Ingrowing Hair and General shaving Advice
james1988
PostPosted: 21:00 - 26 Feb 2013    Post subject: Ingrowing Hair and General shaving Advice Reply with quote
Hello,
For years I'd been shaving with Gillete and Wilkinson sword razors but at Christmas time I was bought a Safety Razor (Merkur Futur) and Badger Brush( Badger Brush).
The Gillette and Wilkinson Sword razor caused (probably poor technique too) me to have ingrowing hairs in my neck. The double edged razor and brush - for the most part - have eliminated this but there is still a patch on the side of my neck that I'm really having difficulty getting rid of.
I've tried using a toothbrush and going across the grain and against it but this hasn't worked. It's really annoying me at the moment as it's the only part of my neck that I haven't been able to remove the ingrowing hairs.
My routine is as follows:
Badger brush placed in hot water while I shower
Shower
Lather up my face and neck with soap using the Badger Brush (making sure it's hot) using a swirling action.
Shave. If there is no soap on the area then there's no shave.
Repeat another once
Rinse with cold water
Pat dry
Apply after shave balm.
Does anybody have an idea of where I'm going wrong? I've not been pulling the skin taught as I'd read somewhere not to do it as it can cause ingrowing hairs.
Finally, the razor came with instructions stating that the moving parts should be kept oiled (it's adjustable). What oil do I use? 3 in 1 or a razor specific oil?
Any advice would be appreciated.
James
Tungtvann
PostPosted: 21:08 - 26 Feb 2013    Post subject: Reply with quote
Dug out my Merkur the other week to give it a go, took my time, did all the prep and still butchered my face! Back to the über expensive gilette pro fusion super majiggy mach 12 glide.
Sorry, I can't even shave my own face, let alone yours! Laughing
Supermoto_Fan
PostPosted: 21:11 - 26 Feb 2013    Post subject: Reply with quote
Gilette razor, (vibrating one Twisted Evil Wink ) Gillette shaving gel, sorted.
soap work nearly as well. I find the key is too get my razor warm/hot, when its cold i can feel it tug more.
or, just grow a beard.
J.M.
PostPosted: 21:19 - 26 Feb 2013    Post subject: Reply with quote
Eh? When I shave it's literally just
- dip disposable razor in hot water
- shave
- repeat until done
Or if I'm feeling particularly lazy... Dry shave and remove hairs from razor.with fingers.
2004 R1 & 2018 XSR900
Tungtvann
PostPosted: 21:21 - 26 Feb 2013    Post subject: Reply with quote
- shave
- repeat until done
Some of us have faces as soft as a baby's foreskin unfortunately.
That sounds really wrong, I have no idea how soft a baby's foreskin may actually be.
james1988
PostPosted: 21:27 - 26 Feb 2013    Post subject: Reply with quote
3.5 on the first pass and then 1 for the second. Unless I don't shave for quite a few days and then use it on 5 first.
Rowey
PostPosted: 21:30 - 26 Feb 2013    Post subject: Reply with quote
I was always told to use an exfoliant to prevent ingrowing hairs.
When I used to wet shave I would shower to get my face wet and the pores open, then use a face scrub, then shaving gel, shave and rinse off with warm and then cold water.
I rarely wet shave now any way. Got one of those new electrickery things. Much quicker, no irritation but not as close.
ZX6R C6F.
PostPosted: 22:00 - 26 Feb 2013    Post subject: Reply with quote
Stopping shaving is the solution to all of the problems you hve articulated in this thread.
Someone had to say it.
nowhere.elysium
The Pork Lord
PostPosted: 22:29 - 26 Feb 2013    Post subject: Reply with quote
Beat me to it.
Be a man, man.
mysterious_rider
PostPosted: 22:43 - 26 Feb 2013    Post subject: Reply with quote
The only thing you should be using to shave is hair clippers. You get a nice bit of growth it leaves behind. None of this razor malarky...
Manface will ensue. Laughing
KAWASAKIIIII
hmmmnz
PostPosted: 00:56 - 27 Feb 2013    Post subject: Reply with quote
yep clippers ftw, i havn't been clean shaven since i was in the army,
and that was 13 years ago, never had an ingrown hair
the humans are dead
I kick arse for the lord
james1988
PostPosted: 08:07 - 27 Feb 2013    Post subject: Reply with quote
I look a twat with a beard. Laughing
James
Flatbadger
PostPosted: 13:29 - 27 Feb 2013    Post subject: Reply with quote
Tweezers! Dig the feckers out.
I got 100 Derby blades off ebay and that's me done for 15 years! Excellent stuff.
You're in ISIS
J.M.
James
You'll get used to it.
I always hated myself with one. Then I grew one to get me laid (this chick loved them). Then decided I actually loved how it looked and it's not left my face since.
Okay, once. I was too lazy to trim so I shaved and let it grow back.
EazyDuz
PostPosted: 14:46 - 27 Feb 2013    Post subject: Reply with quote
My shaving is incredibly cheap and affective.
I use a wilkinson sword classic, pack of blades from Wilko is about 35p, shaving balm is about 40p and lasts about 6 months. Shave brush about 60p which i bought 2 years ago and still works fine.
I get my face warm with hot water using the brush. Rub the balm on my face, wet the brush then flick it once, then massage the balm into my face. Shave one pass with the grain.
Remove balm with brush then re-apply, shave again second pass against the grain.
Rinse, pat dry, apply moisturizer and loads of aftershave.
I get no ingrown hairs except one which is always in the same place on the right side of my chin.
https://www.bruceonshaving.com/wp-content/uploads/2010/12/Wilkinson-Sword-Classic-Double-Edged-Razor-3.jpg
pepperami
PostPosted: 17:15 - 27 Feb 2013    Post subject: Reply with quote
Ingrowing hair?.............................. Cut your head off !................ problem solved Smile Thumbs Up
mr jamez
PostPosted: 17:22 - 27 Feb 2013    Post subject: Reply with quote
Single blade disposables are useless for me, but I might give that a go. I've got a mach 3, you can strop the blades when the edge goes to give them a much longer life. All that stuff about chucking them in the bin after the stupid blue strip goes is madness Shocked
Flatbadger
PostPosted: 21:49 - 27 Feb 2013    Post subject: Reply with quote
EazyDuz wrote:
That's my razor! Except mines got years of soap scum on it..
Hot water, soap stick lather with brush, shave with grain, hot rinse, cold rinse.
Balms tend to build up as the Christmases go by..
You're in ISIS
EazyDuz
PostPosted: 22:07 - 27 Feb 2013    Post subject: Reply with quote
Yea mine gets pretty shit up and clogged with old hair and all sorts.
Use an old toothbrush to clear it all away and it will look and perform like new.
It was like £5 brand new with a few blades.
Flatbadger
PostPosted: 06:55 - 28 Feb 2013    Post subject: Reply with quote
And then how do we clean the toothbrush?
https://s23.postimage.org/55xggwf7v/5010020_std.jpg
You're in ISIS
EazyDuz
PostPosted: 07:56 - 28 Feb 2013    Post subject: Reply with quote
Use said toothbrush to clean bike chain Smile
andym
PostPosted: 09:21 - 28 Feb 2013    Post subject: Reply with quote
I had to look up what a merkur futur was.... seriously though £50 for a razor Shocked (always wanted to try one though)
I've had my mach 3 for a few years now, when I buy a new pack of blades I'll use the first 3 within a month or so then try stringing the last one out for another 4-5 months for some strange reason.
As for the shaving, I've never had an ingrowing hair, I shave twice (well 3 times if you count finding missed patches), first in the direction of hair growth then against... finally a check to make sure I got all the stubbly feeling bits (always just under my ear back of jawbone and on to my neck that the razor seems to miss first and second time)
The last post was made 12 years, 341 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.83 - MySQL Queries: 13 - Page Size: 115.59 Kb
