Should I buy new tyres?
JiveBunny This post is not being displayed because the poster is banned. Unhide this post / all posts.
Islander
PostPosted: 20:52 - 22 Feb 2013    Post subject: Reply with quote
Don't you get bored with the obvious trolling?
tracks
PostPosted: 20:55 - 22 Feb 2013    Post subject: Reply with quote
No. Keep riding on them till they pop.
Islander
PostPosted: 20:56 - 22 Feb 2013    Post subject: Reply with quote
If you're not trolling then you're headed for a shitload of points or a very serious accident if you carry on the way you are.
Based on your past endeavours at DIY mechanics, get it done professionally.
arry
PostPosted: 21:01 - 22 Feb 2013    Post subject: Reply with quote
OP is just priceless; this and the last thread are comedy gold
kestrel
PostPosted: 21:09 - 22 Feb 2013    Post subject: Re: Should I buy new tyres? Reply with quote
JiveBunny wrote:
For my Daelim I have done 16700 miles on the ones what came with it they look bald but no sign of the metal bits coming through yet like they did on my R6 back tyre.
The handling does feel awful especially in the wet but how safe are they?
JiveBunny wrote:
I'm not trolling I can post pictures.
Unbelievable...........
Isle of Man.........Road Racing Capital Of The World
Snorty
PostPosted: 21:11 - 22 Feb 2013    Post subject: Reply with quote
They're not dangerous until the cord is showing all the way around the tyre.
polar
PostPosted: 21:14 - 22 Feb 2013    Post subject: Reply with quote
let the pictures do the talking
Supermoto_Fan
PostPosted: 21:16 - 22 Feb 2013    Post subject: Reply with quote
The same talking those R6 picture were doing.. Right..
c_dug
Custard test.
polar
PostPosted: 21:21 - 22 Feb 2013    Post subject: Reply with quote
you should not ride the fucking thing if they are that bad.
get the bus
grow up
kerr
PostPosted: 21:24 - 22 Feb 2013    Post subject: Reply with quote
These young trolls dont even try nowadays do they?
aprilia 125 Af1 Futura >> Suzuki gsxr 600 srad >> J1 zx6r >> cbr 600rr >> Speed Triple
Nick_Giles
PostPosted: 21:41 - 22 Feb 2013    Post subject: Reply with quote
JiveBunny wrote:
If I let him go ahead with the work where do I stand as to getting my key back and not paying him?
You probably won't be standing.
More like face down in the gutter with a broken nose. Very Happy
On a separate note is that your skirt in your avatar snap with you.? Shocked
Nick
angryjonny
PostPosted: 21:44 - 22 Feb 2013    Post subject: Re: Should I buy new tyres? Reply with quote
JiveBunny wrote:
For my Daelim I have done 16700 miles on the ones what came...
That's one of those scooters that folds up that yuppies used to ride around Holborn, right? One of those where the brake is a metal plate over the back wheel that you stand on.
I wouldn't worry about it, the tyres are transparent solid rubber and never had any tread on them to begin with. When you hear a grinding noise it means you're down to the rims. Just pop into Argos and get a new scooter.
angryjonny
PostPosted: 21:51 - 22 Feb 2013    Post subject: Reply with quote
If your question is actually serious...
Is there at least 1mm of tread on both tyres? Yes... you're legal. No... you're illegal.
Will <1mm kill you? Not immediately no, but it'll wear down to nothing in no time but not evenly. There will be patches that are balder than others and when one of those hits a wet patch you'll bowl your bike down the road before you realise what's going on. The longer you leave it, the greater the risk.
You'll get 3 points per illegal tyre if you're pulled over. Though I'd be amazed if you had a licence to have 6 points put on.
Nick_Giles
PostPosted: 22:00 - 22 Feb 2013    Post subject: Reply with quote
JiveBunny wrote:
FFS - Promise us not to ever breed. Sad The result of a copulation between a Piss Piggy and Millhouse (Simpsons) 'look-alikes' would be an offensive visual obscenity to humanity. Confused
So use a rubber.! New ones. Thumbs Up (see what I did there.? Brought it back on topic with a ref to new rubber. Wink )
Nick
angryjonny
PostPosted: 22:03 - 22 Feb 2013    Post subject: Reply with quote
Tread levels won't affect the handling in the dry. In the wet with no tread you'll skitter all over the place and throw the bike at the ground. But in the dry, technically, slick rubber is the best because you have the greatest surface area touching the ground (best grip) hence slick tyres on F1 cars.
If your handling is bad check your tyre pressures. If they're low the bike will handle dreadfully. Not got a pressure gauge? Then pop into Halfords and get one, and get a tread gauge while you're in there.
The handling may be bad if you've squared off the tyres... it'll drop less readily into corners and it'll be like riding on a knife edge when you're leaning it.
Ropey suspension is also a reason for bad handling. If your forks are leaking then that could easily be a factor yes. But pumping up your tyres is much cheaper.
angryjonny
PostPosted: 22:19 - 22 Feb 2013    Post subject: Reply with quote
You often need to put air in your tyres in the winter as the cold weather causes air to contract so the pressure goes down. In a car it doesn't make too much difference. On a bike it really does.
Fisty
PostPosted: 22:23 - 22 Feb 2013    Post subject: Reply with quote
She looks like a bag of smashed crabs.
Fatter and faster than Fret
The last post was made 12 years, 364 days ago. Instead of replying here, would creating a new thread be more useful?
Goto page 1, 2, 3, 4  Next
Page 1 of 4
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 1.25 - MySQL Queries: 13 - Page Size: 131.88 Kb
