How to tell what headset bearings you have?
Bike Chat Forums Index -> The Cycling Forum
Minty
PostPosted: 15:15 - 27 Feb 2013    Post subject: How to tell what headset bearings you have? Reply with quote
Hello my lovelies,
My Carrera Virago T.T (road bike) is getting a little loose on the headstock and am wanting to replace it. I cannot find any spec listings for my bike now (think it is a 2008 model).
The last time I did one was on my Raleigh Lizard. How the feck do I decide which size and type mine is (after seeing the plethora of varying types available online)?
Mucho thanks. Thumbs Up
My fingers smell of your mum.
PostPosted: 15:19 - 27 Feb 2013    Post subject: Reply with quote
I think all you have to do is measure the width of the top fork tube (what the stem bolts onto).
Most of them are 1 1/8" I believe.
PostPosted: 16:19 - 27 Feb 2013    Post subject: Reply with quote
You have a threadless headset. Almost certainly 1 1/8" but measure it quickly just to check.
I just fitted an FSA Orbit one to Mrs stinkwheels MTB. Sealed tapered roller bearings. Shouldn't ever need another set.
Also read this: https://sheldonbrown.com/headsets.html
Minty
PostPosted: 16:38 - 27 Feb 2013    Post subject: Reply with quote
Yes, I am definitely threadless. Thanks chaps.
A colleague at my work thinks it'd be worthwile to take it apart, pack some grease and tighten it all up again before deciding to replace.
He has a decent bike and says he repacks his every 5-6 months to keep it tip top.
I have performed no maintenance on the headset since I came to own it around 3 and a half years ago.
PostPosted: 16:45 - 27 Feb 2013    Post subject: Reply with quote
If you had sealed ones, they wouldn't need re-packing, what with them being sealed and all.
Minty
PostPosted: 16:48 - 27 Feb 2013    Post subject: Reply with quote
Ok, I guess I need a look-see and find out just what I have.
I'll report back........... Karma
Minty
PostPosted: 17:11 - 27 Feb 2013    Post subject: Reply with quote
Work was quiet so I popped to the bike shed, undone the 2 pinch bolts and went to undo the main one........oh, it's loose already? ? ?
Tighten it all back up and it feels lovely now.
I bring much dishonour to the cycling family. Embarassed
D O G
PostPosted: 17:59 - 27 Feb 2013    Post subject: Reply with quote
If you are referring to the 'main one' being the one on the top, so applying tension along the length of the steerer tube, this is not really the way to think about it.
That bolt is to apply pretension to the headset before tightening the pinch bolts on the stem.
Correct way to tighten is to nip up the tensioning bolt so there is no play in the headset, then tighten the pinch bolts on the stem. Not the other way round.
Minty
PostPosted: 19:57 - 27 Feb 2013    Post subject: Reply with quote
That does make logical sense and is the way I tightened it back up. Felt like a different bike on the way home.
Ta muchly. Thumbs Up
The last post was made 13 years, 187 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> The Cycling Forum All times are GMT + 1 Hour
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.93 - MySQL Queries: 13 - Page Size: 60.72 Kb
