| andym |
 andym World Chat Champion
| P.addy |
 P.addy Formerly known as P.
 Posted: 12:28 - 26 Feb 2013 Post subject: |
Small bit of 2 stroke oil down the bores, turn it over by hand.
or
Cover in petrol and set on fire.  |
| andym |
| P.addy |
 Posted: 13:01 - 26 Feb 2013 Post subject: |
Keep option B in reserve, just in case  |
| Timmeh |
 Timmeh World Chat Champion
| P.addy |
| Timmeh |
| andym |
 Posted: 14:24 - 26 Feb 2013 Post subject: |
I never even thought of the engine number to be honest..... or the oil for that matter... but then it was transported by pallet so the oil had to be drained anyway.
Will post some pics of the grubbyness in a few though
OK I hammers some of the crud off the engine number and would like to check if it is legal or not....
From what I can read:
ZXR00570131/1  |
| Timmeh |
| P.addy |
 Posted: 15:02 - 26 Feb 2013 Post subject: |
Shure tingz fam  |
| andym |
| P.addy |
 Posted: 16:56 - 26 Feb 2013 Post subject: |
Well played sir.  |
| Timmeh |
| andym |
| Irn-Bru |
 Irn-Bru World Chat Champion
 Posted: 18:37 - 26 Feb 2013 Post subject: |
Guessing you got that at a bargain price?  ____________________ KTM 990 SMT & Suzuki DR-Z 400 SM |
| andym |
| stevo as b4 |
 Posted: 19:04 - 26 Feb 2013 Post subject: |
It's a grubby old thing that's definitely been standing outside for some time, looking at the sparkplug body's. It will probably clean up and paint quite nicely with some furious scrubbing and a few litres of de-greaser etc.
TBH it's always a big gamble with buying an unseen never heard running secondhand lump, especially a more expensive and complicated 4stroke multi. But there's always the chance it could look far worse than it runs, and that when you get it installed it could run much better than the old lump ever did. You have no real way of telling until it's in the bike though.
If you could rig up a battery to operate the starter motor with it standing on the floor, then at least you could do a compression test, which is the best way to give you some indication of if it's worth trying to clean up, and get running, without a partial strip down.
If not, then you have got to get it into the bike, and then do a compression test. But if your fitting an engine you probably only mean to do it once, so you'd be probably wanting to clean it up and paint it first. It's a good idea to check the valve clearances while you've got great access, and then at least you can inspect the cams for wear as well.
Once it's in the bike, id say bung in some new plugs, fit a new oil filter, and fill it with the cheapest fresh bike oil you can find. If it does start and seem to run well without smoke, funny noises etc, then id do a 100-150mile shake down run (a tank full of fuel), and then drop the oil have a look at what drains out, and change the filter again and fill it with some reasonable oil and see how you go.
There could be some common problems and things to look at with the new lump, and these might be, sticking or contaminated clutch plates, a corroded or silted up water pump, best to check that now, and oil leaks, water leaks, and gear selection problems etc. If none of these issues are present when you fire it up and run it up the road, then you have been savvy and bagged a sound motor. If your very unlucky with it, then id look at it as a potential organ donor for you original engine as a positive outlook.
Good luck with it, and don't forget to keep all your fingers crossed before you hit the button!  |
| Timmeh |
 Posted: 20:22 - 26 Feb 2013 Post subject: |
Christ, what a mess.
That's gonna need some serious scrubbing. Personally I'd hire a steam-cleaner for a day and do it with that.
If it's full of oil and turns, then that's promising, although the state of the plugs and the inlet ports is, frankly, scary.
I'd be tempted to try to start it off the bike before anything else. ____________________ GSXR400 x2 | '94 RVF400 | '93 TZR125 4DL (again)
20:48:18 Temeluchus: comp you hunk of smouldering homos3x you |
| andym |
| stonesie |
 stonesie World Chat Champion
 Posted: 21:44 - 26 Feb 2013 Post subject: |
My biggest problem with that is the inlet ports shine a torch down the plug holes, if the piston crowns look like that then I would be having the head off. |
| andym |
| Walloper |
 Walloper Super Spammer
| 2 litre |
 2 litre Nova Slayer
| stonesie |
| mysterious_rider |
 mysterious_rider World Chat Champion
The last post was made 12 years, 359 days ago. Instead of replying here, would creating a new thread be more useful? |
