zx6r being naughty
Vase
PostPosted: 22:00 - 21 Feb 2013    Post subject: zx6r being naughty Reply with quote
my zx6r 97 is driving my mad now.
i had a recent problem with it not getting any fuel, turned out i needed a fuel pump repair kit.
thats all sorted now, my new problem is now when it runs it is misfiring heavily and also throws in some very loud backfiring and popping from the exhaust mainly when reving it as it wont idle on its own.
note the bike ran perfectly fine before the fuel pump packed in.
only other things i had done when it first stopped was changed the spark plugs and air filter.
i have checked the plugs and all are sparking as they should, checked all the leads on each individual plug and nothing seems out of order.
also the carbs were run dry originaly when the fuel filter fault happened.
so i ask could a dirty carb cause backfiring? if not then any other suggestions?
cheers
Current : zx6r f3
Previous : gsf400
FullOnFazer
PostPosted: 01:07 - 22 Feb 2013    Post subject: Reply with quote
Sync'd the carbs up properly recently? Might be worth a look mate
Edit - dirty carbs = bad running. Simplest step is to check carb sync if you've got the tools, then messing about dismantling n cleaning ect.
33bhp Yamaha Fazer FZS - Thats how full on.
Vase
PostPosted: 18:24 - 22 Feb 2013    Post subject: Reply with quote
Carbs avnt been synced whilst I've had it but since the problem started it has been stood for around 2 month as gettin time off has been difficult.
I'm gonna strip carb off tonight anyways and hopefully will find something blocked.
1 thing I haven't checked is the actual fuel flow, I can't see any obvious way of priming the system , is there a trick to it?
Current : zx6r f3
Previous : gsf400
Fisty
PostPosted: 00:35 - 23 Feb 2013    Post subject: Reply with quote
Are you sure you have the HT leads on the correct plugs?
Fatter and faster than Fret
Vase
PostPosted: 23:12 - 23 Feb 2013    Post subject: Reply with quote
Hi, I'm fairly sure the leads are the correct way around. What sort of volts should I expect roughly on the leads as il borrow a multi metre tomorrow and jam it down them!
In the mean time il try and find a picture of a engine to check the leads position
Current : zx6r f3
Previous : gsf400
BigGeeking
PostPosted: 08:56 - 24 Feb 2013    Post subject: Reply with quote
Don’t use a DMM on the end of a HT lead to check for volts it will hurt and break your meter.
You should only check the resistance on the output of the coils.
Bendy "Flip front. I can filter down the M4 while shoving a Twix in my face."
honda CG 125 2001 SOLD-- current Bandit 400--SOLD. current SV650s 2000
MOD 1 ON 20/7/2011**passed** MOD 2 ON 17/10/2011***passed***,,
Vase
PostPosted: 18:12 - 03 Mar 2013    Post subject: Reply with quote
Hi sorry for the slow update but I'm still fighting with it!
I had the carb off, cleaned it all out , put it back together.
It now seems I'm getting no fuel, I bypassed the tank and tap by rigging one up, the pump seems to get power (sometimes) when i flick on the ignition but not all the time and nothing when turning over,
I tested it with a spare relay.
Is there anything else that can cause intermitant power to the pump? Does the cdi get involved?
( already had a pump kit fitted)
Doing my head In now as I rarely get chance to look at it like its taken me almost 2 weeks to take the carb off, clean them and put them back on!
Current : zx6r f3
Previous : gsf400
The last post was made 13 years, 40 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.87 - MySQL Queries: 13 - Page Size: 61.52 Kb
