latter translates to 121 miles (194 km) of city riding per charge, or 74 miles (119 km) at highway speeds for the DS model, and 132 miles (212 km) for city or 83 miles (133 km) highway for the S motorcycle.
I imagine thats good enough for most day to day city police bike work. Don't look to bad either. Thinking
PostPosted: 03:09 - 21 Feb 2013    Post subject: Reply with quote
I find it surprising that city riding distance is so much better than motorway riding. I would have thought the stop start riding would still use more power per mile than continuous smooth open road riding.
Triumph Trophy Launch Edition
PostPosted: 08:47 - 21 Feb 2013    Post subject: Reply with quote
Decent regenerative braking will get you some of that energy back.
These might make sense for plodforce, especially if they can use money from some ecobudget to subsidise them. Resale value will be an issue, i.e. they're unlikely to have any.
map
Mr Calendar
PostPosted: 13:03 - 21 Feb 2013    Post subject: Reply with quote
Looking at the pictures probably intended for use in California.
PostPosted: 13:46 - 21 Feb 2013    Post subject: Reply with quote
Sounds likely, they love greenwashing there.
PostPosted: 13:59 - 21 Feb 2013    Post subject: Reply with quote
Have a look at the power needed to do 30mph - around 3hp.
To do 60mph that bumps up to around maybe 9hp?
Electric engines are a lot more efficient than petrol in 'start stop' due to the 'stop' not being an issue of course.
Low distance in-town stuff is exactly where electric bikes do make sense.
haroman666
PostPosted: 14:03 - 21 Feb 2013    Post subject: Reply with quote
It's the "sat there idling away" bit that makes IC engines lose their MPG. Hence why the likes of Ford have brought out the Stop-start system on their engines.
Electric Motors do jack shit when they're not moving. So no power is being used (Aparts from lights and ancillaries).
I see Zero are jumping on the band-wagon with Brammo then.
https://www.matternetwork.com/images/Matter/brammo-ev.jpg
I've done quite a lot of research on Electric Bikes as it's what my final year uni project is on.
Sable
PostPosted: 14:16 - 21 Feb 2013    Post subject: Reply with quote
GAAAAH! I want to like Brammo but the shape of their bikes makes my eyes bleed and stomach cry. Sick
Nick 50
PostPosted: 23:07 - 23 Feb 2013    Post subject: Reply with quote
Out of interest what generally is the size of an electric motor they use in electric bikes?
I saw a Yasa 400 motor the other day. It's only 28cm by 7.5cm small and generates 120 hp, I couldn't believe it Shocked
I don't think electric bikes start have an impact on the biking market.
haroman666
PostPosted: 23:50 - 23 Feb 2013    Post subject: Reply with quote
https://www.zeromotorcycles.com/powertrains/
If you download the brochure for their motors, you can see pretty much all info about the various motors Zero use.
The motor i'm basing my project on is their ZF9 motor which produces 29hp from a motor that measures 201 x 163mm.
The motors are generally small. It's the batteries that take up all the room.
This is my project with the motor using the Dimensions from the ZF9
https://fbcdn-sphotos-a-a.akamaihd.net/hphotos-ak-prn1/11014_10152082225515288_409139052_n.jpg
The motor being the bit just forward of the shock.
PostPosted: 00:10 - 24 Feb 2013    Post subject: Reply with quote
The motors can be quite small; compared to an ICE they are very simple things generally.
However, they tend to have heat issues developing high peak power for extended periods - that's usually not a big issue as generally the batteries won't last that long anyway.
Not sure if they're doing water cooled varieties, but if they can sort out power supply issues, expect it may well end up going that way - or at least oil cooled.
Also consider that the electronics required tend to be a bit chunkier.
fatboyaquila
PostPosted: 21:04 - 07 Mar 2013    Post subject: Reply with quote
nice bikes but a bit pricey imho. similar problem with most electric cars too but through time hopefully we will see more affordable prices as these hopefully catch on.
live each day as if it were your last!
PostPosted: 21:27 - 07 Mar 2013    Post subject: Reply with quote
The limiting factor is battery technology and that's something that is far from unique to road vehicles.
fatboyaquila
PostPosted: 22:00 - 07 Mar 2013    Post subject: Reply with quote
true and i believe that was a point well proven in a recent top gear program, which also highlighted another problem, the lack of suitable charging points.
haroman666
PostPosted: 23:01 - 07 Mar 2013    Post subject: Reply with quote
Number of charging points isn't necessarily the issue. It's charge time... Sure charge it over-night for the next day. But people dont want to be restricted to X amount of miles and then have to wait 4 hours or more to get the same range over again.
Charge time of electric vs refuel time of an IC engine... No competition really.
I believe this is a reason why charge points haven't been implemented in large numbers yet.
goto10
PostPosted: 23:10 - 07 Mar 2013    Post subject: Reply with quote
If you're using it for a fixed commute then this isn't a problem.
I'm hoping that in ~3 years time there will be an electric bike that can do 100 miles (mixed urban/highway) on a single charge and cost less than £8k - If I'm still commuting by bike then I'd certainly buy one.
I cover ~80 miles a day to/from work and would have no problem plugging my bike in every evening.
PostPosted: 00:03 - 08 Mar 2013    Post subject: Reply with quote
In some ecomental places like Californay and the Whitelee Wind Farm, parking spaces are available with free charging points so that you can charge while you work/recreate/learn where your tax money is going.
Super, great, smashing, but there's a couple of issues with that.
#1 To keep them free for the ecomobiles, they have to be denied to other vehicles.
#2 If you're relying on charging up your ecomobile in order to get home, and some other yoghurt knitter swipes the space, then you're pretty much shafted.
Bit more thought required on that one.
L4Isoside
PostPosted: 00:15 - 08 Mar 2013    Post subject: Reply with quote
I take it a hybrid bike with a small ICE engine for the battery charging is dumb idea? Laughing Embarassed
I mean, at least it could kick in and provide an extra how ever many miles, plus you could just fill that up at a petrol station to get you home and charge it at night or what ever.
PostPosted: 00:26 - 08 Mar 2013    Post subject: Reply with quote
Yes.
But a plug-in hybrid with electric for cheap transport in town and the engine driving wheel as normal for longer distances does make sense to my mind.
goto10
PostPosted: 08:25 - 08 Mar 2013    Post subject: Reply with quote
Yes.
Iirc someone on here made something like that out of a C90, using a hub motor intended for a push bike. (Or they may have linked to the story on another forum)
Sable
PostPosted: 10:27 - 08 Mar 2013    Post subject: Reply with quote
What point did Top Gear prove? Very Happy
PostPosted: 12:11 - 08 Mar 2013    Post subject: Reply with quote
Haven't seen anyone on here, but wouldn't be surprised if it was done - I've certainly mooted similar stuff in the past. C90 makes sense for a town bike as you get decent mpg and it's got a space ready to put the batteries, as well as having skinny wheels already.
Indeed - I thought they showed that if you drive in circles for ages to deplete your fuel, your car runs out of fuel!
Sable
PostPosted: 12:44 - 08 Mar 2013    Post subject: Reply with quote
Top Gear is always going to present contrived trash in line with what the public are currently thinking, they want to stay popular. I still watch it every week and find it hugely entertaining. Just not at all factual Smile If your genuinely interested in electric vehicles, try watching Fully Charged :
https://www.youtube.com/user/fullychargedshow
Long running series of 10 minute shorts by Robert Lewelyn on electric vehicles. He does try to clear up a lot of facts about electric cars, but he is the polar opposite of Top Gear and is very very pro electric car. Some of his most interesting episodes are some of the interviews. Loved the one where they put the Tesla from London to Edinburgh in a day. He does also cover a lot of how the batteries work (yeah I know, snooze to a lot of you! I am interested though! ^^ ).
Watch some of them and aim for an opinion that is about 25% Top Gear / 75% Fully Charged. That's a roughly balanced opinion Smile
PostPosted: 15:26 - 08 Mar 2013    Post subject: Reply with quote
Sable wrote:
Watched a good few of them - a bit too much of a hippy-vlog for me.
Vracktal
PostPosted: 20:04 - 08 Mar 2013    Post subject: Reply with quote
https://www.thehulltruth.com/attachments/dockside-chat/188419d1313861503-damn-prius-owners-m_44250.jpg
Sorted. Cool
2007 BMW R1200R: On road
2009 BMW G650X Challenge: On road
1975 Norton Commando 850: Off road, awaiting recommissioning
The last post was made 13 years, 119 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 1.32 - MySQL Queries: 13 - Page Size: 133.16 Kb
