| Wonko The Sane |
 Wonko The Sane World Chat Champion
 Posted: 15:03 - 20 Feb 2013 Post subject: Do I need a new battery? |
Just tried to start my varadero, it started initially with full choke and quickly slide the choke in once it's fired up, left it to warm a bit but by the time I'd nipped back inside for my helmet it had cut out again (nothing new there)
Tried to re-start it and while it ran on tick over, it just died when applying throttle,
re-starting it flattened the battery.
It's been stood for about a week, outside with a cover on, prior to that, two days of a 40 min ride to, and then 40 min ride back someplace,
before that I had a flat battery after doing a service and checking timing and compression before a 20 min ride home.
So, is it just the cold weather and lack of riding or is it likely I need a new battery?
Cheers ____________________ Looking to pass your CBT / Bike tests in Bury Lancashire? try www.focusridertraining.co.uk Would recommend.
They're also on Facebook https://www.facebook.com/pages/Focus-Rider-Training/196832923734251 |
| Benson_JV |
 Benson_JV World Chat Champion
| map |
 map Mr Calendar
 Posted: 15:37 - 20 Feb 2013 Post subject: |
My advice would be to charge it first.
If you can use a 'recovery' type charger such as Optimate/Accumate (there are others, wemoto do one for example).
My lad's Varadero battery has failed. He didn't really mention this, just a vague "it's iffy" comment. Turns out push starting it is a doddle. Place in 2nd gear, pull in clutch and run with it. then let clutch out and it should catch. Remember to pull clutch in and select neutral before putting on side stand. Also don't set off in 2nd as found it can stall.
He will be getting a new battery. When I put the power pack on it (effectively a 12v jump start battery) I was a bit concerned it would not start at all. Just a click from the solenoid. So crossing fingers starter not fubared. Hope yours isn't. ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
Gibbs, what did Duckie look like when he was younger?  |
| Walloper |
 Walloper Super Spammer
| Wonko The Sane |
| Rogerborg |
 Rogerborg nimbA
 Posted: 10:52 - 21 Feb 2013 Post subject: |
Firstly, thou shalt buy or order thyself a cheap digital multimeter.
Then get it out and (unless it's a magic gel one) have a look at the level of the electrolyte in the cells. There should be clearly marked min/max levels. If any are low, top them up using deionised water, which you should be able to get from a garage or many supermarkets.
Then try charging it with a decent charger. That'll cost you about the same as a new battery, but will be an investment that will stay with you from bike to bike.
If that recovers it, I'd suggest getting a solar trickle charger and wiring that up, especially if it's used occasionally or for short trips. You can get 500mV ones for ~£10 from eBay which are ideal. ____________________ Biking is 1/20th as dangerous as horse riding.
| Snorty |
 Snorty World Chat Champion
| Wonko The Sane |
| Wonko The Sane |
 Posted: 19:22 - 21 Feb 2013 Post subject: |
Right, battery is inside overnight instead of out in the cold,
hoping that it'll have enough power in it for one attempt at starting.
failing that I have jump leads.
I need to know, I've jump started cars many times but never a bike.
Some people say you should have the car lights on when removing the leads so that it doesn't damage any relays or fuses, anything similar with bikes?
Is it ok to jump start a bike from a car? The car is standard 12 volts, the bike's battery says 12v so I'm assuming it's all ok? ____________________ Looking to pass your CBT / Bike tests in Bury Lancashire? try www.focusridertraining.co.uk Would recommend.
| Snorty |
| kawakid |
 kawakid World Chat Champion
| Walloper |
| kramdra |
 kramdra World Chat Champion
| Wonko The Sane |
The last post was made 12 years, 290 days ago. Instead of replying here, would creating a new thread be more useful? |
