| redelmo |
 redelmo Borekit Bruiser
| jeddy11 |
 jeddy11 Traffic Copper
 Posted: 09:17 - 02 Mar 2013 Post subject: |
Any oil will do for the chain- specific sprays or 3 in 1 or old engine oil think the key is to keep it reguly lubed and clean.
Engine oil should use a motorcycle specific as some of the car ones are rumoured to cause clutch slip and cooling issues but others say they use car oil !!
You can't go wrong with a specific chain lube and specific motorcycle oil though if your unsure. ____________________ Fuelly My Z1000SX
cbt 06/08/11 mod1 (second go) 01/08/12 mod2 21/09/12
Varadero Viking YBR125>Varadero125>ER6F>Z1000SX !!! |
| neil. |
 neil. World Chat Champion
 Posted: 09:34 - 02 Mar 2013 Post subject: |
80 or 90w gear oil is a good choice, doesn't fling as much as engine oil and is generally recommended by the likes of Honda in their service manuals. Still works out cheap.  ____________________ CBT February 2008 | A2 June 2008 | Yamaha YBR125 (written off) | Honda CBF125 (current) |
| redelmo |
| ricklincs45 |
 ricklincs45 Nitrous Nuisance
| blurredman |
 Posted: 10:48 - 02 Mar 2013 Post subject: |
| neil. wrote: | 80 or 90w gear oil is a good choice, doesn't fling as much as engine oil and is generally recommended by the likes of Honda in their service manuals. Still works out cheap.  |
All very well, and i'll take that advice on board, but I generally have a few gallons of used 10w/40, or 20w/50 oil lying about, but generally no gear oil  ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
Current: 1973 MZ ES250/2 - 18k, 1979 Suzuki TS185ER - 10k, 1981 Honda CX500B - 91k, 1987 MZ ETZ250 (295cc) - 40k, 1989 MZ ETZ251 - 51k. |
| redelmo |
| whitedevil |
 whitedevil World Chat Champion
| ricklincs45 |
| redelmo |
| ricklincs45 |
 Posted: 16:37 - 02 Mar 2013 Post subject: |
| Quote: | But is the revs of any real issue. It is the torque that is putting the pressure on things. Either way the bearings, etc, should be specced to cope with it.
A lot of bikes just specify a fairly low grade oil. For example in the Suzuki workshop manual for the 1200 Bandit they just specify 10W40 SF or SG oil (both fairly low specs). Nothing about bike specific oil. |
This one could run and run
Well, the more revs, the faster and more often a gear will bite through the oil simply because the gearbox shafts will be turning more quickly (compared to a car, for instance). This isn't so much of a problem for the bearings, as, like you say, they are generally well up to the job, though, how bearings interact with oil is different to how gear teeth interact with it.
Quite happy to accept that oil technology has improved since 'I were a lad', though I don't think I'll be rushing out to buy a gallon of Morrison's own-brand 20/50 any time soon  ____________________ Author '80 Bikes, and counting...' Currently getting frustrated with an MZ 125 TS. |
| Islander |
 Islander World Chat Champion
 Posted: 18:29 - 02 Mar 2013 Post subject: |
+1 for the EP90 gear oil as a chain lube. It's very cheap, it doesn't fling and it does the job. Paraffin or diesel to clean the old crap off - use an old washing up brush or similar to work it in and scrub it. Top tip is to stick an old offcut of plywood or some cardboard between the chain and the wheel to stop the diesel from flicking over the tyre.
Any decent semi synth 10W40 will do for the engine. |
 Posted: 19:50 - 02 Mar 2013 Post subject: |
| ricklincs45 wrote: |
Well, the more revs, the faster and more often a gear will bite through the oil simply because the gearbox shafts will be turning more quickly (compared to a car, for instance). This isn't so much of a problem for the bearings, as, like you say, they are generally well up to the job, though, how bearings interact with oil is different to how gear teeth interact with it. |
Aye, but the only one that really applies to is the primary drive, as that is stepping the revs down by quite a bit for the rest of the gearbox. After that they are probably at similar revs.
Sure the gears give the oil a harder life, but then the oil is binned after maybe 6k max (and probably far less), rather than maybe triple that in a car. And even old Minis could cope with engine and gearbox oil shared with that kind of change interval.
The last post was made 12 years, 331 days ago. Instead of replying here, would creating a new thread be more useful? |
