CG Popping Bulbs - electrical voodoo i tells ya!!
mudcow007
PostPosted: 19:28 - 26 Feb 2013    Post subject: CG Popping Bulbs - electrical voodoo i tells ya!! Reply with quote
right getting near the end (hopefully) of my CG rebuild
just plugging all the wires into the headlight case (the rats nest) plugged the headlight in an it lit - which was nice
however after about 10secs it popped
the bike was running at the time so i put my voltmeter across the + - leads from the bike to the battery (the battery was connected when the bulb popped but i disconnected when i was testing with me volt meter) which was only reading between 5 - 6v?!
the bike is 12v - its a BR-E
im guessing it is the rectifier going on other threads on here?
is there a way of checking what voltage i'm getting from the generator?
all of the wires are not yet plugged into the headlight so its possibly the low voltage is due to that....or is it?!?
thanks
kramdra
PostPosted: 23:12 - 26 Feb 2013    Post subject: Re: CG Popping Bulbs - electrical voodoo i tells ya!! Reply with quote
Headlight wiring is possibily AC rather than DC, explaining your shit reading. Put the battery back, try again. A low voltage will not kill bulbs. Id say vibration or too high voltage, or old fatigued bulb.
Summary: CG's are shit Laughing
Cyclingbiker
PostPosted: 23:19 - 26 Feb 2013    Post subject: Reply with quote
Check the voltage from the yellow wire that connects to the switchgear. That yellow wire is the direct AC feed for the lights from the generator. It will read fairly low on idle and rise with the revs, that's why the lights on a CG get brighter the faster you go.
Honda CB500s (1999) - Honda CG 125 BR-J (1991)
Mod 1 - Passed - 12/11/12 --- Mod 2 - Passed - 26/11/12
_mjs_
PostPosted: 10:27 - 27 Feb 2013    Post subject: Reply with quote
Could just be shit bulbs. The rear light on my CB500 blew a while ago so I went to Halfrauds and bought a twin pack of bay15d for I think £3.99. Both popped as soon as I turned the ignition on. I went back in to complain and was told by the fat whore behind the counter 'the problem must be with your bike'.
In desperation I went back into the store and bought a 'heavy duty' bay15d for £2.99 and lo and behold it's still working today!
The fat whore would not refund me for the first set of bulbs so I accidently knocked over the satnav display on the way out and refused to refund said fat whore for any damage; because 'the problem must be with your display'.
So yeah, try another bulb Laughing
treeno
PostPosted: 10:37 - 27 Feb 2013    Post subject: Reply with quote
Can confirm the headlight is AC directly from the generator. Check the voltage between the yellow/blue (whichever feeds the headlight, check the wiring diagram) and green and make sure your multimeter is on AC and let us know. Probably a rubbish bulb to be honest.
PostPosted: 10:49 - 27 Feb 2013    Post subject: Re: CG Popping Bulbs - electrical voodoo i tells ya!! Reply with quote
thanks
Is the ballast resistor* plugged in? And all the bulbs?
You need all the bulbs connected, including the taillight and speedo lights.
A direct lighting model CG125 provides an unregulated AC output to the lighting circuit. If there isn't sufficient draw to soak up all the current, it'll pop the bulbs one at a time.
* Usually a coil attached to the bottom yoke, just behind the little plastic "Honda" grille thing. Pink wire.
Alpha-9
PostPosted: 12:36 - 27 Feb 2013    Post subject: Re: CG Popping Bulbs - electrical voodoo i tells ya!! Reply with quote
stinkwheel wrote:
thanks
Shocked
Stinkwheel you are an absolute fountain of knowledge Thumbs Up
Fzr-600 1999
mudcow007
PostPosted: 12:49 - 27 Feb 2013    Post subject: Re: CG Popping Bulbs - electrical voodoo i tells ya!! Reply with quote
stinkwheel wrote:
thanks
erm...
if i'm completely honest i just had the bike running an was plugging wires in one by one (matching their colours)
i will check tonight what i already have plugged in etc
thanks all!!!
mudcow007
PostPosted: 19:41 - 15 Apr 2013    Post subject: Reply with quote
sorry to resurrect this thread
i cant find no pink wire?!
the bike is now fully wired up (except the horn an pilot light - which i cant figure out where its wired to)
fitted spanking new headlight an bike pops the bulb within about 20seconds
Haynes reckons its a possible bad earth?
mudcow007
PostPosted: 21:45 - 15 Apr 2013    Post subject: Reply with quote
cheers all
just looking at pic of my genny
https://i25.photobucket.com/albums/c81/mudcow007/20130316_170127_zps052f78b0.jpg
cant really spot a pink wire..
i will whip the strator off tomorrow an check it out
so where does the other end of the pink wire go - to a coil on the headstock?!
YBR Ric
PostPosted: 17:41 - 16 Apr 2013    Post subject: Reply with quote
that oil seal looks as if its in inside out Rolling Eyes
mudcow007
PostPosted: 08:58 - 17 Apr 2013    Post subject: Reply with quote
ahh sorry old pic, its the other way around now
Cyclingbiker
PostPosted: 15:40 - 17 Apr 2013    Post subject: Reply with quote
If yours is one of the 12v Brazil models it won't have a pink wire, nor a ballast resistor, apart that is from the BR-S/T from 1995 onwards. They were absent from the BR-E/F, J and K models according to the Haynes manual.
HTH Thumbs Up
mudcow007
PostPosted: 20:30 - 17 Apr 2013    Post subject: Reply with quote
HTH Thumbs Up
cheers!
it gets confusing as the engine is a BR-E but frame is earlier so the wiring maybe from a 6v an the engine is 12v
makes ordering parts difficult
mudcow007
PostPosted: 08:04 - 18 Apr 2013    Post subject: Reply with quote
the engine is still old, way before cdi - its still rocking points!
i had the bowl off the headlight last night to see if i can figure something out, one thing i did discover was i had two wires not connected to anything
one green, one red - these both come from the right switch gear (wires come from kill switch)
the red is live when the switch is turned to on (an the bike running) green is dead so i'm guessing its an earth
i wouldn't mind trying to get the kill switch to work seeing as its there..anyone any ideas what i could rig up?
Karma
mudcow007
PostPosted: 13:08 - 18 Apr 2013    Post subject: Reply with quote
yap that explains why when i bought the bike it had no ignition/ key but would still start
im going to disconnect everything in the headlight tonight an check where each of the earths are connected
could it cause issues if say the indicators are using the same earth (plugged into the same earth plus) as brake switch?
i think its deffo the wrong r/h switch gear as it has a hole for a 2nd throttle cable, which i seriously doubt a CG ever had...
im desperado to get the thing back on the road, sorn is up at the end of the month
cheers
mudcow007
PostPosted: 08:15 - 23 Apr 2013    Post subject: Reply with quote
**Update**
my bike is due for an MOT on Saturday, so took it to my mates garage last night for it to be checked over.
i mentioned the headlight an tail light popping after a few seconds.
after a couple of checks they have found the headlight/ tail was lighting off the coil, creating a pulse hence why i couldnt get a reading with my voltmeter
now i have to figure out why
i thought CG's were simple!!
mudcow007
PostPosted: 08:12 - 24 Apr 2013    Post subject: Reply with quote
cheers for the reply, i couldnt attack my wires last night as i had to replace the handbrake on my Transit connect
tonight feels like an rewire night!
gracias Karma
Cyclingbiker
PostPosted: 16:00 - 24 Apr 2013    Post subject: Reply with quote
I have found this wiring diagram very useful in my never ending quest to get the bike running for more than a week without breaking down Twisted Evil
It is just the Haynes Manual diagram that someone on here has cleverly coloured in with the right wire colours to make it more obvious what goes where. As you can see the Yellow wire comes off the coil on the stator, heads to the rectifier but splits and sends current to the headlight/tail light/pilot light/high-beam idiot light when they're on. No regulation of current, just straight AC pulsating voltage Thumbs Up
EDIT: Just had a brainwave after I did something stupid the other night which resulted in 3 out of 4 bulbs on my CG blowing. I accidentally disconnected the rectifier when I was working on the headset bearings which meant there was no outflow for the current from the stator. It was all channeled through the yellow wire where it splits before the rectifier and was sending 30+ volts through the headlight circuit and blew everything with a touch of the throttle apart from the idiot light for the high beam. It meant I had to buy a new halogen bulb (£6.50), new pilot bulb (£1) and stop/tail light (£1.50) Doh!
Just make sure of the two wires coming from the generator to the wiring loom that the white one if definitely connected and that the rectifier is plugged in firmly. I have an inkling that this could maybe be your problem too. A quick AC voltage test on the yellow wire inside the headlight could confirm it. Usually voltage should be no higher than 12-15 even when revving it but it easily spiked above 20 volts with just a light touch on the throttle.
HTH Thumbs Up
https://cdn.bikechatforums.com/files/cg125_157.jpg Doh!
mudcow007
PostPosted: 18:21 - 24 Apr 2013    Post subject: Reply with quote
cheers biker i will check it out
i have kinda put the electrics ont he back burner this week an im attacking the forks...
i will keep you posted when i electrocute my self
thanks
The last post was made 12 years, 249 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.18 - MySQL Queries: 13 - Page Size: 136.76 Kb
