DANGEROUS surface M27...
Bike Chat Forums Index -> Biking News & Rumours
NeiljohnUK
PostPosted: 15:17 - 24 Feb 2013    Post subject: DANGEROUS surface M27... Reply with quote
https://www.powerplane.co.uk/case-studies/m27-concrete-retexturing-mac-area-3
Following the above work, where they milled the surface longitudinally, not transversely as specified in the Highways Agency documents, the M27 between J7 and J5 now has a 'tram-lining' surface, the deep/wide groove left by a mis-set milling head is clearly visible when dry, but invisible after heavy rain, which doesn't drain as well either.
EnterpriseMouchel are supposed to 'maintain' the road in a safe state, but profit above safety seems to be what's driven this. The off slip at J5 West bound is particularly bad, with the milling machine leaving criss-crossed curved grooves that change direction and make a bike very twitchy, my Land-Rover is also affected, its THAT bad!
The other effect was to mash the slab edges, so the overbanding is now 4" wide, not a nice 10mm filled slot...
They intend to push this out as an answer to 'polished' concrete nation wide, so if anyone is able to high-light the dangers to the H.A. of allowing it, rather than doing it transversely, please do so.
TT_Man
PostPosted: 09:48 - 25 Feb 2013    Post subject: Reply with quote
Took a close look at this last night (in the car). Your right quite a deep gulley on all 3 lanes where one of the grinding heads is set too deep. Think I'll use the backroad upto the m3 in the wet on the bike!
Thanks for the heads up!
supZ
PostPosted: 10:45 - 25 Feb 2013    Post subject: Reply with quote
report it!
www.fillthathole.org.uk
CBR954RR - Daily toy
CBR600RR - Trackbike
kramdra
PostPosted: 14:10 - 25 Feb 2013    Post subject: Reply with quote
It appears to be a trail, you sould contact the Highways Agency. if none complains it will be sucsessfull.
UnspeedySam
PostPosted: 14:54 - 25 Feb 2013    Post subject: Reply with quote
The M27 has been pretty poor for a while now. I used to commute down the section and filtering between lanes 2 and 3 is pretty hairy due to the 'hump' between lanes.
Do you know the date the work was carried out?
Redoko
PostPosted: 15:21 - 25 Feb 2013    Post subject: Reply with quote
supZ wrote:
I find that link to be much more funny than I should.
supZ
PostPosted: 15:35 - 25 Feb 2013    Post subject: Reply with quote
Redoko wrote:
i have been known to giggle when typing it out it has to be said Very Happy
but it is a damn good site to use. report em, upload pics etc.. and it automatically gets forwarded to the correct authority to investigate. i've had great success reporting problems and seeing them fixed not too much later
Marmalade
PostPosted: 17:05 - 25 Feb 2013    Post subject: Reply with quote
I hit a pothole in August. Reported it twice and it got filled in Feb.
Like a thunderbolt from the heavens.
The last post was made 13 years, 129 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.11 - MySQL Queries: 13 - Page Size: 58.1 Kb
