GPZ fork seals
Gazz
PostPosted: 19:42 - 24 Feb 2013    Post subject: GPZ fork seals Reply with quote
Needing some help with this....
I have removed the fork, then dismantled it as far as I can. Removed the spring, the washer on top of the old seal and the funny shaped retaining wire but I cannot pull both parts apart.
Is there another washer inside there?
Casper
PostPosted: 20:25 - 24 Feb 2013    Post subject: Reply with quote
Yip the stanchon is attatched to the folk lower. Taper a broom handle and ram it down the centre and undel the lower leg you should see a allan bolt needing turned.
Bit like this
https://www.youtube.com/watch?v=8cSYiIl8gQk
andym
PostPosted: 22:03 - 24 Feb 2013    Post subject: Reply with quote
Or if you have the forks off then just put a screwdriver through the seal and lever them off and save dismantling the whole thing (unless you need to check the condition inside that is)
Casper
PostPosted: 22:20 - 24 Feb 2013    Post subject: Reply with quote
Now i like quick or cowboy jobs but i have never did that. Using the correct tool you are just as quick to split them and clean them out proper.
The last post was made 13 years, 11 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 38.81 Kb
