Need help with filling reservoir tank with coolant
bklynvx1
PostPosted: 23:06 - 16 Nov 2004    Post subject: Need help with filling reservoir tank with coolant Reply with quote
The reservoir tank on my bike is empty and I need to fill it up with coolant. Does it matter what kind of coolant I use? I have a bottle of Prestone Antifreeze/Coolant and I was wondering if I could use that and also how much do I put in and how much of it do I have to mix with water?
mr jamez
PostPosted: 23:07 - 16 Nov 2004    Post subject: Reply with quote
50/50 mix is yer man Wink Unless the instructions on the bottle specificaly tell you otherwise, I always do 50/50 on the car and bike.
PostPosted: 23:13 - 16 Nov 2004    Post subject: Reply with quote
Read the back of the bottle. It should say words to the effect of "suitable for use in aluminium engines", if it does, carry on. It should also tell you on the label how much water to dilute it with for certain temperature ranges, err on the side of a stronger mix. Some are 'ready to use', just put this straight in.
bklynvx1
PostPosted: 23:23 - 16 Nov 2004    Post subject: Reply with quote
Yes it says it protects aluminum and all other engine metals so that sounds good. I'm going to go do this now. Thanks for your advise guys!
The last post was made 21 years, 303 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.86 - MySQL Queries: 13 - Page Size: 39.44 Kb
