Fucked up! GPZ forks
Gazz
PostPosted: 22:08 - 25 Feb 2013    Post subject: Fucked up! GPZ forks Reply with quote
Trying to do a set of fork seals on a GPZ600R but have managed to make an arse of it and I currently have both forks in individual bits. I have damaged the new fork seals (they were very tight to fit into place) and I have also lost a washer as well. I have 3 washers, 2 of them are bent - dont know how they got like this. So I am assuming that I am missing one and dont know where they go either because I am a dick!
Just ordered some more seals from a different supplier in case they parts I ordered were the wrong size. The old seals slot into place fine. However I couldnt get the upper washer over it and the clip in place though, hence dismantling everything again in an attempt to put it all together again.
And now I cannot get the bush to go inside the fork, when it was going in before.
I have come across this website:
https://www.gpzzone.co.uk/acatalog/Front_Forks_A1_A6.html
Can someone please have a look at it and see what washers I need to buy and where do I put them?
Also, what does the air valve do - as some bikes dont seem to have this part?
Any help muchly appreciated.
Gazz
PostPosted: 22:09 - 25 Feb 2013    Post subject: Reply with quote
Furthmore, what does the air/oil balance thing do as well ?
All this stuff seems very technical for a 23 year old bike.
PostPosted: 22:22 - 25 Feb 2013    Post subject: Reply with quote
Can't help with the specifics.
The air valve does pretty much fuck-all. Don't worry about it.
Some of the washers in forks are supposed to be bent.
What you need is an exploded diagram and a workshop manual. You also need a seal driver (known to the rest of the world as a length of plastic waste-pipe).
I strongly suspect you didn't have the bushing fully seated before trying to bump the seal down on to of it.
Do they have anti-dive?
Ja7
PostPosted: 22:43 - 25 Feb 2013    Post subject: Reply with quote
Edit post
Ja7
PostPosted: 23:06 - 25 Feb 2013    Post subject: Reply with quote
Page 89 there's a diagram of the forks hope this helps.
https://dl.dropbox.com/s/7bkdaesfisoeopk/Kawasaki%20GPX600%20EX600%20GPZ600%20Ninja%20600%20R%20Parts%20List%20Diagram%20Manual.pdf?token_hash=AAEOC7hxNMWYB5aYtX6bvO03FA1ehiN0eSIO8OKP-LYMwQ&dl=1
Gazz
PostPosted: 08:13 - 26 Feb 2013    Post subject: Reply with quote
I tried to flatten the bent washers straight.
You could be correct. I tried pushing the seal in and then used the old seal and top washer as a guard and put the other fork on upside down (to act as a driver) and bashed the 2 forks together. And this was how I managed to burst the new seal.
This was also the reason that I ended up with both forks stripped down at the same time. I was planning on doing them individually but I thought I could use the other fork to force the seal in.
I have no idea what anti-dive is.... Although I have heard of it - probably when researching how to do these.
The thing that annoys me, is that I actually done a set of fork seals years ago on an old Hyosung bike but cannot remember stripping it down as far as I have with this bike.
Cheers for the replies guys. I'll give karma when I get on a computer.
Gazz
PostPosted: 15:45 - 26 Feb 2013    Post subject: Reply with quote
Update. Just went home after work, went into the garage to organize all the parts so that I had 2 of every part and put them all nicely together and low and behold I have lost another fucking washer!!!
This is getting beyond a fucking joke. I want to punch myself in the face but worry about people asking; 'how did you do that?' I am fucking useless.
Anyway, could someone possibly find me the washers that I need on a site somewhere that I can by them from? I think all the other parts are there - except the new fork seals which will be coming in the next day or 2.
The last post was made 12 years, 362 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 52.54 Kb
