| irish |
 irish L Plate Warrior
| mr.z |
 mr.z World Chat Champion
 Posted: 01:40 - 17 Nov 2004 Post subject: |
There could be an air leak somewhere allong the line, if not enough air is getting to the air fuel mix you will get fouled plugs, if you get some wd40 (with the tube bit on) and spray into joins on your inlet side, if the revs rise then you know there is a leak!
It could also be down to your plugs not giveing off a good enough spark, if they are gapped properly and new then the leaves your ignition system, coils or HT leads, ht leads are not all that much money so i'd try them second...
Of course your fueling might be allll wrong, but i'm sure any competant mechanic would have thought of that (unless of course your buying spark plugs from them )
theres probably allot of other things it could be but i'd try them for starters... (i'm haveing a similar thing myself, but not as extreme) ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
| Bomberman |
 Bomberman World Chat Champion
 Posted: 02:16 - 17 Nov 2004 Post subject: |
I was needing to replace plugs on my TZR every three days Turned out that the 2-stroke oil pump had jammed on full and needed replacing.
Just yet another possibility for you to think about  ____________________ 'Allo! My name is Inigo Montoya, you killed my father, prepare to die!
'89 TZR 125 - '94 GPZ500s - ZK3 GSXR600 Alstare  |
| mchaggis |
 mchaggis World Chat Champion
| RS1Banger |
 RS1Banger Scooby Slapper
| alains |
 alains World Chat Champion
 Posted: 16:01 - 22 Nov 2004 Post subject: |
go to https://www.sparkplugs.co.uk and buy BR9EIX , they are expensives (£6.84 ex vat) but 3 times longer life and 3/4 l petrol spare on each full tank . engine running much better . ____________________ the worst day fishing is better than the best day working |
| Dru2000d |
 Dru2000d Nova Slayer
The last post was made 21 years, 328 days ago. Instead of replying here, would creating a new thread be more useful? |
